What Is the Velocity of Cyclist B and C Relative to the Road?
The velocities of cyclists B and C relative to the road are determined by their relative velocities to cyclist A and the chosen coordinate system. Cyclist A moves at -3.0 m/s (to the left), cyclist B has a relative velocity of +1.0 m/s with respect to A, resulting in a velocity of -2.0 m/s relative to the road. Cyclist C, with a relative velocity of -2.0 m/s with respect to A, moves at -5.0 m/s relative to the road. The key takeaway is to set the coordinate system correctly, where leftward velocities are negative.
  • Understanding of relative velocity concepts
  • Familiarity with coordinate systems in physics
  • Basic knowledge of vector addition
  • Ability to interpret velocity equations
  • Study the principles of relative velocity in physics
  • Learn about coordinate systems and their impact on motion analysis
  • Explore vector addition techniques in kinematics
  • Review examples of relative motion problems in physics textbooks
Students studying physics, particularly those focusing on kinematics and relative motion, as well as educators seeking to clarify concepts related to velocity and coordinate systems.
Peter G.
Hi,
I got the answer to this question wrong; I'll show what I did so you guys can help me spot my misconception:
A cyclist A moves with speed 3.0 m/s to the left (with respect to the road). A second cyclist B, moves on the same straight line path as A with a relative velocity of 1.0 m/s with respect to A.
a) What is the velocity of B with respect to the road?
b)A third cyclist has a relative velocity with respect to A of -2.0 m/s. What is the velocity of C with respect to the road?
My Answers:
a) OK, if the velocity of B relative to A is equal to 1 m/s, they are moving in the same direction, but B is moving faster by 1 m/s, hence, relative to the ground it should be moving at 4 m/s. But the answer is, according to the book, -2 m/s.
b) If C is at -2.0 m/s to A, then it is moving in the same direction as A once again, but, in this case, it must be moving slower because A is seeing it move in the opposite direction, backwards. Since it is at -2,0 m/s in relation to A, it must be at 1 m/s relative to the ground, but the answer according to the book is -5 m/s...
I am lost!
Thanks in advance,
Peter G.
If B is going in the opposite direction from A, then he's going -2m/s relative to the ground. Hard to do on a bike but easy in math.
If C is going in the opposite direction from A, then he's going -5m/s relative to the ground.
You need to ask your prof what the hell these guys are doing peddling backwards.:smile:
It would appear that they want you to set your coordinate system so that velocities to the left are negative. So cyclist A moving with speed 3.0 m/s to the left has a velocity of -3.0 m/s in that coordinate system. Cyclist B, with a relative velocity of 1.0 m/s w.r.t. A (a rightward difference) will still be moving to the left, only a bit slower that A.
In equation form:
Vb - Va = +1.0 m/s
Vb = +1.0 m/s + Va
Vb = +1.0 m/s + (-3.0 m/s) = -2.0 m/s
Similar reasoning should clear up part (b).
  • · Replies 16 ·
  • · Replies 16 ·
