- 4,867
He didn't. I think he just remarked that his 1-particle recipe no longer worked.vanhees71 said:I don't know, how Schrödinger interpreted multi-particle wave functions either.
Why should it? In the situation you describe, the charge distribution of the single electron before the first ionization is not measurable at all!vanhees71 said:According to Schrödinger each single (!) electron should give a wide-spread continuous distribution, while we always find a point-like track
The attempt to measure it heavily affects the state of the electron. As discussed in another thread in the context of Mott's analysis, the very first ionization effected by the single electron changes its state to one with a tiny cross section (reasonably well-defined transversal position) and a reasonably well-determined longitudinal momentum only, with a cigar-shaped charge distribution, whose track is measured!
The only situations where the charge distribution of a single electron can be measured are those where the measurement doesn't influence this distribution significantly, so that repeated measurements can be made. This is the case
- (i) for an electron in a well-collimated beam, and
- (ii) for an electron in a temporally stable stationary state.
