What is the value of these angles ?
  • Thread starter Thread starter yoxter
    Angles Value
The discussion revolves around determining the angles formed by normal forces exerted by semi-cylinders on a bar, specifically in relation to horizontal lines. The original poster expresses confusion regarding the angles in two different figures and seeks clarification on the teacher's explanation.
  • Participants explore the relationship between the normal force and the horizontal direction, questioning the definitions and measurements of angles in the provided figures. Some suggest examining the geometry of the figures to clarify the angle relationships.
The discussion is ongoing, with participants providing insights and suggestions for analyzing the figures. There is a recognition of the need for clearer definitions of angles and directions, but no explicit consensus has been reached regarding the correct interpretation of the angles.
The original poster mentions an impending exam, indicating a time constraint that may affect their ability to seek further clarification from their teacher.
yoxter
i know that question is a little basic but i have no one to ask.
for this image i think that the angle between the horizontal and the normal force that the semi-cylinder
exert on the bar is is α - 90°
Original Image
for this one i think that the angle between the horizontal and the normal forces that the cylinders exert on the bar is O - 90°
but my teacher says that is O and i can't figure why.
some one can explaimed why ? thanks.
Original Image
An angle is measured between two directions. You can't say "the angle of the normal force that the semi-cylinder
exert on the bar" and expect people to know what you're talking about because you only provided one direction - namely, the direction of the normal force. Are you measuring the angle between that force and the horizontal direction? If that's the case than the answer to the first picture that the angle is equal to α. Why can't you ask that question to your teacher?
thanks.
i've edited the post as you say, i can't ask to my teacher because my exam is the next class.
There is no difference between the 2 figures in regard to the angle that the normal force makes with the horizontal. The angles of a triangle sum to 180 Degrees and angles on one side of a straight line also sum to 180 degrees. In your first figure, Try extending the horizontal line through D to your dashed line and examine the triangle so formed to see if that helps to determine the required angle of the normal force, using the 180 degree sum rules noted.
Thanks
I did as you said and the first figure the angle is α and in the the second the angle is o
it is a little more clear to me now.
OK and a belated welcome to PF!
