What is the velocity of mass 2m after the collision?
The discussion revolves around a collision problem involving two masses, where mass 2m collides with mass m at rest. The problem seeks to determine the velocity and direction of mass 2m after the collision, as well as to assess whether the collision is perfectly elastic.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the conservation of momentum in both x and y directions, attempting to set up equations based on the given conditions. Some express confusion about simplifying the equations and the relationships between the variables involved.
Several participants are engaged in deriving expressions for the unknowns related to the velocities after the collision. There is a recognition of the need for simultaneous equations, and some participants are providing hints and corrections to each other's attempts. The discussion reflects a collaborative effort to clarify the setup and resolve the mathematical expressions.
Participants note the presence of multiple unknowns and the challenge of simplifying the equations. There is also mention of specific values for trigonometric functions, which may influence the calculations.
Xenon
Mass of 2m slides on a horizontal plane with the velocity of v0 across the x-axis. And hits the mass m which is in rest. after the collision mass m moves with the velocity of v0/2 in the direction which creates an angle of 30 degrees of the original movmen of 2m.
a) What is the velocity of mass 2m after the collision?
b) What is the direction of mass 2m after the collision?
c) Is the collision described is perfectly ellastic collision?
P=m*v
Pi=Pf
I have broken down the velocity to x,yPinitialx=Pfinalx
m1*V1ix+m2*V2ix=m1*V1fx+m2*v2fx
2m*v0+m*0 = 2m*Vfcosθ+m*v0/2*cos30Pintialy=Pfinaly
m1*V1iy+m2*V2iy=m1*V1fy+m2*v2fy
0 = -2m*Vfsinθ+m*V0/2sin30
I don't know what to do from here. i can't simplfy the equations,
could you help me with that?
Thank you,
You have 2 unknowns so you want to get two expressions that arise from conservation of momentum in both x and y directions. You will have two simultaneous equations which you can solve for the unknowns. I am not sure if you have already done that its hard to follow those expressions but once you get your two equations its relatively straight forward to solve by substitution. Remember that your answer will be in terms of m\ and \ v_0
I think you meant "V0/2*sin30" as in (V0/2)*sin30.
Hint: sinx/cosx = tanx
My problem is that i just can't simplfy it. could you show me what to do with the parameters? V0 and the θ angles.
Thank you for helping me.
Your figure has Vf as u. That's a bit handier.
What are the values of sin30° and cos30° ?
Solve 0 = -2m*u*sinθ+m*(u/2)sin30 for u. (EDIT: This is corrected below.)
Solve 0 = -2m*u*sinθ+m*(V0/2)sin30 for u.
Plug that result into the other equation:
2m*u+m*0 = 2m*u*cosθ+m*(u/2)*cos30
2m*u+m*0 = 2m*u*cosθ+m*(V0/2)*cos30
2m*V0+m*0 = 2m*u*cosθ+m*(V0/2)*cos30
Solve for cotθ (Lots of stuff cancels.)
U=-m*sin tetha-sin30/2 ?
Doesn't u cancel from this equation?
DUH! Yes it does!
Thanks for noticing.
I had a major typo there!
It's now been corrected. (I hope correctly!)
why does it cancels?
umm,
iam really confused why does it cancels?
we are left with u/2 don't we?
Shouldn't the first u in this equation be V0?
Yup !
This is what i got:
u=-m*sinθ+0.5v0*sin30
2m*V0+m*0 = 2m*u*cosθ+m*(V0/2)*cos30 solve for cotθ
cosθ=u+0.5v0*30
when plugging u into cosθ to solve for cotθ
cotθ=-m+0.5v0*sin30+0.5v0*cos30
What now?
Thank you for all of your help :)
Xenon said:
This is what i got:
cosθ=u+0.5v0*30
What now?
The mass, m, cancels out of both equations.
You did not solve for u correctly in the first equation.
Your result for the second equation is also far from correct.
Could you please show me how to do it correctly,
I tried to do it, bit by bit... and it still not right.
Thanks
Thanks
I'll get you started.
To solve 0 = -2m⋅u⋅sinθ+m⋅(V0/2)sin30 for u, subtract the first term from both sides. (Add its opposite.)
2m⋅u⋅sinθ = m⋅(V0/2)sin30
Then divide both sides by 2m⋅sinθ. Right? What do you get?
I got
u=05V0*sin30/2sinθ
Xenon said:
I got
u=05V0*sin30/2sinθ
Using the "reply" feature will help you make more readable posts. Then you can cut & paste more accurately. Also, to make a subscript, use the X2 icon on the green strip above the message box you use to form your message to post.
You should use parentheses around that denominator. The leading 05 is missing a decimal point. You might as well divide 0.5 by 2 .
u = (0.5)V0⋅sin30/(2⋅sinθ)
u = (0.25)V0⋅sin30/(sinθ)​
By the way, do you know the value of sin(30°) ?
So
u = (0.125)V0/(sinθ)
How is that looking?
Thank you very much, you have no idea how glad iam, that you are helping me.
  • · Replies 22 ·
  • · Replies 29 ·
11K
