teggenspiller said:
gosh duh. THANK YOU so much disconnected. so how do you know when to subtract and when to add velocities, do i just have to analyze their directions?
Yeah. Like fewmet said, it's best to draw a picture (initially on paper, but eventually in your minds eye) and designate one of the directions as positive (the direction you choose is arbatrary, you are defining the coordinates used) and the other, obviously, as negative. Things get a little more complex as you add dimensions, but the same principles hold.
The combination of vectors is always addition, however one or more may have a negative value.
teggenspiller said:
by the way, why is this 1 suddenly negative in the explantaion you gave me.. i just ran into this reading over it;
"p2=1*(-2)
Thus the initial momentum is 1+(-2)=-1
Thus the final momentum is -1."
In my notation p1 was the momentum of particle 1 and p2 was the momentum of particle 2.
So the momentum is give by the mass times the velocity, and the velocity (a vector!) of particle 2 is 2m/s in the negative direction, and is thus -2. 1*(-2)=-2, right? so the momentum of particle two is of magnitude 2 but in the negative direction, thus -2.
The momentum of particle 1 is just 1*1 because it's velocity is one in the positive direction=1.
So the total momentum is p1+p2, right? so 1+(-2) gives the result of -1, agreed? So the total momentum is magnitude 1, but pointed in the negative direction. This makes sense as the objects are of equal mass and the one moving in the negative direction is going faster.
The 1 isn't suddenly negative, it's just the result of adding 1 and -2!
So the initial momentum is -1, thus the final momentum is -1.
Remember that the new mass is the sum of the two initial masses, which were set to 1. Therefore the new mass is 2. We will call the momentum of the two objects moving together p12.
p12=2*v
But we know that p12=-1 from conservation of momentum, thus
-1=2*v
thus
v=-1/2
So the resulting velocity is magnitude 0.5, and in the negative direction - which makes sense. If you threw two balls of putty at each other and one was going faster then the other (and the masses were equal), you would expect the resulting motion to be in the same direction as the one that was traveling faster (thrown harder), right?
As the question asks for the magnitude |p|, the negative sign disappears.
Notice that if you define the coordinates as v1 being negative and v2 being positive, the final momentum will be positive 0.5. Again this makes sense as this new coordinate system is the inverse of the initial system, so any value that used to be negative is now positive and visa versa.
teggenspiller said:
Two trucks with the same masses are moving toward each other along a straight line with speeds of 50 mi/h and 60 mi/h. What is the speed of combined trucks after completely inelastic collision?
i assume the 50m/s is moving east, while 60m/s mass is moving west. That would make their final combined velocity
pi=1*50
p2= 1*(-60)
50+(-60)= -1 <--i put this negative one here, cause that's what you did.
10mi/h
^^^^which is actually incorrect..
Eeeep! 50+(-60)=-10, not -1!
And remember that the final mass is the sum of the masses, which in this case is again 2.
so
p12=2*v
-10=2*v
v=-5
Make sense? Feel free to ask if I didn't explain it right. I am very prone to silly little mistakes (like forgetting that gravity exists...)!
