What is the velocity of a car accelerating at a non-constant rate?
The problem involves a car accelerating at a non-constant rate, described by the acceleration function a(s) = k·s^n, where k and n are given constants. The original poster seeks to find the car's velocity at a specific distance of s = 1.3 m, starting from rest.
  • Participants discuss the need to integrate the acceleration to find velocity but express uncertainty about the integration process and the relationship between variables. Questions arise regarding the meaning of 's' and how to calculate time for integration.
Some participants have offered insights into the integration process and the relationships between acceleration, velocity, and displacement. There is ongoing exploration of the implications of initial conditions and the functional form of acceleration. Multiple interpretations of the problem are being considered, particularly regarding the initial state of the car's motion.
There is ambiguity about the initial conditions, particularly whether the initial displacement is zero, which affects the interpretation of the acceleration function. Participants note the importance of correctly applying integration techniques and understanding the units involved.
albert12345
A car accelerates with a(s) = k·sn m/s2, from 0 m/s. What is the velocity of the car when s=1,3m?
k = 7,96 och n = 0,454
I know I have to intergrate in some way, but I really don't know how to start? I don't have the time?
What are you trying to find? Distance or velocity?
for velocity: [tex]v = v_{0} + \int_{t_{0}}^{t}a(t)dt[/tex]
for distance: [tex]x = x_{0} + \int_{t_{0}}^{t}v(t)dt[/tex] - using the velocity found above.
I am trying to find the velocity at s=1,3m
How do i calculate t, so i can solve your intergral?
Yes you should be able to use the integral, although I'm having a bit of trouble understanding the functional relationship of your acceleration. What is the dependent variable? I'm not sure what "s" is.
s is the distance travelled
Oh ok, well in that case you have to use a little trick:
[tex]a = \frac{dv}{dt}=\frac{dv}{dx}\frac{dx}{dt}=v\frac{dv}{dx}[/tex]
then the integral becomes:
[tex]\int vdv=\int adx[/tex]
Hopefully you can figure it out from there.
I'm sorry but I don't understand :(
Hmm...if a(s)=k*s*n and the car starts at s=0 with v=0, then the car will have an acceleration of 0 and will just stay stationary. Am I missing anything?
Im sorry!
I wrote the expression wrong, it should be:
A(s)=k*s^n m/s^2
No, this only means that v_0 = x_0 = 0. As long as the acceleration is nonzero, the particle will have nonconstant motion.
But let s = x and integrate a over x and you'll have your answer.
But the acceleration is a function of the displacement such that if the displacement is zero, then the acceleration is also zero. It also happens that the velocity is zero initially, so the displacement would never change from zero and hence the acceleration would also never change from zero. Although this is only if the initial displacement is zero, which the question never actually states (it never tells us initial displacement).
The answer should be 4,0m/s. I got 8m/s when I integrated 1 time. What did i do wrong?
What do you mean by 'integrated 1 time'? Integrating a(s) from s=0 to s=1.3 is not going to give a velocity, the units will be [itex]\frac{m}{s^2}*m = \frac{m^2}{s^2}[/itex], while velocity has units of [itex]\frac{m}{s}[/itex].
I'm not actually sure what grindfreak means when he says [itex]\int vdv=\int adx[/itex] then "integrate a over x and you'll have your answer", which seems to be implying that [itex]\int vdv=\int vdt[/itex], which is not correct as far as I know.
But his application of the chain rule does give something useful:
[itex]a =\frac{dv}{ds}\frac{ds}{dt}=v\frac{dv}{ds}[/itex]
If you'll recall, the question tells us what a is in terms of s:
[itex]a = k*s^n[/itex]
So:
[itex]v\frac{dv}{ds}=k*s^n[/itex]
Which is a first order non-linear ordinary differential equation for v(s) from which we can obtain our desired answer v(s=1.3), which leads me to believe that there must be some other way to do this question because I only started learning that kind of maths in a second year university maths unit. I know I'm not suppose to give you the answers, but you could have just put this straight into Wolfram Alpha anyway, like this, so I might as well just show what it spat out:
[tex]v(s)=\sqrt{\frac{2*(c*n+c+k*s^{n+1})}{n+1}}[/tex]
To find the constant c, remember that v(0)=0 from the information in the question.
Here's how it should integrate. Since the initial values for both velocity and displacement are 0, the right integral looks like:
[tex]\int_{0}^{s}ads^{'}=k\int_{0}^{s}(s^{'})^{n}ds^{'}=\frac{ks^{n+1}}{n+1}[/tex]
The right integral is:
[tex]\int_{0}^{v}v^{'}dv' = \frac{1}{2}v^{2}[/tex]
Now don't be confused about the primes, it's just used to discern between the limits and the variables you're integrating over (you'll see this quite a bit in more upper level courses).
Now, equating these two answers together you get:
[tex]\frac{ks^{n+1}}{n+1} = \frac{1}{2}v^{2}[/tex]
Now solve for v and plug in your numbers and you're done :D
*Just realized EmittingLight came up with the same conclusion.
