What is the Tangent Space to the Unitary Group?
The discussion revolves around finding the tangent space to the unitary group U(n), particularly focusing on the expression for T_X U(n) for an arbitrary element X in U(n). Participants explore various methods to derive the tangent space, including the use of differential geometry and properties of Lie groups.
  • One participant proposes defining a function F(X) = X^\dagger X - I to express U(n) as F^{-1}(0) and suggests that the tangent space can be computed as T_X U(n) = DF^{-1}(0)[X] = {Z ∈ M_n(ℂ) : X^\dagger Z + Z^\dagger X = 0}.
  • Another participant describes a method to find the tangent space at the identity by considering paths through it and taking derivatives, concluding that the tangent space consists of anti-Hermitian matrices.
  • Some participants discuss the relationship between the tangent space at the identity and the tangent spaces at other points in U(n), suggesting that they are isomorphic.
  • There is a question about whether the tangent space at an arbitrary A in U(n) remains the set of anti-Hermitian matrices, with some expressing uncertainty about the generalization beyond the identity.
  • One participant notes that the exponential map is not generally surjective from the Lie algebra to the identity component of the group, while another counters that it is surjective for unitary groups due to their compactness.
Participants generally agree on the method to find the tangent space at the identity and that it consists of anti-Hermitian matrices. However, there is uncertainty regarding the generalization of this result to arbitrary elements in U(n), and the discussion remains unresolved on this point.
The discussion highlights limitations in the understanding of the relationship between tangent spaces at different points in U(n) and the implications of the exponential map's surjectivity.
Kreizhn
This may seem like an easy question, but my differential geometry is a little rusty. I'm trying to find the tangent space to the Lie group U(n); that is, for an arbitrary X \in U(n) I'm trying to find an expression for T_X U(n).
I can't quite remember how to do this. I've been playing around with the idea that if we define a function
where \dagger is the conjugate transpose, then U(n) = F^{-1}(0). I think F: M_n(\mathbb C) \to Sp(n) where the domain is nxn matrices and the codomain is the symplectic group, though I don't think this is too important.
So if U(n) = F^{-1}(0), can I compute the tangent space as
T_X U(n) = DF^{-1}(0)[X] = \left\{ Z \in M_n(\mathbb C) : X^\dagger Z + Z^\dagger X = 0 \right\}
This feels like it would be a suitable candidate, since if X is the identity matrix, this reduces to
T_I U(n) = \left\{ Z \in M_n(\mathbb C) : Z + Z^\dagger = 0 \right\} = \fraktur{u}(n) [/itex]<br /> the corresponding Lie Algebra of traceless skew-Hermitian matrices.
Does somebody know if this is correct?
Usually the way it's usually derived is to first find the tangent space at the identity, which is the important one anyways since that is the Lie algebra. From that, you can use either the left or right action of the group to find a 1-1 isomorphism between the Lie algebra and all other tangent spaces of the manifold.
The easiest way to find the tangent space at the identity is to look for paths through it, and then taking the derivatives of these paths to find the tangent vectors.
For example, if A(t) is a particular path in manifold (i.e. it is a unitary matrix for all t) and A(0)=I, then the tangent space is the set of all matrices A'(0) such that the above is the case.
In particular we know that ##A(t)A^{\dagger}(t)=I##. Taking the derivative of both sides at t=0 gives us the condition that ##A'(0)A^{\dagger}(0)+A(0)A'^{\dagger}(0)=0##. Since we know that ##A(0)=I## and therefore ##A^{\dagger}(0)=I## we conclude that the tangent at the identity of a unitary group is the set of all matrices B such that ##B+B^{\dagger}=0## which is exactly the set of all anti-Hermitian matrices (which we know to be the tangent space of the unitary group).
I'm not sure if this is what you wanted. But I can't follow your derivation as I am unfamiliar with such formal mathematical notation. Sorry.
EDIT: I just realized this thread is 4 years old...so...
The thread is old, But I'm interested :)
Thanks for your post Matterwave, now I understand how one obtain that the lie algebra of the unitary group are antihermitian matrix.
what about the tanget space for general A?
Repeting your procedure the answer seems to agree with the one in the original post.
Well, we obtained the tangent space. I probably should have been clearer in my terminology. To get the Lie algebra requires us to to further show that matrix commutation is the correct Lie bracket (e.g. that it satisfies the Jacobi identity among others).
For a general matrix group, you can do this same exact procedure, with the Lie algebra being specified by the matrix commutator (which I won't prove here). For example, using this procedure, you will also find that the tangent space to the orthogonal matrices are the anti-symmetric matrices.
If A is a more abstract Lie group, e.g. an extraordinary Lie group, then I'm not sure how one would apply this construction. But of course abstractly speaking, if A(t) is any path through the identity such that A(0)=e (e=identity element), then A'(0) will be a member of the Lie algebra. But without the useful matrix commutator acting as your Lie bracket, you will have to start working with isomorphisms induced by the right action (or the left action) and taking the actual Lie bracket on the manifold as the Lie bracket...
Thanks.
Sorry for being annoying, But what about the tanget space of a general at a A that belongs to U(n)?
I'm not sure what your question is, we have proved earlier that the tangent space to U(n) is the set of all n-dimensional Anti-hermitian matrices.
I'm seeing the prove for the identity. You showed the equation
and then at the identity
##A(0)+A^{\dagger}(0)=0##
Do we get the same result for other ##A≠I##?
A=I only at t=0. A(t) is not generally equal to the identity.
Also, I proved the equality ##A'(0)+A'^{\dagger}(0)=0##. Notice the primes on them. These are the derivatives, and not the A's themselves.
Although I'm still not understanding your question...
Sorry, I'm not native speaker.
What I want to know is if tanget space to an arbitrary ##A## that belongs to SU(n) (not just at the identity) is still the set of antihermitian matrices?
I'm inclined to say yes, but I want to be sure.
Oh, in that case you will get something like this:
$$A(P)A'^\dagger (P)+A^\dagger(P)A'(P)=0$$
Now, this condition actually depends on what ##A(P)## is, and I am not seeing any way of reducing this to a form easily recognizable as showing A' is an anti-hermitian matrix.
However, the tangent spaces on a particular manifold are certainly isomorphic to each other, so at least the tangent space at P must be isomorphic to the set of all anti-hermitian matrices of dimension n.
Thanks.
I think that if I write $$A(t)=Exp[tH]$$, with $$A(P)=Exp[PH]$$ then I can get $$H=-H^\dagger$$
If we care only about the connected component of the identity (which are those points which can be reached by the exponential map) then we can have ##A(t)=\exp(tH)## indeed. However, recall that ##H## is an element of the tangent space at the identity. This means that ##H=-H^\dagger## as we already showed in my previous posts. The element we care about now is ##A'(P)## which given this map is now simply ##A'(P)=H\exp(tH)|_P##. Now ##\exp(tH)|_P## is some unitary matrix (it is in fact ##A(P)##), so then ##A'(P)## is the original member of the Lie algebra (at the identity) rotated by some unitary matrix ##A(P)##:
$$A'(P)=A(P)H=A(P)A'(0)$$
I'm sure that this is related to the induced isomorphism by the right action of the group, but I'm not seeing a concrete say to develop that notion at the moment.
I don't know if that's whay you meant by
But the exponential map is not in general surjective form the Lie algebra of the group to the identity component of the group.
It is surjective for the Unitary groups since they are compact.
It seems that is the case. So far the Only explicit reference I have found is in Wulf Rossman "lie Groups: And introduction through Linear groups", pag 46. Not sure if it is true for more general Lie groups.
Thanks for your help.
You should use the level set theorem.
  • · Replies 21 ·
  • · Replies 0 ·
  • · Replies 17 ·
