What is the current perspective on quantum interpretation?
314 replies · 29K views · last reply
vanhees71 said:
Entanglement does not imply action at a distance, because local relativistic QFT is an example for a QT, which of course allows entanglement but is at the same time a theory where you have only local interactions by construction.
There are two aspects to quantum theory (including QFT). One is the recipe for the evolution of the quantum state (Schrödinger's equation for QM and the differential equations governing the evolution of the field operators in QFT). The second is the recipe that says that when one performs a measurement, one gets an eigenvalue of the corresponding operator, with a probability calculated from the quantum state.
The issue with nonlocality is about the second aspect. When you say "you have only local interactions by construction", you're not including the measurement process itself.
martinbn said:
I agree with this, but there is nothing in nature that behaves that way.
The point of the example is to show that local is not the same thing as lack of FTL communication. Local implies no FTL but the converse isn't true.
martinbn said:
Ok, I am late for the discussion but I am still confused. Following @stevendaryl by locality we mean that to understand what is going on in a small region we only need the information from near by. But how is the usual Alice and Bob scenario any different?
If Bob has already measured his particle's spin along the z-axis, then Alice's result for a measurement along the z-axis is already determined, even if she hasn't performed the measurement yet. It's not probabilistic in the sense of a stochastic process. It's still probabilistic in the sense of lack of knowledge---anybody who is unaware of Bob's result will assign a 50/50 subjective probability to Alice's result.
So the strangeness of EPR (and maybe QM in general) is how probability shifts from being intrinsic probability to being subjective probability. If you believe that intrinsic probability is an objective property, then such a shift seems to be a change in Alice's situation that happens FTL when Bob performs his measurement.
If you don't believe that probability is intrinsic, but is always subjective, then that seems to be suggesting either hidden variables or superdeterminism. If there was no change for Alice due to Bob's measurement, and after Bob's measurement it is 100% certain that Alice will measure spin-up, then it seems that it must have been 100% certain before Bob's measurement.
martinbn said:
Yes, but the question is should one still say that space-like events can be cause/effect related? I am not convinced that EPR, Bell and all that implies that one should.
No, space-like events cannot be cause-effect related by construction (microcausality constraint on local operators).
You still did no clearly define, what you mean by "local". The usual definition is that the Hamilton density is a local operator and that all local operators commute with it at space-like distances (micro-causality constraint). This excludes the possibility of space-like separated cause-effect related events, i.e., it excludes faster-than-light signal propagation. Other conclusions follow from that: the unitarity of and the cluster-decomposition principle of the S-matrix, the CPT symmetry, and the usual spin-statistics relation.
You keep saying that, but it completely misses the point. The microcausality constraint is on the field operators. But as you keep saying yourself, the only meaning to quantum theory is the predictions it makes about measurement results. Measurement results produce a SINGLE outcome from a set of possible outcomes. That is not described by the evolution of the field operators.
Yes, I did. Local means that the conditions in one region of space evolve over a period of time ##\Delta t## in a way that is independent of the evolution of conditions in regions of space that are farther than ##c \Delta t## away (once you take into account information in the common backwards lightcone). In the EPR experiment, that is not true.
Alice in one region is measuring the z-component of spin for one particle from an anti-correlated pair.
Far, far away, Bob is measuring the z-component for the other particle.
The evolution of those two regions is not independent, and the dependency is not removed by looking at information in the common backwards lightcone.
vanhees71 said:
The electromagnetic field is not frame dependent.
Its value at a particular point is not. But @stevendaryl meant by "state" a global set of values for the EM field "at an instant of time". That is not invariant because "an instant of time" is not; it's frame-dependent.
This is just another way of saying "the correlations violate the Bell inequalities". Which is, IMO, a much better way of saying it, since it doesn't require any questionable notion of "evolution" or "state". It's just a testable statement about the correlations.
It's not another way of saying it. There is quite a lot of work needed to go from things being local in the sense that I'm talking about to Bell's inequalities being satisfied. But it is true that every local system in my sense obeys Bell's inequalites.
This is an empty definition in the case of quantum theory. What do you mean by "conditions in one region of space"? In quantum theory what evolves are probabilities (and quantities derived from them like expectation values).
Your concrete example of course makes sense, but what you describe there is no non-locality but inseparability. There are correlations between far-distant measurements described by entanglement, but there is no non-local causal effect from one local measurement at A on the measurement at B and vice versa, because the interactions between the photons with the detectors at the places A and B are local, i.e., they fulfill the microcausality constraint such that there cannot be any instantaneous influence between the detectors at the far distant places through the measured object (in this case the two photons).
I realize now that what I'm sketching out is basically what Bell laid out in his "Theory of Local Beables":
https://cds.cern.ch/record/980036/files/197508125.pdf
It would help if you clarified in what sense you are talking about FTL, in the gallilean or classical pre-Einstein-Lorentz sense where it can still be causal since there was no speed limit or in the modern (Einstein relativistic) more fundamental sense.
I think we should discuss within relativistic theory only, and since the only really working relativistic QT is local relativistic QFT, maybe also restrict ourselves to this.
There is also of course no problem with actions at a distance in non-relativistic physics (to the contrary it's the usual model of interactions as Newton's theory of the gravitational interaction). There's of course also no microcausality condition in non-relativistic QFT. It couldn't even be sensibly defined there.
I think so too. That's why I wanted for stevendaryl to clarify, since he himself made a classification of qm interpretations with 2 catrgories: wrong and nonsense. My point is that talking about FTL is mathematically sound but physically wrong with the galilean mindset, and pure nonsense with the modern fundamental mindset so maybe it's better to leave it out.
The issue is whether QM obeys Einsteinian relativity, when one takes into account the measurement process. As I explained in a different post, quantum mechanics has two pieces: (1) the smooth deterministic evolution of the quantum state, and (2) the nondeterministic production of a measurement result. In QFT, it's pretty clear that (1) is relativistically invariant, but it's much less clear whether (2) is. According to some interpretations of QM, relativity is only approximately true, for macroscopic measurements, but fails at a microscopic level.
In any case, I don't agree with you that you need to assume Einsteinian or Galilean relativity in order to say what FTL means. It is enough that there is a single frame in which light travels at its characteristic speed. Then relative to that choice of a frame, you can ask whether or not there are FTL influences.
stevendaryl said:
The issue is whether QM obeys Einsteinian relativity.
That's not so hard, Non-relativistic QM doesn't obey it, while its generalization RQFT does. This doesn't necessarily mean the whole construct of QFT as a mathematical theory is correct, if that's what you are suggesting.
I didn't talk about assuming anything, I asked you a simple question that you seem to refuse to answer and that's your privilege. But when you say there is a single frame in which light travel at it's characteristic speed and you mention FTL in relation with it, it is relevant to know if you are referring to frames in Galilean or Einsteinian relativity because it is not the same thing and it helps to clarify which to judge the argument adequately.
The latter is just not clear.
I don't understand what your question means. Whether something is FTL doesn't depend on whether we're talking galilean or einsteinian relativity. It doesn't depend on relativity (galilean or einsteinian), since I'm only talking about a single frame. Relativity is about the relationship between two DIFFERENT frames. Within a single frame, relativity is not relevant.
Maybe it would be better to say "coordinate system" rather than frame?
As I said its formulation has serious mathematical issues, but the "FTL influence" is a physical problem it does not have, it makes perfectly causal predictions.
FTL might not depend on it, that's what I'm saying in a way, but you must have some idea of what you intend for your single frame when it relates with other frame. Single frame physics is not really so useful as in NRQM for quantum fields theories.
Oh, my god. I HATE Physics Forums discussions.
I agree that
  1. In relativistic quantum field theory, the quantum state evolves according to local equations.
  2. RQFT does not allow FTL signal transmission.
The issue is whether 1&2 imply that it is local. 1 by itself is not enough, because the smooth evolution does not include the measurement process by which a single outcome is selected out of a set of several possibilities. 2 is not enough, either, because although Local implies no FTL, no FTL does not imply local.
  • Haha
If one uses your definition of "local" in post #90, then relativistic quantum field theory is not local. So we don't have to use another person's definition, we just use yours.
If you accept that collapse interpreted as physical is "local" since it does not allow "faster-than-light signal propagation", then relativistic quantum field theory is "local".
If you reject that collapse interpreted as physical is "local" since allows "faster-than-light signal propagation", then relativistic quantum field theory is "nonlocal".
Truly, I don't understand how what some people say about "collapse" isn't complete nonsense.
In an EPR experiment, with anti-correlated spin-1/2 particles, Alice and Bob agree to measure spin along the z-axis. Immediately before Alice's measurement she would say that there is a 50/50 chance that Bob will measure spin-up. Immediately after Alice's measurement, if she gets spin-up, the probability that Bob will measure spin-up changes to 0. How can you account for that sudden change? It seems to me that there are several possibilities:
  1. Alice's measurement caused a physical change that affected Bob's measurement. Well, we have to rule this out because it involves FTL influences.
  2. Alice's measurement, like a classical measurement, only changed Alice's knowledge about Bob. It didn't change anything physical on Bob's end. But let's think about this. If after Alice's measurement, she knows that it is 100% certain that Bob will measure spin-down, and if Alice's measurement didn't change anything about Bob, then it means that before Alice's measurement, it must have already been true that Bob would measure spin-down (only Alice didn't know it). Well, we have to reject this, too, because it involves hidden variables (the value of Bob's measurement before he makes it).
  3. Umm, maybe there are two versions of the universe: One in which Alice measures spin-up and Bob measures spin-down, and another version in which Alice measures spin-down and Bob measures spin-up. Well, this would be a many-worlds interpretation, which is fanciful nonsense, and should be ruled out.
Any of those three seem like weird, unappealing choices: Unobservable FTL influences, unobservable hidden variables, unobservable alternate universes. But to reject all three seems like nonsense. Or at best, it amounts to saying: "I have no idea".
Most physicists accept that time dilation and length contraction follow from the relativity principle applied to the measurement of c, even though we have no constructive counterpart (causal mechanism) for that principle account. Indeed, this is the standard presentation of special relativity in the introductory physics textbooks. The mystery of quantum entanglement can be resolved in similar fashion via the relativity principle applied to the measurement of h. Would that principle account of quantum entanglement suffice here, or would you still require a constructive counterpart?
The only sensible way I know of, in which relativistic quantum field theory is defined is through Wightman's axioms which, unlike the axioms of Dirac-von Neumann for non-relativistic QM, are silent about observables, about measurements or whether measurements on a QFT observable are in agreement with Einstein' SR. And this set of axioms only work(s) for the free spinless scalar (electrically charged or not) fields. Interactions between these fields (or self-interactions) and other Poincare covariant ones, not to mention interactions with any measurement device, are already outside the axioms.
So the whole discussion of interpretation issues in SR context seems futile to me.
P.S. Sure, there is the Haag-Kastler operator algebra axiomatization, but I do not know if it is superior to Wightman's from interpretation-relevant considerations (such as measurements and interactions between measured and measurer).
I thought that in QFT that the measurements and observables at least included detection of particles. People certainly use QFT to compute things like cross sections, which are empirically measurable, right?
I think we can consider relativity in 2+1D where there are rigorously constructed interacting relativistic field theories. Haag's own book (Local Quantum Physics, 1996) does recognize the discontinuous state update (p301), at least informally, and discusses interpretation in a way that can be understood if the principles of non-relativistic QM also apply to relativistic QFT.
From my perspective, 2 is possibly reasonable and appealing. I will try to just explain how this is not a problem for Bell.
(To understand my line of reasoning, you need some Qbism on steroids)
To understand why you can have hidden variables, and still escape Bells theoreem. There is, and always was a problem with the premise of "realism" and ##\lambda## in Bells theorem.
Bells idea of hidden variable
##\lambda## - suppsedly responsible for the predeterminded correlation - is "real" and in principle "known" to whole measurement device and environment, except the ignorant observer (say physicists). Ie. the hidden variable in Bells theorem represents the experimenters ignorance only! The outcome follows the single-lambda logic, without "self-interference" (Bell inequality). Ie. the interactions follow as if ##\lambda## was predetermined, and then averaged.
But, let's think about it. Does this make sense? If a bell pair is created, and isolated, would it make sense that all of the universe EXCEPT the physicists, would be informed about this?
Insted consider this.
Then let's consider the case where ##\lambda## - suppsedly responsible for the predetermined correlation - is hidden not only to the ignorant physicists, but also to the whole measurement device and environment. Then what?
Lets think about it. Does this make sense? If a bell pair is created, and really isolated until measurement, would it make sense that all no other "agents" in the universe EXCEPT the physicists, also cannot be informed about this? I think so.
To understand the point here, let's look at Qbism, where the subjective probability does not reflect correlations on observerations, but instead causally determines the action of the agent.
"An agent’s probabilities are defined by her willingness to place or accept any bets she believes
to be favorable to her on the basis of those probabilities. "
The steroid part is this: Now let's consider any other classical part fo the system an agent, say the measurement device, and all of the environment are a set of "Qbist agents". Now if these agents are ALSO ignorant about ##\lambda## as per the second case, it will follow that the actions of these agent will reflect the uncertainty even if ##\lambda## is set. This is because we assume that the action is causally related to the subjective probability, while observations are merely "correlated".
Ie. the hidden variable explains the non-local correlation of observations, but it does nto imply non-local causation. Its simply two different things. Bells original realism does not make the discintion as I see it.
I hope this does not offend anyone, I'm just trying to add a new reflection. This basic lineout is simple and selfcontained enough to hopefully not require a "reference"? Qbism is a minor but still widely discussed interpretation. The steroid addition is not standard however.
(Would WOULD required a reference, is to take this another step, and INFER physical interations (hamiltonian) from the agent-updated-mechanis. But not that I am not making that claims here. I am just saying it seems a possibilit, which is trivial enough.)
An Introduction to QBism with an Application to the Locality of Quantum Mechanics
- Christopher A. Fuchs, N. David Mermin, Ruediger Schack, https://arxiv.org/pdf/quant-ph/0703192.pdf
To associate further to Demystifiers Solipsist HV, this is the way I imagine meaning to HV. It can potentially restore some "realism" buy not in the Bell sense, the bell realism is IMO outdated. This is my problem, rather than locality. To me locality is never questioned. Non-local correlations(observations) yes, but not non-local causation (actions)
Solipsistic hidden variables
-- H. Nikolic, https://arxiv.org/abs/1112.2034
/Fredrik
