What is the role of Relativistic QM?
The discussion revolves around the role and interpretation of Relativistic Quantum Mechanics (RQM) in the context of Quantum Field Theory (QFT) and its historical significance. Participants explore the existence and interpretation of wave functions in relativistic regimes, the application of the Dirac and Klein-Gordon equations, and the implications of these theories for understanding particle behavior and measurements.
  • Some participants argue that RQM has limited contemporary utility and may primarily hold historical significance, particularly in relation to the Dirac equation.
  • Others assert that the wave function exists in RQM but lacks the conventional probabilistic interpretation in position space, suggesting it is valid in momentum space instead.
  • A participant highlights that the Dirac equation and Klein-Gordon equation are still relevant as they contribute to the framework of relativistic quantum field theory, albeit with different interpretations.
  • Concerns are raised about the interpretation of position measurements in RQM, with some arguing that the Newton-Wigner position operators do not apply as expected in relativistic contexts.
  • There is a contention regarding the necessity of particle creation (e.g., electron-positron pairs) during position measurements, with differing views on whether this is an inevitable outcome in relativistic quantum mechanics.
  • Some participants challenge the notion that RQM is rendered useless, arguing that it is essential for constructing multi-particle systems and understanding the behavior of quantum fields.
  • Discussions also touch on the implications of non-locality in position-space wave functions and the finite uncertainty in measurements due to relativistic effects.
Participants express a range of views, with no clear consensus on the utility and interpretation of RQM versus QFT. Disagreements persist regarding the nature of wave functions, the interpretation of measurements, and the relevance of historical perspectives in contemporary physics.
Limitations include unresolved assumptions about the applicability of certain operators in different frames of reference and the interpretation of measurements in relativistic contexts. The discussion reflects ongoing debates in the field without reaching definitive conclusions.
  • #31
vanhees71 said:
For non-interacting particles that may be right, but those you can't detect nor localize.
Are you saying that interaction changes particle observables/operators?
Then our definitions of "interaction" are quite different. In my view, relativistic interaction should be introduced in a theory by adding operators V and W to generators of the non-interacting representation of the Poincare group. It seems that S. Weinberg would agree with me. See eqs. (3.3.18) and (3.3.20) in his "The quantum theory of fields" vol. 1.
So, relativistic interaction of the Dirac-Weinberg type modifies only 4 total observables of the physical system. The remaining theory (particle observables, particle number operators, Fock space structure) remains the same as in the non-interacting case.
But I can also agree that Weinberg's approach to QFT is very different from usual textbooks, where interacting quantum fields are placed in the center, and it is not possible to derive particles, their positions, Fock space etc. from the fields in the interacting regime.
Eugene.
  • #32
I would like to see Weinberg's perspective directly applied to the non-relativistic case as much as possible, the closest general reference seems to be Ballentine.
  • #33
Ballentine takes from older sources, like Jordan's "linear operators in QM" or Jauch's "foundation of QM".
Btw, the same treatment can be given to classical systems, where it also happens that in the relativistic case the position operator behaves like a Newton-Wigner operator.
https://arxiv.org/abs/2105.13882
https://arxiv.org/abs/2004.08661
  • #34
Eugene.
No, because "particle observables" refer to asymptotic free states. For transient states, there is no viable particle interpretation.
What I meant is that Landau&Lifshitz is right (BTW I don't like vol. IV of LL too much, because there are much more up-to-date books for QED, but this introductory chapter is well worth studying carefully). If you want to localize particles you need some interactions to do so. E.g., you can use a trap (Penning or Paul traps are examples), but if you try to squeeze a particle on a spot smaller than its Compton wavelength, ##h/(m c)##, you rather create new particles than to localize the original particle better. The extreme are massless "particles" like photons, which cannot be localized at all, because there's no energy necessary to create new ones when trying to localize them. Despite this argument, even free massless particles with spins ##\geq 1## do not even admit a position operator.
Weinberg's approach to QFT is just the standard approach to its presentation for the 21st century. It gets rid of all the dust of the difficult (and still not finished) development of the theory since 1925 and gives a clear exposition of the foundations as far as they are understood today. Particularly there is no viable first-quantization approach beyond approximations for situations close to the non-relativistic limit. The clear analysis of Wigner's ground-breaking analysis of the representation theory of the proper orthochronous Poincare group (of 1939!) is the key for a real understanding of the theory. Together with the microcausality/locality concept it delivers the fundamental properties of the theory:
-necessity of antiparticles
-spin-statistics relation (half-integer spin fields must be quantized as fermions; integer-spin fields must be quantized as bosons)
-non-conservation of particle numbers (but rather charges) -> Creation and annihilation processes need a many-body description, and the most convenient one is QFT
-particle interpretation only for (asymptotic) free states
  • #35
dextercioby said:
@throw Well, there are very well founded theories of a quantization of time in non-relativistic QM, but for some unknown reason they are not reaching (advanced) textbook-level, hence most people are unaware of them and keep dwelling on the same arguments for ages. This is also because of the immense success of QFT to which no obvious generalization (such as a time operator on equal footing with the Hamiltonian) of QM was felt needed (well, up to known theoretical/mathematical problems).
Can you give an example for a (review/introductory) paper about how "time is quantized"? The old argument by Pauli is very convincing, and I don't see what's wrong with it, no matter whether you consider non-relativistic or relativistic QT.
  • #36
In the non-relativistic case, time-energy uncertainty involves energy measurements at two different times, it's hard to believe this is from some operator relation since the whole reason for NRQM in the first place is the inability of simultaneously (i.e. at the same time) prescribing values of complementary variables; successive measurements of the same quantity (thus at different times, note we're also talking about exact values for the energy at these times as L&L set it up) is just completely different.
The RQM case means either generalizing this to include time-energy as part of complementary space-time momentum-energy measurements... It simply starts to look like nothing makes any sense until we give up something else - in this case it is the very idea of space-time energy-momentum complementarity that is challenged in the RQM context (see the position vs momentum space wave function comment earlier, or the discussion around the earlier-cited passage, for example).
This has interesting comments on 'Pauli's theorem' even in a non-relativistic context, it seems very hard to believe something can be an operator some of the time but not all of the time in a NRQM context depending on the spectrum which seems to be the argument, and this seems to be the road one has to go down to try to force a time operator.
But regarding the relativistic case - the particle action is gauge invariant, so the Hamiltonian is not even fixed until one fixes a gauge (parametrization), and it possesses primary constraints so it should be treated as a constrained system which also incorporates the massless case. The Schrödinger equation associated to this properly formulated version (in which the gauge choice does not ruin space-time covariance) is not even the naive 3D Schrödinger equation either, for example section 3 here: this appears to be the proper context in which Pauli's theorem should be applied regarding the choice of Hamiltonian and a potentially 'proper time' operator being associated to it, note it regards not 'time' but now a 'proper time' operator.
Thus, in this covariant case, (in which it should again be stressed that the Hamiltonian is determined by the choice of gauge usually taken to keep things covariant) operator commutation relations like ##[X^{\mu},P_{\nu}] = i \delta^{\mu}_{\nu}## are simply unaffected by Pauli's argument about discrete spectra of the Hamiltonian, which would really relate to whether it is possible to establish a proper time operator associated to a covariant-gauge-chosen Hamiltonian.
In a specific gauge in which proper time is taken to be the usual time (section two of the above notes for example), non-locality immediately arises - we now get a non-local Schrödinger equation, the square of which as usual leads to 'negative energy' eigenvalues which then require a direct argument - at best one has to artificially throw away the negative energy eigenvalues and replace them with positive energy eigenvalues for a separate species of plane wave associated to what we call anti-particles, or else talk about going backward in time, to keep those energy eigenvalues positive, and so the meaning of position space is just destroyed as usual making time operators even less relevant, it's unavoidable.
  • #37
The counterexample is of course invalid, because the there discussed Hamiltonian
$$\hat{H}=\frac{1}{2m} \hat{P}^2 -q E \hat{Q},$$
where I made deliberately the dimension of the potential right (##q## electric charge of the particle, ##E=\text{const}## electric field). Of course here ##[\hat{H},\hat{P}]=\text{const}##, but this Hamiltonian is indeed not bounded from below, i.e., there's no stable ground state. Of course a homogeneous electric field everywhere is fictitious and thus this is a idealized approximate Hamiltonian not describing a real-world situation.
The energy-time uncertainty relation is of a different kind than the uncertainty relations between observables. To measure time you have to measure an observable, e.g., the hyperfine transition of Cs which defines the SI unit of time, the second. To get this transition, i.e., the difference of the two energy levels, accurately you need to measure for a long time.
Another argument is that for a measurement of time you have to measure some observable ##\hat{A}##. Then the uncertainty relation of this observable with the Hamiltonian/energy is
$$\Delta A \Delta E \geq \frac{1}{2} |\langle [\hat{A},\hat{H}] \rangle|=\frac{\hbar}{2}|\langle \dot{A} \rangle|,$$
where ##\dot{A}## is the operator representing the time derivative of the observable ##A##. Then
$$\Delta E \geq \hbar \frac{|\langle \dot{A} \rangle|}{2 \Delta A} = \frac{\hbar}{2 \Delta t},$$
where ##\Delta t## is an estimator for the time it takes for the observable ##A## to change by an amount of its standard deviation ##\Delta A##, i.e., where a change can be expected to be significantly detected. Again it tells you that to determine the energy of a system you need a sufficiently long time for measuring it.
  • #38
throw said:
In these notes they promote time (not proper time) to an operator and arrive e.g. at the Klein-Gordon equation which tells us point particle wave functions are independent of proper time.
There is no problem of making time an operator in that sense, in a Lorentz covariant way. But this operator is not an operator on a Hilbert space. It is an operator on the space of functions of spacetime position ##x=(x^0,x^1,x^2,x^3)##, but those functions are not square integrable. That's because solutions of the Klein-Gordon equation cannot be localized in spacetime; they can be localized in 3-space, but not in time.
  • #39
Are you implying that the fact that continuous spectrum eigenfunction solutions of a Schrödinger equation are not square integrable, and so technically not in a Hilbert space (an issue that does not stop books like L&L), somehow let's us rationalize the existence of a time operator in a relativistic context, but not in a non-relativistic context? I'm not sure I could agree with anything like that.
  • #40
No. I am saying that the scalar product (both relativistic and non-relativistic) between two wave functions involves a 3-dimensional integration over space, and not a 4-dimensional integral over spacetime. This means that the Hilbert space is a Hilbert space of functions of space only, not of space and time. For reasonable wave packets, this 3-dimensional integral is finite. But there are no wave packets for which the 4-dimensional integral would be finite. Just the opposite, the scalar product, namely the 3-dimensional integral, is conserved in time, it is a constant. If one would then integrate the constant over the infinite time interval, one would get infinity.
  • #41
One should, however, also pose the caveat that a "wave function" (or the so-called "first-quantization formalism") has a very different and pretty limited sense in the relativistic case compared to the non-relativistic case. The only successful fully consistent description of relativistic QT for (interacting) particles is local relativistic QFT, providing the only consistent framework to formulate the Standard Model of high-energy particles physics, which still as one of the most successful theories ever discovered.
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 61 ·
  • · Replies 78 ·
9K
