What Is the Fourth Dimension and How Does It Work?
  • Level: High School
  • Thread starter eggy
    Shape
eggy
Based on info found in this forum, I have compiled info along with personal thoughts and observations in attempt to understand the fourth dimension better
any input or corrections would be helpful, along with links to sites you have found helpful in your experience.
Thanks! My notes below:Observations:
Move up/down
Move left/right
Move forward/backward
(Age [one direction])
2d circle in 1 dimension is a line getting larger and smaller
3D circle in 2 dimensions is a circle getting larger and smaller
4d sphere in 3 dimensions is a sphere growing and shrinking
What does 4d shape look like? Tesseract? Hypercube?
How does it work?
Possible dimension- Time
Visualized in 2d as a straight line
Visualized in 3D as a straight line
Conclusion: time is a straight line which any point can be accessed through any point all the time.
Time never started and never stops (different from eternity) TIME OPERATES IN A LOOP (time never started and never stops but with infinite time matter will reassemble itself into every single possible combination) given that time is relative and infinite. Light and time are distorted in a black hole (general relativity)
2d timeline is 2d, only exists in 2+ dimensions (too simple) 3D timeline only exists in 3+ dimensions (2d cannot hold due to lack of dimensions.) proposed 4d timeline only exists in 4+ dimensions (3D cannot hold due to lack of dimensions)
Does not exist in any dimension above current dimensionUndefined
Cannot be defined
Time is not infinite (nor finite)
There is Never nothing. Point=0 dimensions
The way you would say this technically is that the foliation of a 2D disk into an ordered series of 1D submanifolds is a line segment that gets larger and smaller as you progress along the series.
Similarly with these.
What does a 3D shape look like? I don't think this is a well formed question.
eggy said:
How does it work?
How do 3D shapes work? I don't think this is a well formed question either.
It is certainly possible to produce solutions to the Einstein field equations with closed timelike curves. But there is no experimental indications that support the idea that such spacetimes represent reality in any way.
eggy said:
Undefined
Cannot be defined
None of this communicates anything that I can tell.
these were mostly just brain dumps i did in geometry class. I am a freshman in high school and was just asking for input (which you provided). I have virtually no knowledge of any theoretical physics, yet have a huge interest in it. Thank you for the input, is there any way you could include some links to things that i could use to grasp this idea?
