What is the y-component of Fa in statics?
  • Thread starter Thread starter talmid100
    Statics
The discussion revolves around a statics problem where participants are trying to determine the length L1 in a system that is in balance. The original poster expresses uncertainty about how to start and what quantities need to sum to zero in a static equilibrium context.
  • Participants discuss the need to identify forces and moments in the system, questioning how to proceed with calculating the unknown force Fa and its components. There is also a focus on the relationships between the forces and distances involved.
The conversation is ongoing, with various participants offering insights and questioning assumptions. Some guidance has been provided regarding the calculation of forces and moments, but there is no explicit consensus on the correct approach or final answer yet.
Participants note the lack of specific information in the original question and the need to clarify the definitions and roles of the forces involved in the problem. There is an emphasis on the requirement that all forces must sum to zero for the system to be in static equilibrium.
talmid100
Member advised to use the formatting template for all homework help requests and to show some effort towards solving the problem
Hello
I need to find L1 length
but I don't know how to start
Member asked to report posts without template or effort rather than responding to them
welcome to physics forum
you mentioned in the question it is statics what are the quantities that have to sum to zero for statics
The question says the system in the picture is in balance find L1 length .
That's it no more info in the question
no i was asking you
you mentioned in the question it is statics what are the quantities that have to sum to zero for statics[/QUOTE
okay if something is balanced what needs to cancel out
Don't know
okay do you know about moments
I know that the formula says m=f*l
but how to proceed I'm not sure
Maybe. - fa*l + f2 *sin 65*3l
ok what is fa and what is f2 and why is there 3l
fa is force on point a (which I don't know)
F2 is 35 *sin 65 and 3l should be the distanceI'm totally lost here.
your method is correct but i think instead of 3l it should be 3 +L where l is what the question is asking
while this method is valid you don't know what fa is which you need to calculate separetely
what if you take moments about the point a
F2 (35 *(sin 65) * 3 (distance from point a to f2)
equal to 95.16 divide by f1 (20)
95.16/20 = 4.76 so L1 is 4.76 m
i think it is correct
do you know how to figure out fa and you might want to check your answer using that method
No I don't know how to figure fa
Use that the sum of all forces must equal zero in a static equilibrium.
I'm not sure if it's correct
Fx=0
Fa= F2(35)*cos (65) = 14.8
You calculated correctly (within a sign +- perhaps) the x-component of Fa. Now calculate the y-component of Fa.
