What is the change in gravitational potential energy
The discussion focuses on calculating the change in gravitational potential energy for a 6200 kg satellite transitioning from Earth's surface to a circular orbit at an altitude of 2500 km. The initial calculation using the formula E_{p}=mgh yields a potential energy change of 152,055,000,000 J. However, this approach introduces a significant error due to the assumption of a constant gravitational acceleration (g = 9.81 m/s²), which decreases with altitude. Participants emphasize the need to use integrals to accurately compute the work done against the varying gravitational force during the satellite's ascent.
  • Understanding of gravitational potential energy and the formula E_{p}=mgh
  • Familiarity with gravitational force equations, specifically F_{g}=G((m_{1}m_{2})/(r^{2}))
  • Basic knowledge of calculus, particularly integration
  • Concept of percent error in scientific calculations
  • Learn how to perform definite integrals for gravitational force calculations
  • Study the concept of varying gravitational acceleration with altitude
  • Explore the implications of percent error in physics calculations
  • Investigate the gravitational constant (G) and its role in potential energy equations
Students in physics, aerospace engineers, and anyone interested in understanding gravitational potential energy calculations and the effects of altitude on gravitational force.
I Like Pi
What is the change in gravitational potential energy of a 6200 kg satellite that lifts off from Earth's surface into a circular orbit of altitude 2500 km? What percent error is introduced by assuming a constant value of g and calculating the change in gravitational potential energy from m⋅g⋅Δh?
E_{p}=mgh
Well, the change in potential energy is simply mgh = 6200kg*9.81m/s/s*2500000m = 152055000000 which is the change in p energy.. then the rest i am lost.. i know there would be an error because gravity is not 9.81 m/s as you go on, it gets less and less as you leave earth..
thanks for your time
You need to calculate the work done to get to the potential energy for the two models - work is the integral of the force needed along the path you take. The constant g integral is easy since the force is assumed constant, leading to the familiar mgh. Since the force in the second model depends on R you need to do the definite integral between the starting point and the end point...
We're not doing work yet, just momentum and energy.
Thanks
Thanks
work done for taking the satellite from R1 to R2 = difference in potential energy between these two locations.
yes, but for the first part i just use mgh? to find the change in p energy, mg(hf-hi), hi = 0
then for the percent error, i don't get what you mean...
right, because the integral from R1 to R2 over mg is simply mg*(R2-R1)
okay thank you, therefore i get 152055000000 J, which equals 1.5*10^11 J
now what do i do for the second part? which equation would i use to find the actual value? cause i would then just find what the percent error is by dividing one by the other and subtracting that by 100 percent?
Thanks for your help!
The potential is the work done when taking the satellite from radius R1 to R2=R1+2500km. Putting them on a similar footing the work is
(1) \int_{R_1}^{R_2} dr G m_1 m_2 / R_1^2
(2) \int_{R_1}^{R_2} dr G m_1 m_2 / r^2
Where m_1 is the mass of earth, m_2 the mass of the satellite, G the gravitational constant, R_1 an average radius of the earth.
Are you able to do these integrals?
