What is the Correct Temperature Yesterday?
The discussion revolves around a problem involving thermal expansion and measurements taken by a survey crew using a steel chain. The key issue is determining the temperature from yesterday based on two measurements, with the understanding that the chain expands with heat, affecting the measured distance. Participants express confusion about how to interpret the measurements and the implications of thermal expansion on the results. There is a debate on whether the temperature yesterday should be higher or lower than today's temperature, with differing interpretations of the equations provided. Ultimately, the problem highlights the complexities of thermal expansion in practical applications and the challenges of deriving accurate temperature readings from indirect measurements.
jrs
While studying for the Fundamentals of Engineering exam, I came across the following problem that has me puzzled:
Yesterday a survey crew measured the distance between two points as 805.420m. They used a steel chain, but no correction was made for the temperature. Today, they measured the distance as 805.316m, also without correction. If a measured length is Lm and the temperature is Tc in degrees C, then the length is corrected for temperature by adding "(11.66)(10^-6)(Tc-20)Lm" to it. If today's temperature is 28C, what was the temperature yesterday?
The problem then goes on to give four possible answers (37.06 degrees C, 38.06 degrees C, 39.06 degrees C, and d. 40.06 degrees C) though I'm convinced that none of them can be correct.
Okay, I'll babble for a bit. Enough that you can see that I've got a few ideas, but also enough that you can see that I'm confused:
The second to last sentence in the problem is more confusing than it's worth, I think. From it I gather that the coefficient of thermal expansion of the chain is "11.66 x 10 ^ -6" with units of 1/degrees C. Also it seems as though they are trying to imply that at 20 degrees C, the change in temperature will be zero - my confusion level crosses into murk at about this point.
Back to the problem. Here are some things that I know:
Thermal Expansion is:
Code:
 DL/L = a DT
   where:
   DL   delta L - the change in length of the chain due to thermal
        expansion.
   L    - the "unchanged" length of the chain.  the length of
        the chain at DT = 0, I suppose.
   a    alpha - the coefficient of thermal expansion.
   DT   delta T - the change in temperature that caused the chain to
        expand from L to L + DL.
As the temperature increases, the chain will expand. The measured distance will get smaller as this happens. For example, if it was so hot that the chain expanded to 200% between measurements (unrealistic of course, but easy to think about) then the same distance would only measure 50% of its previous value.
From that little thought experiment it seems clear enough that according to the problem, the "temperature yesterday" should be less than "today's temperature". So none of the four given answers can be correct.
However I'm a bit stubborn and after I get started on a problem I like to grok it as best I can. So, what *is* the temperature today anyway?
It seems a bit more confusing to me because I'm only given 2 measurements - neither of which are "real" - they're only what the chain measured while it was expanded to some degree or another.
I've reasoned that:
Code:
 Lm = L / ( L + DL )
   where:
   Lm   length measured - the measured length.
   L    - the length of the chain at DT = 0.
        - another way of saying "what the chain would measure
          if DT = 0"
        expansion.
Now I've got two equations to work with, but it all falls apart here - I'm just not having the insight to figure out what to think next.
I hope someone is sparked with a bit of curiosity and wants to help me to an understanding. This isn't a homework problem (I graduated with a physics degree in '92 - to say I'm rusty would be an understatement though as I've been programming computers for that last 15 years rather than doing physics)
please help. thanks in advance.
-- Jonathan
Well, I got one of the answers listed. This is my approach:
I used the equation for thermal linear expansion
\Delta L=\alpha L_o \Delta T
so L-L_o=\alpha L_o(T-T_o)
I used "yesterday" as Lo and To, and "today" as L and T. I just put in the numbers given, and solved for To.
Yes, the chain will expand as temperature increases, but I can't see how you conclude the measured distance gets smaller. :confused:
I see it the other way around. If the chain measured longer yesterday, then that means there must have been a higher temperature yesterday compared to today.
I'm thinking about it this way:
Say I've got a chain, and at some temperature T0 it measures the distance between two fixed points to be the full length of the chain - call that 1 unit of measure. The next day is very hot and the chain has expanded to twice it's original length. At that time (at temperature T) the two fixed points only measure up to half the length of the chain. So the measured distance is 1/2 units long.
I see what you've done, and you're probably doing what whoever wrote the question intended the solver to do. But the way I see it, in order for that solution to be valid the values for L and L0 must have been measured by another scale. The one that is "on the chain" so to speak, isn't going to work.
Think about it this way (continuing with my totally unrealistic example): on the first day I measure 1 unit long (the full length of the chain). So I'll use 1 unit for the value of L0 (as you said you did). On day two (when the chain has expanded to twice it's original length) I'll go measure a different distance so that I get L0 also to be one unit (of course you an I know that I'm measuring something that is twice as far (because the chain has expanded) but the chain doesn't know that). Now plugging L into the equation and solving for T I get... ta-da, no change in temperature - because my measured distances were the same.
Does that make any sense?
(completely off topic - how do you do the laTex equations?)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
