|Glitch|
- 428
- 117
For the last 88 years we have used Subrahmanyan Chandrasekhar's calculations to determine the maximum mass of a white dwarf. As a result of that calculated mass limit, a peak brightness was derived and the Standard Candle was born. However, those calculations were made based upon certain assumptions, namely that the white dwarf was not rotating and had no magnetic field. More recent discoveries have demonstrated that those assumptions made in 1930 may not be valid in some cases.
In the last 15 years we have discovered both sub- and super-Chandrasekhar Type Ia SNe, each with varying absolute magnitudes. In the case of the sub-Chandrasekhar Type Ia SNe, they were classified as Type Iax SNe in March 2013 with an absolute magnitude range between -14.2 < MB < -18.9, and none of them are suspected of exceeding the 1.4 M☉ established by Chandrasekhar.1 In the case of super-Chandrasekhar Type Ia SNe (specifically, SNLS-03D3bb, SN 2003fg, SN 2006gz, SN 2007if, and SN2009d) they all showed an exceptionally large mass of 56Ni in their ejecta.2 Larger than should be possible for a 1.4 M☉ white dwarf progenitor. The white dwarf mass prior to SN 2007if's deflagration, for example, was estimated to be 2.4 M☉ based upon the amount of 56Ni detected in its ejecta.3
In 2013 it was suggested that these super-Chandrasekhar Type Ia SNe were the result of highly magnetic white dwarfs. Upasana Das and Banibrata Mukhopadhyay, from the Indian Institute of Science, proposed a new white dwarf maximum limit of 2.58 M☉.4 However, these suggested white dwarfs progenitors were also assumed to be not rotating. In 2015 Mukhopadhyay corrected this oversight and calculated the mass range for various rotational periods and various intensities of magnetic field. Mukhopadhyay now proposes a white dwarf maximum limit range between 2.3 and 2.8 M☉.5 The idea behind these papers was that both a very strong magnetic field and/or rapidly rotating white dwarf would be able to counteract the inward pull of gravity to a certain degree, allowing the white dwarf to accumulate additional mass before deflagration.
If rapidly rotating and/or highly magnetic white dwarfs can exceed the Chandrasekhar Limit of 1.4 M☉, then it would have a significant effect on our prior assumptions. Magnetars, for example, could be highly magnetic white dwarfs, and not neutron stars as currently believed. A 2.8 M☉ white dwarf would also be more massive than the most massive neutron star yet observed.
One of the first casualties of these new discoveries of both sub- and super-Chandrasekhar Type Ia SNe has to be what we have assumed was a “Standard Candle.” This would also call into question the ΛCDM model considering that it is based upon the observations of 30 Type Ia SNe at z = 0.5 and 10 Type Ia SNe at z = 1 made prior to 2003.6 At the very least we need to be certain that the data for Type Ia SNe collected prior to 2013 is sufficient to rule out any possibility of sub- or super-Chandrasekhar Type Ia SNe before assuming it has a fixed absolute magnitude.
Sources:http://iopscience.iop.org/article/10.1088/0004-637X/767/1/57/meta
- Type Iax Supernovae: A New Class of Stellar Explosion - The Astrophysical Journal, Volume 767, Number 1, March 2013 (free issue)
- The Type Ia Supernova SNLS-03D3bb from a Super-Chandrasekhar-Mass White Dwarf Star - Lawrence Berkeley National Laboratory, April 2008 (open access)http://iopscience.iop.org/article/10.1088/0004-637X/713/2/1073/meta
- Nearby Supernova Factory Observation of SN 2007if: First Total Mass Measurement of a Super-Chandrasekhar-Mass Progenitor - The Astrophysical Journal, Volume 713, Number 2, March 2010 (free issue)http://www.worldscientific.com/doi/abs/10.1142/S0218271813420042
- New Mass Limit of White Dwarfs - International Journal of Modern Physics D, Volume 22, Issue 12, October 2013 (free preprint)https://arxiv.org/abs/1509.09008
- Over-Luminous Type Ia Supernovae - arXiv : 1509.09008, September 2015http://iopscience.iop.org/article/10.1086/306308/meta
- The High-Z Supernova Search: Measuring Cosmic Deceleration and Global Curvature of the Universe Using Type Ia Supernovae - The Astrophysical Journal, Volume 507, Number 1, 1998 (free preprint)
