The discussion revolves around determining the probability density function (PDF) of the random variable z, defined as z = x - y, where both x and y are non-negative random variables. Participants explore the mathematical formulation of this PDF, particularly focusing on the convolution of distributions and the appropriate integration bounds for the integral representation.
- Technical explanation
- Mathematical reasoning
- Debate/contested
- One participant seeks to express the PDF of z in integral form and questions the correct integration bounds, assuming x and y are independent and non-negative.
- Another participant suggests using the standard convolution PDF and provides a formula for the integral, but does not specify the bounds clearly.
- A later reply indicates that the integral should cover the whole real line but emphasizes that due to the non-negativity of x and y, the integration may only need to consider non-negative x.
- One participant references a slide that proposes a specific integral form for the PDF, questioning whether the upper bound should be z or infinity.
- Another participant expresses confusion over the notation used in the posts, noting a potential mix-up between x and y, and comments on the upper limit of the integral, suggesting that while infinity is technically correct, the non-negativity of the random variables may render some parts of the integral unnecessary.
Participants do not reach a consensus on the correct integration bounds for the PDF of z. There are competing views on whether the upper bound should be z or infinity, and some confusion exists regarding the notation and definitions used in the discussion.
There are limitations regarding the assumptions made about the independence of x and y, as well as the implications of their non-negativity on the integration bounds. The discussion also reflects uncertainty in the notation and definitions of the variables involved.
