What Is the Temperature Coefficient of a Car Battery Resistor at 0 Degrees?
The discussion centers on calculating the temperature coefficient of a car battery resistor at 0 degrees Celsius, given a voltage drop from 12V to 7.2V while drawing 150 amps. The internal resistance of the battery, denoted as R_i, is calculated as 4.8 V / 150 A, and the outer resistor, R_o, is calculated as 7.2 V / 150 A. To determine the temperature coefficient, a reference resistance at room temperature is necessary, which was not provided in the initial query. The original poster eventually solved the problem independently.
  • Understanding of Ohm's Law
  • Familiarity with electrical resistance concepts
  • Knowledge of temperature coefficients in resistors
  • Basic algebra for calculating resistance values
  • Research the concept of temperature coefficients in resistors
  • Learn how to calculate internal and external resistance in battery systems
  • Explore the effects of temperature on battery performance
  • Study Ohm's Law and its applications in real-world scenarios
Electrical engineers, automotive technicians, and anyone interested in understanding battery performance and resistance calculations in cold temperatures.
Mango12
Starting a car: the voltage drops from 12V to 7.2 V, it is 0 degrees out, and 150 amps are pulled from the car. What is the temperature coefficient of the resistor?
I have NO idea how to do this. Help please!
Mathematics news on Phys.org
Hi Mango! ;)
We'll need more information.
From the information you provided, we can only tell that:
$$R_o = \frac{7.2 \text{ V}}{150\text{ A}} \\
R_i = \frac{4.8 \text{ V}}{150\text{ A}}
where $R_i$ is the internal resistance of the battery, and $R_o$ is the outer resistor.
We would need for instance a reference resistance at room temperature of the battery to say anything about temperature coefficient.
Is any such given? (Wondering)
I like Serena said:
Hi Mango! ;)
Hey there! Thanks for replying, but I solved this problem on my own before I saw your post.
9K
  • · Replies 31 ·
  • · Replies 28 ·
