What is the moment of inertia for a circular lamina with constant density?
  • Thread starter Thread starter Chris L T521
The moment of inertia for a circular lamina with constant density is defined by its resistance to changes in rotational motion about an axis. For a lamina occupying the region described by the inequalities \(0 \leq x^2 + y^2 \leq a^2\), the moments of inertia about the x-axis and y-axis are equal, given by \(I_x = I_y = \frac{\delta \pi a^4}{4}\), while the moment of inertia about the z-axis is \(I_z = \frac{\delta \pi a^4}{2}\). This conclusion was confirmed through the contributions of forum members Ackbach and Sudharaka.
  • Understanding of moment of inertia concepts
  • Familiarity with double integrals in calculus
  • Knowledge of density functions in physics
  • Basic principles of rotational motion
  • Study the derivation of moment of inertia for different shapes
  • Learn about polar coordinates and their application in double integrals
  • Explore applications of moment of inertia in engineering and physics
  • Investigate the effects of varying density on moment of inertia calculations
Students and professionals in physics, engineering, and mathematics who are interested in rotational dynamics and the calculation of moment of inertia for various geometries.
Chris L T521
MHB
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Background Info: The tendency of a lamina to resist a change in rotational motion about an axis is measured by its moment of inertia about that axis. If a lamina occupies a region $R$ of the $xy$-plane, and if its density function $\delta(x,y)$ is continuous on $R$, then the moments of inertia about the $x$-axis, $y$-axis, and $z$-axis are denoted by $I_x$, $I_y$, and $I_z$ respectively, and are defined by
\[I_x= \iint\limits_R y^2\delta(x,y)\,dA,\qquad I_y = \iint\limits_R x^2\delta(x,y)\,dA\]
\[I_z= \iint\limits_R (x^2+y^2)\delta(x,y)\,dA\]
Problem: Consider the circular lamina that occupies the region described by the inequalities $0\leq x^2+y^2\leq a^2$. Assuming that the lamina has constant density $\delta$, show that
\[I_x=I_y=\frac{\delta\pi a^4}{4},\qquad I_z=\frac{\delta\pi a^4}{2}.\]
This week's problem was correctly answered by Ackbach and Sudharaka. You can find Sudharaka's solution below.
Let \(x=r\cos\theta\) and \(y=r\sin\theta\) where \(r\geq 0\) and \(0\leq\theta<2\pi\). Then,
\begin{eqnarray}
I_x &=& \delta\int^{2\pi}_{\theta=0} \int^{a}_{r=0}(r^2 \sin^{2} \theta) r \,dr\,d\theta\\
&=&\frac{\delta a^4}{4}\int_{0}^{2\pi}\sin^{2}\theta\,d\theta\\
&=&\frac{\delta\pi a^4}{4}
\end{eqnarray}
Similarly,
\begin{eqnarray}
I_y &=& \delta\int^{2\pi}_{\theta=0} \int^{a}_{r=0}(r^2 \cos^{2}\theta) r \,dr\,d\theta\\
&=&\frac{\delta a^4}{4}\int_{0}^{2\pi}\cos^{2}\theta\,d\theta\\
\end{eqnarray}
\begin{eqnarray}
I_z &=& \delta\int^{2\pi}_{\theta=0} \int^{a}_{r=0}(r^2\sin^{2}\theta+r^2 \cos^{2}\theta) r \,dr\,d\theta\\
&=& \delta\int^{2\pi}_{\theta=0} \int^{a}_{r=0}r^3 \,dr\,d\theta\\
&=&\frac{\delta a^4}{4}\int_{0}^{2\pi}\,d\theta\\
&=&\frac{\delta\pi a^4}{2}
\end{eqnarray}
