What is the Equation for Calculating the Mass of the Sun?
  • Thread starter Thread starter Dark_Dragon
    Mass Sun The sun
The discussion focuses on the equation for calculating the mass of the Sun using the formula T²/R³ = 4π²/GM, where T is the orbital period and R is the distance from the Sun. An initial calculation yielded a mass of 3.27e+15 kg, which is incorrect compared to the known mass of the Sun, 1.98e+30 kg. Participants emphasized the importance of correctly converting the orbital period from years to seconds and squaring it in the calculations. After reviewing the calculations and receiving assistance, the original poster confirmed they resolved the issue. Accurate calculations are crucial for determining the mass of celestial bodies.
Dark_Dragon
-Deleted-
Dark_Dragon said:
ok, so if my equation to find the mass of the sun is:
T²/R³ = 4п²/GM
and i used the orbital period (T²)(in seconds) and the distance from the sun (R³)(in metres) of say, venus, then i transform the equation to find "M" and i get:
M = 4π²(R³/T²) / G
M = (4π²)(1.08e+11/1.95e+7) / (6.67e-11)
=3.27e+15
but the mass of the sun is 1.98e+30.
Check your calculations. I get 1.92*10^30 kg.
-Deleted-
Check your orbital period. Make sure you convert the year into seconds and then square it.
ok scratch the last post, i got it, thank you for your help both of you!
much appreciated =)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
