What is new with Koide sum rules?
  • Level: Graduate
  • Thread starter Thread starter arivero
    Rules Sum
355 replies · 146K views · last reply
Time ago the hard printed edition of the pdf had a last page with an illustration of how the measures had evolved across editions. Remembering that, I have setup a similar evolution for the Koide tuples
https://arivero.github.io/pdghist/predictions.html
ohwilleke said:
How do these papers fit into a larger research program of either of the authors?
Neither author has prior work on Koide that I can see. Hübner did some QCD and thus he knows QFT topics like renormalization schemes. Shulga worked on qubits from a physical rather than computational perspective (e.g. superconducting qubits), and maybe something there inspired his mechanism. But otherwise it seems a coincidence that two independent authors had their (very different) first Koide papers released on arxiv on the same day.
Actually three :oldbiggrin: Mine was removed because just resending now causes an autodelete, even if the resend includes doi and journal. It is a sort of peak surely caused by the AI leverage, but still funny.
I've been looking at the geometric origin of the phase ##\delta = \pi/12## (15°) that appears in the Koide parametrization for charged leptons.
In 4D Euclidean space, the rotation group decomposes as ##SO(4) \cong SU(2)+ \times SU(2)-## (isoclinic decomposition).
If you have a helical structure with ##C_3## symmetry (three-phase, 120° shifts), the closure condition at a nodal surface forces a total twist of ##\pi/2##.
The three-phase offset accounts for ##\pi/3## of that, leaving a residual of ##\pi/6##, distributed equally between the two isoclinic planes: ##\pi/12## per plane.
This gives ##\delta = \pi/12## as a geometric necessity, not a fit. The factor 3 between leptons (##\pi/12##) and quarks (##\pi/4 = 3 \times \pi/12##) would then correspond to the three color directions in the transverse space.
Has anyone explored the connection between the isoclinic decomposition of ##SO(4)## and the Koide phase? The coincidence ##\pi/12 \leftrightarrow 15°## seems too precise to be accidental, especially given that ##SO(4) \cong SU(2) \times SU(2)## is unique to 4 dimensions.
π/12 appears as part of a formula for a Koide phase in the neutral leptons (see Brannen's "Koide Mass Formula for Neutrinos"), not charged leptons. The phase for the latter is 2/9 radians (no appearance of π). The neutrino masses are not known with great precision and so there is no empirical confirmation of this π/12 formula, the way there is for the 2/9 formula, it is more theory-driven. It would be interesting to try to adapt Shulga's mechanism, mentioned in immediately preceding posts, and which introduces and then cancels factors of π, to the Brannen neutrino phase. And it would be miraculous to find an "isoclinic" origin of 2/9!
Thank you for the correction — you're right that the Brannen phase for charged leptons is 2/9 radians (no π), not π/12. I was imprecise.
Let me reformulate the observation more carefully.
The connection I'm exploring is indirect: in 4D Euclidean space with a three-phase helical structure (##C_3## symmetry, 120° shifts), the closure of the helix at a nodal surface forces the gradient perpendicular to the axis (total angle ##\pi/2##).
The three-phase offset accounts for ##\pi/3## of that rotation. The residual ##\pi/6##, distributed equally between the two isoclinic planes of ##SO(4) \cong SU(2)_+ \times SU(2)_-##, gives ##\pi/12## per plane.
This ##\pi/12## doesn't claim to be the Brannen phase. Rather, it enters the coherent closure condition as ##7\pi/12 = 2\pi/3 - \pi/12## (the target phase for counter-rotating closure). When this closure is imperfect (small mismatch ##\delta##), the forced precession onto one of the three ##C_3## directions introduces a correction of the form ##\sqrt{m_i} \propto 1 + A\cos(\theta_0 + 2\pi(i{-}1)/3)##, and the trifase identity ##\sum_{\tau=0}^{2}\cos^2(\theta_0 + 2\pi\tau/3) = 3/2## then gives ##K = 3/2## exactly independently of ##A## and ##\theta_0##.
So the question I should have asked is: has anyone explored the isoclinic decomposition of ##SO(4)## as the geometric origin of the closure condition from which a Koide-type parametrization can emerge?
The factor 3 between leptons and quarks would then correspond to the number of transverse directions (color), not to the phase itself.
Regarding Shulga's mechanism, interesting. His compact dimension with antiperiodic boundary conditions and the Casimir-like shift producing 2/9 is structurally reminiscent of a closure condition on a cycle.
I'd be curious whether his "a-field" dressing could be reinterpreted as a frame connection on a helical structure.
they are a lot of elegant results that are just generic of the theory of quadrics. Basically it is possible, except for the integrality, to repreoduce all the symmetries of https://en.wikipedia.org/wiki/Markov_number Markow trees of tuples, find the critical coefficient where the atractor of the tree becomes fractal, look for accumulation points. A loot of very pretty geometry, but that really one can do with different kinds of quadrics.
Your post seems to be related to your Zenodo papers. I’d like to remind you that these questions are okay as stand-alone questions but not if they bring in your unpublished Zenodo papers. PF explicitly state that we only discuss peer-reviewed papers from reputable journals. Sadly, zenodo does not count as either a published paper nor as a reputable journal.
If the discussion does extend into your Zenodo papers then the PF mentors will be forced to delete your relevant threads and give you a personal speculation warning or personal theory site ban.
Please take some time to read our site global guidelines.
Noted. My posts in this thread discuss the isoclinic decomposition of SO(4) and its relation to closure conditions, standard differential geometry. No personal papers are referenced or needed to follow the argument.
Linking the question of Pavani with mine, the point is that here there is a fine thread for Mathematics that somehow is not fully exposed in online forums: to characterise the solutions of permutation invariant equations Q(x_1,x_2,...x_n)=0. Markov's
[tex]x^2 + y^2 + z^2 - K x y z = 0[/tex]
have been very studied because it has Diophante solutions when K=3.
Koide generalisations
[tex](x^2 + y^2 + z^2 )+ K \times (xy + yz + zx) = 0[/tex]
are fine objects too, but they have no such elegant diophantine solutions and it is not easy to find studies going concrete with this, or at least digitised ones. This history goes as deep as Newton and Girard, and of course linked to the problem of having all the solutions as roots of a single cubic equation. Pure maths, anyway.
EDIT: I am recalled that the fruity meme problem is also in this category of permutation invariant equations, with k=4 in
[tex](k+2)(x+y+z)(x^2+y^2+z^2)+2(k+3)xyz - k (x+y+z)^3=0[/tex]
and I think that we already did the joke of writing koide in fruity way.
IFIC, Irvine, mexico and INFT, quite a collaboration! textured modulad forms look always as a way to hide the Wilzeck-Zee-Nambu perturbative approach to the muon mass.
I wondered what this is and found an older comment from you
https://www.physicsforums.com/threa...ncidence-or-significant.1058414/#post-6979218
AI suggests you are combining "“A New Approach to the Electron-Muon Mass Ratio" (and successor papers) by Barr and Zee, with “Horizontal Interaction and Weak Mixing Angles” by Wilczek and Zee...
As for the comparison with modular symmetry... These Zee et al models basically work by loop effects (radiative corrections, usually involving interaction with new fields), and give mass matrices where the entries are powers of some small parameter. My understanding of modular symmetry models is still very fuzzy, but there I think that, although you can get similar-looking mass matrices, the various powers arise from representation theory of the modular group - modular forms have "q expansions" and the modular representation of a field means that only one term in the expansion remains nonzero and physically relevant... There might be a more concrete explanation when you look for realizations of modular symmetry within string theory, but it depends on the particular mechanism (there is more than one way to obtain modular symmetry within string theory), e.g. in one stringy approach, it's the winding number of a virtual string which controls the powers... The best guide for model building is probably to try to obtain circulant mass matrices a la @CarlB.
Yes! From AI hallucinated citations to AI correcting hallucinations. Yes, WZ is the one that help to the frenzy of CKM angles, while BZ is about trying to justify "alphaology" mass ratios.
Meanwhile, AI has also pointed out to me
"The exact column texture: tree-level Yukawa universality in heterotic Z_3 x Z_3 orbifolds" (Navid Ardakanian)
which claims (section 8.3) that up-quark and down-quark yukawa matrices in this class of models are, in a first approximation, left-circulant. (If they are exactly left-circulant, there is no CKM mixing, so there must be corrections, possible sources of which are also itemized in the paper.)
I do not recall ever before seeing a string paper with circulant yukawas so this grabs my attention. Of course originally we want this for the charged leptons, and in these models the leptons arise differently to the quarks (section 2, second paragraph). Nonetheless, approximately-circulant yukawas for up and down quarks are my preferred explanation for the waterfall (#291 in this thread), and @arivero 's new paper reports a good "inverse-Koide" formula for the downquarks which also implies circulant yukawas (#321, #324). So this surely deserves some kind of study.
However: the author is an independent researcher with his own genAI business and no visible history as a physicist prior to this year (he has four papers on arxiv now), who lists Claude in the acknowledgments. So one might want to be on guard, even more than usual, as to whether AI is telling us what we want to hear, rather than the truth.
"The Very Nearly Right Theory of Flavor" (Arkani-Hamed, Figueiredo, Hall, Andrea Manzari)
Even more than #319, this seems compatible with the waterfall since it is complementary - it's about the phases in the quark mass matrices, rather than the mass eigenvalues. I just had a long dialog with "GPT 5.6-Sol high", and after singling out the texture identified on page 18 as number 24 in figure 6 (because the mass of the charm quark has a special origin in this scenario, and the charm quark is arguably a pivot point in the waterfall), "we" (mostly the AI) went on to identify a list of mechanisms that would start with circulant up and down quark yukawa matrices (as arguably suggested by the waterfall), and then perturb them to put the running values of everything within 1% of the standard model error bars. The implied field theory would be full of new fields and interactions of the kind that are popular with mainstream model builders, something which is unappealing to those of us who expect beyond-standard-model physics to be more minimal and elegant, but it's interesting to see (1) that the waterfall can dovetail with a cutting-edge mainstream proposal (2) that AI can already engage in theory construction at this level.
"On the Flavor Yukawa coupling for the Lepton Mass Hierarchy and the Koide Relation" (Olivier Rousselle)
This paper builds on #327 by Shulga, using ansatze in a QFT framework. The author is French and cites the oft-overlooked Francis Goffinet; he seems to have a math PhD from Sorbonne and some association with a Louis de Broglie Foundation.
To obtain Higgs-fermion couplings for the charged leptons, he supposes a complex 3x3 field S which he calls a flavor spurion and which another author might have called a flavon. The field coupling schematically is
(left-fermion) (S-transpose) (Higgs) (S) (right-fermion)
S is supposed to initially possess a U(3) flavor symmetry that is broken to U(1) x Z3. This gives S a circulant vev and the charged lepton yukawa matrix is (S-transpose) (S). The Koide constant Q comes out as 2/3 because energies associated with the flavor-singlet and flavor-octet parts of S are assumed equal; the Brannen phase comes out as 2/9 because of a "topological condensation" that obeys a formula due to Shulga (equations 12-13 here).
I am here just paraphrasing the paper's own assertions. Whether the physical definitions and mechanisms actually make sense, I cannot yet testify, but it seems plausible that some version of them should make sense.
The paper also makes use of an alternative formulation of the Koide relation (ultimately due to Koide himself), in terms of quantities z0,...,z3, that @arivero also used in a 2024 paper (see #277 forward, this thread). In Rousselle, these come from the singlet-octet decomposition of the eigenvalues of S; in Rivero, they are charges of preons, raising the question as to whether this Rousselle-Shulga scenario could be realized within Rivero's framework.
"Revisiting the U(1)-CP tension in QCD from a 1PI-action perspective" (Paolo Di Vecchia, Francesco Sannino, Graham M. Shore, Gabriele Veneziano, Shimon Yankielowicz)
This paper explores the relationship between two issues of QCD: why the strong CP-violating parameter θ is effectively zero (most popular solution, the axion), and why there is no Goldstone boson of axial symmetry (answer, the axial anomaly breaks the symmetry).
It's relevant for us because the explanation for θ_QCD = 0 could have been a massless up quark, and this is an ingredient of @arivero's "unperturbed waterfall", which has to be "perturbed" in order to line up with the actual quark masses. The instantons associated with the axial anomaly are already capable of giving a small mass to an otherwise massless up quark.
The question for us is whether such effects could actually shift the entire quark mass spectrum in the required way. It appears to make the most sense in a context like string theory, where QCD vacuum fluctuations might back-react upon intersecting branes and cause all the yukawas to change...
The differences between an extended Koide waterfall with a zero mass up quark and the observed masses is well approximated by adjusting the waterfall masses by the mass of the down-like quark that is not part of an up-like quark's Koide triple in the waterfall times the CKM matrix squared of the up-like quark and the missing down-like quark (or the reverse for a down-like quark).
For example, if the waterfall value of the up-quark is zero, and you add the b-quark mass times the ub CKM matrix element squared, you get something quite close to the measured value of the up-quark.
Where the CKM matrix element squared for the opposite charge quark that isn't included in its Koide triple is fairly large, for example, in the case of the c-quark, the waterfall value is further from the mark.
Where the CKM matrix element squared for the opposite charge quark that isn't included in its Koide triple is small and the mass of the excluded opposite charge quark is small, for example, in the case of the b-quark, the waterfall value is spot on accurate.
Surely, a linear "missing from the triple quark mass" times CKM matrix element squared is not truly the right formula. More likely, the waterfall value is a leading order approximation, this adjustment is a next to leading order approximation, and there would be additional terms and/or the adjustment needs to have a non-linear form.
The other plus of that way of thinking about systemic deviations from a pure waterfall model is that one can be parsimonious. You don't need another fundamental instanton or axion or BSM Goldstone boson or string theory to perturb the quark masses. The perturbation of the masses can arise from on shell and off shell W-boson interactions between one flavor of quark and another flavor of quark that a W boson can transform it into in a weak force interaction. No BSM particles or forces required.
From this perspective, the four CKM matrix parameters, and the relative magnitude of the six quark masses, are basically all properties of the W boson, with the overall mass scale of the fundamental fermions of the quarks driven by the Higgs vev, which, in turn, is itself a function of the W boson mass and the weak force coupling coupling constant (both of which are also properties of the W boson).
Basically, the W boson got robbed in the PR department. It, and not the Higgs boson, is the real "God particle", and a plausible source of the lion's share of the experimentally determined physical constants of the Standard Model.
Reply to Roberto Pavani's question of 22 May, which as far as I can tell was left open: “has anyone explored the isoclinic decomposition of SO(4) as the geometric origin of the closure condition from which a Koide-type parametrization can emerge?”
I have a partial answer. Not for the phase — that is where it was aimed — but for Q itself, and there it turns out to be an identity rather than a model. I would like it shot at.
PRIOR ART FIRST, so nobody wastes time. Foot's angle (hep-ph/9402242) and Brannen's circulant with ##\eta^2 = 1/2##, ##\delta \approx 2/9## are assumed known. The equal-norm reading — that Q = 2/3 holds exactly when the democratic and orthogonal components of the ##\sqrt{m}## vector have equal norm — is now in the literature twice this year (the Quantum Reports “Koide cone” paper, and Shulga's self-duality ##s^2 = 2|d|^2## in arXiv:2605.10245). None of that is mine. What follows is one step past it.
1. FOOT'S ANGLE IS ALREADY THE R^4 SPLIT ANGLE.
Foot states ##\cos^2\theta = 1/(3Q)##, with ##\theta## the angle between ##(\sqrt{m_e},\sqrt{m_\mu},\sqrt{m_\tau})## and ##(1,1,1)##. Put ##a = \cos\theta## and ##b = \sin\theta##. Then ##a^2 + b^2 = 1## by construction, and
$$Q = \frac{1}{3a^2}, \qquad \frac{b}{a} = \tan\theta = \frac{\sigma}{\mu}$$
where ##\sigma/\mu## is the spread over the mean of the three ##\sqrt{m}##. Checked on random triples, not just the leptons: it is an identity, no fit anywhere. ##Q = 2/3 \iff a = b = 1/\sqrt{2}##.
On ##\mathbb{C}^2 = \mathbb{R}^4## with the two isoclinic planes, ##a## and ##b## are the two circle radii, ##|z_1| = a##, ##|z_2| = b## — so Koide's condition is the Clifford torus, the equal-moduli surface, and nothing else.
2. THE STEP I HAVE NOT SEEN ANYONE TAKE: READ THAT SPLIT KINEMATICALLY.
Set ##\beta = b## and ##1/\gamma = a##. Then ##a^2 + b^2 = 1## is
$$1 = \frac{1}{\gamma^2} + \beta^2$$
and the ratio of the two circles is ##b/a = \beta\gamma = \tan\theta##, with the exact bridge
$$(\beta\gamma)^2 = 3Q - 1 \qquad \Longrightarrow \qquad Q = \tfrac{2}{3} \iff \beta\gamma = 1$$
i.e. ##\beta = 1/\sqrt{2}##, ##\gamma = \sqrt{2}##. Koide's condition becomes the fixed point of ##\beta\gamma##, which is also where ##pc = mc^2##.
3. WHAT THAT DOES TO THE RESIDUAL. On PDG 2024 masses, ##\beta\gamma = 0.9999966951##, i.e. 3.3049 ppm BELOW 1 — and that number is not new, it is the ##\sigma/\mu## everyone already quotes, wearing a different name. But it now has a sign and a direction: the triple sits below the fixed point, not scattered around it. “Q is 3.3 ppm off” says nothing about which way; “##\beta\gamma## is 3.3 ppm short” does.
THE FENCE, EXPLICITLY. Section 1 and the bridge are identities. What is offered and not derived is that this kinematic reading means anything — that ##\theta## is a velocity angle rather than a Euclidean one. I have no dynamics that forces the triple to sit at ##\beta\gamma = 1##. Without that, this is a change of variables with a suggestive smell, and I would rather hear that said plainly than have it quietly assumed.
ONE THING THAT MIGHT BE TESTABLE. If the construction is on ##S^3##, the Hopf projection to ##\mathbb{R}^3## keeps the split ##|z_1|^2-|z_2|^2## and the relative phase, and eats the common phase. So Brannen's ##\delta## is one or the other, and that is a fork with consequences: if relative, some lab observable other than the three masses must depend on it; if common, none ever can, and the mass spectrum is the only window onto it. Note also that the eaten circle is the one carrying the spinor's sign — half a turn of the common phase is exactly ##-(z_1,z_2)##, with nothing moving downstairs.
Two questions, then:
1. Has anyone written ##(\beta\gamma)^2 = 3Q-1## before, in any venue? I have searched hard and found nothing, but this thread is twelve pages and I may have missed a line.
2. Is there a reason the kinematic reading is wrong rather than merely unmotivated? That would be the more useful answer.
Thanks, this is the right kind of reply, and the fence is exactly where it should be.
huisman31ej said:
1. Has anyone written (βγ)2=3Q−1 before, in any venue?
As an identity it is already implicit in Foot: from ##\cos^2\theta = 1/(3Q)## you get ##\tan^2\theta = \sec^2\theta - 1 = 3Q - 1## immediately, so ##(\beta\gamma)^2 = \tan^2\theta = 3Q-1## is just Foot's angle rewritten, and in that form it is not new. What I have not seen anywhere is the split of ##\tan\theta## into ##\beta## and ##\gamma## separately, i.e. reading the single Euclidean angle as two independent quantities constrained by ##1 = \gamma^{-2} + \beta^2##. Foot's relation only ever fixes the product. So I'd say: the identity, no; the reparametrisation, I've not seen it either, and I've looked at the same twelve pages.
It is not wrong. Nothing breaks. On the two isoclinic planes ##a=|z_1|##, ##b=|z_2|## are genuine radii, ##a^2+b^2=1## is the ##S^3## constraint, and ##Q=2/3## is the Clifford torus, all of that is Euclidean and forced. Writing ##a = 1/\gamma##, ##b=\beta## is a legal change of variables on that same circle; it introduces no contradiction. So there is no argument that says "this is false."
The gap is the one you already named, and it is worth stating precisely so it isn't papered over: a Euclidean angle and a rapidity are the same real parameter only up to which quadratic form you declare invariant.##a^2+b^2=1## (a circle) and ##\gamma^{-2}+\beta^2=1## (the mass-shell) are the same equation, that's why the change of variables is free, but they carry opposite signatures the moment you ask what is being held fixed. So the kinematic reading is not an extra assumption on the algebra; it is a choice of which metric the ##S^3## inherits. Whether that choice is forced is exactly the thing neither of us can hand you a derivation of from inside this thread, and I agree it should not be assumed quietly.
Which turns your fork into the sharp question. Your Hopf remark is the useful part: the projection to ##\mathbb{R}^3## eats the common phase and keeps ##|z_1|^2-|z_2|^2## plus the relative phase. If Brannen's ##\delta## is the relative phase it must show up in some observable other than the three masses; if it is the common phase it is invisible to everything except the spectrum, and, as you note, half a turn of it is the spinor sign flip with nothing moving downstairs. That is a genuine dichotomy with different empirical content, and it is testable in principle. I'd push on that before I'd push on whether ##\theta## is a rapidity: the phase fork can in principle be closed by data, the signature question probably cannot, from masses alone.
"A Texture of Leptons for the Koide and Alikhanov relations" (Alessandro Strumia)
Alikhanov's relation is a new neutrino mass formula mentioned in #5 of the new thread "Published electroweak coincidences". Strumia notes an abstract similarity to the Koide formula, and then proposes a number of mass matrix textures for both neutrinos and charged leptons, and considers them in combination. His first texture for the charged leptons, K1, is the one which here we attribute to Carl Brannen (@CarlB). Strumia does not cite or mention Brannen, but he does cite a paper by Koide (reference 7) which mentions Brannen in the abstract. His other one, K2, is something new and was found via ChatGPT.
"Strumia notes an abstract similarity to the Koide formula, and then proposes a number of mass matrix textures for both neutrinos and charged leptons, and considers them in combination.
It seems that Strumia doesn't think very highly of the these results:
Quite a "downer" of an ending to one's own paper!
It was good enough for someone else to join the Koide-Alikhanov train:
"A Catalog of Lepton Mass Textures from Koide and Alikhanov Relations" (Sheikh Saad)
The author has previously worked on grand unification, so this constitutes a continued mainstreaming of Koide, by treating it as the consequence of a "Yukawa texture". On the one hand, this means more people will know about it and think about it, but on the other hand, this continues to bury, not just Carl Brannen's role, but the specific clue of the Brannen phase being 2/9 - something which Shulga and Rousselle, #327 and #347 this thread, do try to explain. (Koide himself, in one paper, noted the 2/9 but in effect said that would be too hard to explain and chose to focus on the relation as he had formulated it.)
The new paper's predicted neutrino mass seems high. And, I'm not a huge fan of the indiscriminate brute force approach of considering every possible combination of parameters no matter how ill-motivated.
"Descartes Curvature Geometry, Compact-Cycle Amplitudes, and the GST Cabibbo Seed" (Andrew M. Brilliant)
A paper about the Koide formula that I almost missed since it only mentions Koide in the bibliography, but the body of the paper mentions some who built on Koide, like Shulga and Kocik. The paper also cites correspondence with our own @arivero ! I've had no time to read it yet or the author's only other arxiv paper, which seems to be about the prospects that AI will explain various classic unexplained relations like Koide's.
