What Is the First Acoustic Peak in CMB?
The first acoustic peak in the Cosmic Microwave Background (CMB) temperature power spectrum represents the initial compression of acoustic waves in the baryon-photon plasma of the early universe, occurring when the universe was several hundred thousand years old. This peak is crucial for understanding the universe's geometry, as its angular separation correlates with the size of the horizon at the time of decoupling. Measurements indicate that the universe is nearly flat, which implies a critical density that ordinary and dark matter alone cannot account for, leading to the conclusion that dark energy makes up about 75% of the universe's energy budget. The discussion also touches on the relationship between the sound horizon and the location of the first peak, clarifying that the peak is indeed observed at multipole moment l=200. Overall, the first acoustic peak is essential for probing the universe's expansion and the role of dark energy.
shadi_s10
Dear all,
Searching proofs for Dark energy, people always mention "the first acoustic peak in CMB".
can anyone tell me what exactly is that?
how long did we expect it to be and now -having Dark energy- how long do we see it?
can anyone help me please?
Space news on Phys.org
The first acoustic peak is seen in the CMB temperature power spectrum:
Consider the graph formed by the red line. This is the best fit WMAP temperature power spectrum. It measures the fluctuations in temperature as a function of multipole moment, \ell. The multipole moment corresponds to the angular separation, \theta of the correlated fluctuations on the sky: \ell \approx \pi/\theta. So in this plot, scales on the order of the present-day horizon are at the far left, and smaller length scales are at the far right. The broad central peak is the first acoustic peak.
What you are looking at in this plot is the Fourier transform of the spatial density correlation function -- in English, what you are seeing are acoustic waves oscillating in the baryon-photon plasma of the early universe. It's a snapshot of the universe when it was some several hundred thousand years old. As the universe cooled, the photons decoupled from the baryons, and no longer participated in these oscillations -- they instead began free streaming across the universe making up what we know of today as the CMB, forever locking in these intricate patterns of primordial oscillation.
The first peak corresponds to an acoustic wave that had just enough time to compress once before this decoupling. The higher order peaks have gone through more oscillations (and hence, are damped somewhat relative to the first.) Scales to the left of the first peak were actually 'superhorizon' at the time of decoupling -- they subtended length scales that were causally disconnected -- and so oscillations could not be set up on these scales.
Anyway, so back to the first peak. The first peak corresponds to a very special length scale in the early universe -- namely, its angular separation gives the size of the horizon at the time of decoupling. Astronomers measure distances by measuring the angle subtended by an object of known size. In our case, theory tells us how big the horizon was at the time of decoupling, and we know how long ago the CMB was emitted. From the figure above, it's simple geometry to relate the angle, \theta, to the horizon distance at decoupling. If the geometry is flat, well, you get the usual Euclidean result. However, if there is appreciable spatial curvature you'll measure a smaller angle for a given length scale (see left figure). And so, the angular diameter of the central peak -- it's position along the x-axis -- helps to determine the geometry of the universe. For example, an open universe would give the gray curve in the figure. WMAP has discovered that the universe indeed is very close to flat, to about 1%.
So what does all this mean for dark energy?? If the universe is flat, then it must have a density equal to the critical density. But we know that ordinary matter and dark matter only account for roughly 25% of the critical density. We know this from several data sources, but perhaps most notably, by measuring the locations and sizes of the higher order peaks in the CMB. So there is another source of energy that contributes about 75% to the overall budget. It needs to be smooth and uniform, and we call it dark energy.
The fact that dark energy causes the universe to undergo accelerated expansion can also be seen in the CMB, although the evidence for this is most notable in supernovae redshift measurements.
What a fabulously lucid answer, thansk for answering my red tilt question as well. I salute you .
Nina_ress said:
Thanks for the detailed answer. I have the following question. I'd like to know if the horizon you mentioned is the same as sound sound horizon (c_sound*time_recombination)? As I can see from this table l_a = 301 http://lambda.gsfc.nasa.gov/product/map/pub_papers/firstyear/basic/wmap_params_table.pdf
but in the literature everyone mentions that the peak is located at l=200.
Hrm. That is odd. The first peak is indeed located at l=200, so I'm not sure why they obtain a different acoustic scale. I will need to look more closely at how they define their quantitites; in the meantime, check out http://background.uchicago.edu/~whu/araa/node7.html and see if it helps.
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Title: Can something exist without a cause? If the universe has a cause, what caused that cause? Post Content: Many theories suggest that everything must have a cause, but if that's true, then what caused the first cause? Does something need a cause to exist, or is it possible for existence to be uncaused? I’m exploring this from both a scientific and philosophical perspective and would love to hear insights from physics, cosmology, and philosophy. Are there any theories that explain this?
