What is the Energy Transfer in a Spring and Oscillation Collision?
The problem involves a bullet colliding with a block connected to a spring, focusing on energy transfer and motion after the impact. The subject area includes concepts from mechanics, specifically energy conservation and momentum in collisions.
  • Participants discuss using conservation of momentum and conservation of energy to analyze the problem. Some express frustration with initial attempts, while others suggest alternative approaches and question how to set up the equations correctly.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some guidance has been offered regarding the use of conservation of energy, but there is no clear consensus on the setup or the next steps.
Participants note the potential for previous discussions on similar problems, indicating a possible overlap in content. There is also mention of the challenge in applying conservation principles effectively in this context.
parwana
A 5.00 g bullet moving with an initial speed of v0 = 405 m/s is fired into and passes through a 1.00 kg block, as in Figure P13.58. The block, initially at rest on a frictionless horizontal surface, is connected to a spring with a spring constant of 950 N/m.
Figure P13.58
(a) If the block moves 5.00 cm to the right after impact, find the speed at which the bullet emerges from the block.
m/s
(b) If the block moves 5.00 cm to the right after impact, find the mechanical energy lost in the collision. J
I don't know where to begin, its so frustrating
Not that I wouldn't like to help you, but I'm almost 100% positive I've seen this exact picture in the last 2 or 3 weeks. I suggest you do some searching first. :wink:
I checked the thread and it wasnt much of a help
I tried to use conservation of momentum for this but it doesn't work
Try conservation of energy.
how do I set it up though
.5kx^2= .5mv^2?
The original kinetic energy will be the sum of the spring energy and the bullets remaining kinetic energy after impact.
  • · Replies 20 ·
