MHB What Is the Domain and Range of y=cos(3(x - 45°)) +2?
The domain of the function y = cos(3(x - 45°)) + 2 for one cycle is determined by the interval on the x-axis where the function is defined, specifically from -45° to 90°. The range of the function is derived from the cosine function, which oscillates between -1 and 1, resulting in a vertical shift that adjusts the range to 1 to 3 after adding 2. To find these values, it is suggested to graph the function for better visualization. Understanding the definitions of domain and range is crucial for solving such problems effectively. This discussion emphasizes the importance of clarity in mathematical definitions and graphical representation.
mathuravasant
State the domain and range for one cycle of y=cos(3(x - 45°)) +2 Show your work.
Mathematics news on Phys.org
Beer induced request follows.
Please show us what you have tried and exactly where you are stuck.
We can't help you if we don't where you are stuck.
like how do you find domain and range off from that given equation I just don't know what to do
You are having a great deal of trouble with these. I suspect the biggest cause isn't in the problems but in the definitions. I would suggest having a 3 x 5 card (or some other modern equivalent) stating what the domain, range, frequency, wave number, horizontal shift (or phase), and vertical shift are for each.
[math]y = cos( 3(x - 45) ) + 2[/math].
What is the domain? It's the interval on the x-axis that the function is defined on. So one cycle is 360 degrees. Thus
[math]0 \leq 3(x - 45) \leq 360[/math]
So what are the possible values for x? [math]0 \leq 3(x - 45)[/math] to [math]3(x - 45) \leq 360[/math]
What is the range? It's the interval on the y-axis that the function takes on over the domain. So for the sake of argument let's say that the domain is [math]-45 \leq x \leq 90[/math]. (Mind you, it isn't.) Then what is the range of cosine? It's best to graph this one and take a look since cosine "waves" so graph [math]y = cos( 3(x - 45) ) + 2[/math] and find the biggest change in y value for [math]-45 \leq x \leq 90[/math].
Let us know how it goes.
-Dan
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
