What is the final velocity of a sail after being hit by photons from a star?
The discussion revolves around the final velocity of a sail after being impacted by photons from a star. The problem involves concepts from momentum and energy conservation, particularly in the context of elastic collisions and the behavior of photons upon reflection.
  • Participants explore the relationship between the sail's mass, initial velocity, and the momentum transferred from the photons. Questions arise regarding the assumptions made about the sail's initial state and the treatment of energy conservation in the context of the collision.
Some participants have provided guidance on considering the conservation of energy and momentum, while others express concerns about the validity of certain approximations. Multiple interpretations of the problem are being explored, particularly regarding the effects of the sail's initial motion and the implications of relativistic mechanics.
There is mention of constraints related to the sail's mass and initial velocity, as well as the need to account for relativistic effects if applicable. Participants are navigating the complexities of these factors in their discussions.
Faiq
The luminosity of the star is defined as ##\phi = L/4\pi r^2##
The photons from the star hits the sail of mass ##M## and cross sectional area ##A##. What's the final velocity of the sail after getting hit by photons for a small time t? Assume the collision is elastic and the photons reflects after hitting the sail.
##\delta p_s = 2\delta p_p= 2\frac{E}{c}=2\frac{LAt}{4\pi r^2c}##
##M\delta v = 2\frac{LAt}{4\pi r^2c}##
##v_f = 2\frac{LAt}{4M\pi r^2c} +v_i##
Is this correct? Because I assume the photons bounce back with a momentum of magnitude equal to initial but that's not stated anywhere.
It is correct as long as the sail mass is large and the sail is essentially at rest. Basically you are making the approximation that the sail rest frame is the CoM frame, in which the light will have the same frequency before and after the collision.
If the sail mass is small (same order as the energy hitting it during the time) you cannot neglect its recoil energy. If it is moving very fast you cannot neglect the Doppler shift and relativistic mechanics.
I am in my early university classes and have only covered conservation of momentum and energy. Do you think I have to account for the things you mentioned? Btw the sail is not initally at rest. What should I do to account for that?
But the thing is that you are not accounting for conservation of energy. (In your approximation he light has the same energy before and after and the sail has more after. It can only be neglected in the given limit.) Your approximation is only valid in the limits I told you.
Yes that's why I was also concerned. Can you please suggest a way to account for the energy?
Yes, make sure it is the same before and after. You have two unknowns and two equations, so it is only an algebraic exercise. If the sail is moving at non-relativistic speeds you can use the classical expressions for its momentum and energy. If not you need to use relativistic mechanics for both light and the sail.
I am getting an equation like ##4E+M(v_i^2-v_f^2)=2Mc(v_f-v_i)## Not sure what to do now since I have to figure out ##v_i## in terms of remaining terms. (E is total photon energy emitted from star)
Where did you get that from? Why don't you start from the beginning and write down the energy and momentum conservation equations (without assuming the light to have the same energy before and after).
##\frac{E}{c}+Mv_i=-p_p+Mv_f##
##E+0.5mv_i^2=0.5mv_f^2+p_pc##
Solving both of them got me the equation that I mentioned above
Looks fine to me. The initial speed ##v_i## is a collision parameter. Your result will of course depend on it.
  • · Replies 17 ·
17K
  • · Replies 40 ·
