What is the magnitude and direction of vector C?
  • Thread starter Thread starter rasikan
    Magnitude Vector
The discussion revolves around vector calculations, specifically focusing on the magnitude and direction of vectors C and E, derived from given vectors A and B, as well as their relationships with angles in a coordinate system.
  • Participants discuss methods for calculating the magnitude of vectors, questioning which formulas to use and how to apply them. There is also an exploration of the relationship between vector components and their angles.
Some participants are verifying calculations and seeking clarification on the second question regarding vector E. There is an ongoing dialogue about the necessary information and methods to approach the problems, with no clear consensus yet.
Participants express uncertainty about the second question and the definitions related to vector components and angles. There is a mention of moving the thread to a different category, indicating a potential mismatch in the original context.
rasikan
I need help with the following questions-
1. if a= 12i+16j and b=-24+10j, what is the magnitude of the vector C=2a-b?
2.If the magnitude and direction of c are 2.5 cm and 80degree , and d[3.5cm,120degree] and e=d-2c then what is the direction of e, (to the nearest degree)?
1. What information can you use in order to find the magnitude of a vector?
you can use any formulas..
So which one would YOU pick? :smile:
I would use square root of (Ax)^2+ (Ay)^2
Indeed, smart choice!
So, what info are you at present lacking in order to calculate the magnitude?
And:
How can you OBTAIN that necessary information?
no i got my answer as 64, just want to verify that, and I dnt have no clue about the second question
Well, I don't bother to calculate myself all the way to 64 or to any other dumb number, I want to find out:
HOW did you are at whatever number you got?
can u help me with my second question
The degrees are measured with respect to the positive x-axis.
So:
How can that help you?
well i really don't know
Well, how har the horizontal&vertical components of a vector related to the vector's magnitude and the angle the vector makes with the positive x-axis?
i think it get calcuate arc tan of Ax/Ay
No!
Go back to your book, and read your definitions again.
Check it for some special cases...
What angle do you expect? and What do you get with your formula?
- for a vector along the x-axis.
- for a vector along the y-axis.
Moved from Advanced Physics to Intro Physics.
  • · Replies 18 ·
