What is the reasoning behind the different forms of F in bolted joint equations?
  • Thread starter Thread starter minoroctave
    Joints Shear
The discussion revolves around the interpretation of the force F in equations related to bolted joints, specifically concerning how this force is distributed among bolts and how it affects bearing and shear stress calculations. Participants explore different formulations and assumptions in the context of mechanical engineering applications.
  • Some participants question whether the force F in the equations represents the total force or a fraction thereof, such as F/2 or F/4.
  • There is a proposal that the force F is shared over two bolts on each side, leading to an expectation of F/2 in the equations.
  • One participant suggests that each bolt receives F/4, which is used in the bearing stress equations.
  • Another participant asserts that each bolt takes F/2, contingent on understanding the definitions of variables t and d.
  • Clarifications are made regarding t as the thickness of the thinnest plate and d as the bolt's major diameter.
  • Participants discuss the shear force distribution, noting that each shear plane for a bolt experiences a force of F/4, with an area of πd²/4.
  • There is a debate about whether shear only exists at the defined shear planes or if it varies along the bolt's length.
  • One participant calculates shear stress based on the total cross-sectional area of all bolts, leading to confusion about the agreement with provided equations.
  • Another participant points out the potential for miscalculating by dividing by 4 twice in their reasoning.
  • Questions arise regarding the reasoning behind the bearing stress formulation, particularly the transition from F/4 to F/2 in the equations.
Participants express differing views on the distribution of force among bolts and the resulting calculations for shear and bearing stress. No consensus is reached, and multiple competing interpretations remain present throughout the discussion.
Participants reference specific definitions and relationships between variables, but some assumptions remain unclear. The discussion also highlights potential ambiguities in the equations and their derivations.
minoroctave
I am having trouble understanding the F used in these equations. Is it supposed to be the force F shown on the left, or is it F/2 or F/4?
It must surely be the F in the diagram. This is shared over two bolts each side, so I expect to see F/2 in the equations. And indeed that is what we do see.
So each bolt get F/4 and that's why the bearing stress equations are
##\frac{\frac{F}{4}}{\frac{t}{2} d} = \frac{F}{2td}##
I'm saying each bolt gets F/2, but I can't comment beyond that without knowing what t and d represent.
for the bearing stress equations, d is supposed to be the bolts major diameter and t is the thickness of the thinnest plate
Ok,then it is the same F as in the diagram. Each bolt takes half the load, F/2. To get the bearing stress, divide by the area, td.
To get the shear stress, you have to consider that there are two shear planes for each bolt, one at each side of the central plate (so distance t apart). Each of those has a shear force F/4, and an area πd2/4.
but according to the definition they gave, shouldn't t be the thickness of the thinnest plate. in the question, its also mentioned that:
"F/2 is transmitted by each of the splice plates, but since the areas of the splice plates are half those of the center bars, the stresses associated with the plates are the same. So for stresses associated with the plates, the force and areas used will be those of the center plate"
is the shear force a max of F/4 only at these shear planes?
Sorry, can't decipher the meaning of that.
How do you mean only in that question? At the shear planes as opposed to, where else?
as opposed to anywhere else between the bolt head and the nut
There is no other shear plane between those.
so shear only exists at the shear planes? doesn't it vary between the planes like this:
http://postimg.org/image/3z13rz8kj/
I'll get this right in a minute...
There are two shear planes at each bolt, but they are not adjacent to the head or nut. The shear planes are where the bolt passes from one plate to another.
for the shear equations, it says the area is supposed to be the total cross sectional area of all the bolts in the group. So since each of the shear planes has a shear force F/4, and an area πd2/4 and since there are four bolts,
so ## \frac{\frac{F}{4}}{4 ( \pi \frac{d^2}{4})} ## = ##\frac{F}{4 \pi d^2}##
but that doesn't agree with the equation in the image
You are dividing by 4 twice over.
You can think of it in many different ways:
- a total force of F spread over four (half) bolts with a total area of πd2
- a force of F/2 on each of two bolts, each with a shear plane area of πd2/2
- a force of F/4 on each of four shear planes, each with an area of πd2/4
All lead to the same answer.
thanks. also, for bearing stress in the members, what is the reason for it being ##\frac{F}{2dt}## ? In the solutions, I see ##\frac{\frac{F}{4}}{\frac{t}{2} d} = \frac{F}{2td}## , but don't know why
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 18 ·
