yashwanthippili
- 1
What is time and how can we describe time?
The discussion centers on the definition and understanding of time, emphasizing its role as the fourth dimension and a measure of duration. Participants highlight that time is not visible but can be measured through clocks, which generate ordered lists of events. The conversation also touches on the complexities of defining both time and clocks, with references to General Relativity (GR) and the ongoing debates about time's nature, particularly at the Big Bang. The consensus is that while our understanding of time is incomplete, significant knowledge exists regarding its properties and measurement.
PREREQUISITESPhysicists, philosophers, students of cosmology, and anyone interested in the fundamental nature of time and its measurement.
Except insofar as we can see, with our eyes, how "long" something is in both the space dimensions and time dimension...you just have to wait a while to observe something's duration.Nugatory said:We cannot see it, but we can measure it. There are lots of things (for example, weight and temperature) like that.
yashwanthippili said:how can we describe time
Drakkith said:Time is that which a clock measures.
How do you define "clock"?Drakkith said:Time is that which a clock measures.
That doesn't seem a good link to answer my question, because it says:Drakkith said:
I agree, but clocks need time to work, and time doesn't need a clock to exist. In other words, clocks are dependent on time, and time is independent of clocks. Therefore, the definition of a clock should stay the same, and it is time that we need to have a better definition for.lightarrow said:That doesn't seem a good link to answer my question, because it says:
"A clock is an instrument to indicate, keep, and co-ordinate time."
We can't answer to the question "what is time?" with the answer "it's what a clock measures" if a clock is what written up...
We need a better definition of "clock", a one which of course doesn't use the concept of time.
lightarrow
Why not? Try the similar question: what is length?lightarrow said:That doesn't seem a good link to answer my question, because it says:
Isaac0427 said:Just remember, in the technical world of physics things that you thought were basic, are very complicated. Honestly, I think what you and many others have asked about time doesn't fall in our knowlage right now. In fact, there are multiple theories I have seen describing time (or spacetime) that are still disputed.
For example, I have had an interesting convorsation on here about the Big Bang and what t (time)=0 meant. What I got from that was nobody knows what happened at t=0, and I don't think you can fully describe what something is if you can't fully describe what happened when it wasn't there.
Look at my other post called the beginning of time. I share how two very well-respected physicists (Stephen Hawking and Brian Greene) have written contradictory things about time.Drakkith said:I don't know of any accepted theories other than GR that describe time. My opinion is that we know a great deal about what time is, just as we know a great deal about what distance is.
Really? I thought t=0 gives is weird infinites in our math. Also, t=0 means that time actually started.Drakkith said:My understanding is that we choose t=0 to be at the big bang because it makes the math easier, not because time literally started at the big bang (which isn't what the big bang theory says). But I could be wrong.
Isaac0427 said:Look at my other post called the beginning of time. I share how two very well-respected physicists (Stephen Hawking and Brian Greene) have written contradictory things about time.
Isaac0427 said:Really? I thought t=0 gives is weird infinites in our math. Also, t=0 means that time actually started.
I don't believe that GR gives us a full understanding of time. It can't answer every question about time, and if it could, there would be no controversy on how time behaved at the Big Bang.Drakkith said:The ONLY accepted theory that deals with what time is and how it works is General Relativity unless you count the fact that we usually just use the plain old Newtonian idea of time in our everyday lives since it's MUCH easier than GR. The Newtonian concept of time being absolute and the same for all observers is, of course, known to be inaccurate/incomplete, which is where GR comes in.
To define "clock" we need something which allow us to distinguish it from other Instruments, or we could use a ruler to measure durations.russ_watters said:Why not? Try the similar question: what is length?
Isaac0427 said:I don't believe that GR gives us a full understanding of time. It can't answer every question about time, and if it could, there would be no controversy on how time behaved at the Big Bang.
I am, in no way, saying I understand all our knowlage of time. All I know is that our knowlage is incomplete. I mean, we don't even know if time had a beginning or not.ZapperZ said:What exactly are these "controversy" at the Big Bang?
Please note that there are many things that are not clearly determined and known at the Big Bang, not just time. One can easily argued that the different scenarios given have more to do with what we don't quite know well, rather than an issue with a parameter such as time and space.
Besides, do you think you are THAT well-equipped to actually say such a thing, considering that in another thread, you clearly indicated that you haven't fully understood even the classical idea of time (as in Lagrangian mechanics, etc.)?
As a side note, we are once again going off on our own here, considering that the OP appeared to have done a post-and-run. And considering the numerous threads on this topic already, are we really discussing anything new here?
Zz.
Isaac0427 said:I am, in no way, saying I understand all our knowlage of time. All I know is that our knowlage is incomplete. I mean, we don't even know if time had a beginning or not.
I am not saying we know nothing, I am justd saying that there is a lot about time we don't know.ZapperZ said:But that's a meaningless statement because ALL of our knowledge is incomplete and will NEVER be complete! That doesn't negate the fact that we do know quite a bit about what "time" is, so much so we actually can define it and know its properties. Just because we don't know if time has a beginning or not (whatever THAT means) does not mean we don't know what it is. We don't know why exactly the cuprate superconductors become superconducting, but that doesn't mean we know nothing about it, or that there are questions that they ARE superconductors!
You need to reexamine your logic.
Zz.
Isaac0427 said:I am not saying we know nothing, I am justd saying that there is a lot about time we don't know.
I was having a discussion on this thread with a mentor before you came in. If I were doing something wrong he would have told me. I have read all the guidelines on PF, and I was not breaking them.ZapperZ said:Thanks to you, this thread is in danger, like most of the previous thread on this topic, of being shut down.
Isaac0427 said:I was having a discussion on this thread with a mentor before you came in. If I were doing something wrong he would have told me. I have read all the guidelines on PF, and I was not breaking them.
seriously?lightarrow said:How do you define "clock"?
lightarrow said:We need a better definition of "clock", a one which of course doesn't use the concept of time.
I imagine that with silly posts like this, they will have easy room to terminate the thread.William White said:That's utterly absurd
Its like saying you need a better definition of a yard stick that doesn't use the concept of distance.
Putting clock in quote marks does not change its meaning. ("yard stick" is still a yard stick).
Maybe you could try your statement with your boss when you turn up for work 20 minutes late.
