What is Zero Action? What is zero action?
  • Thread starter Thread starter Sunfire
    Zero
Zero action refers to the concept that in unconstrained motion, the action is always zero, while in constrained motion, it is minimal but never zero. The principle of least action suggests that motion occurs under constraints to minimize the difference between capability and actual motion. Free fall is discussed as a constrained motion, where the action can be zero at specific points, such as halfway down. The significance of zero action lies in the minimization of action rather than its absolute value, which can vary based on potential energy adjustments. Overall, the discussion emphasizes understanding the implications of action in physical systems and the conditions under which it can be constant.
Sunfire
What is "zero action"
Hello All,
I have been reading this thread, trying to understand the concept of action. There is one very intriguing (to me) statement in that thread:
"So your action is the difference between your capability of motion and your actual motion.
The principle of least action says that there is no difference without some sort of constraint - in which case the motion will be such that this difference is as small as possible." /by Simon Bridge/
Do I understand this correctly - the action is always zero for unconstrained motion; and never zero (but minimal) for constrained motion. Is this reasoning true?
Is free fall a constrained motion? Because the action is zero only at y = y_initial / 2, y is the vertical position.
Perhaps someone has an idea...
Thank you, UltrafastPED; I read the chapter you suggested. Quite a few good points there. I am still having trouble to understand something, though. What is "zero action"? Does it have any significance?
In the chapter by Feinman, the free falling body moves downwards and its lagrangian changes from negative to positive. At some point (half the initial height), it becomes zero. Does this zero lagrangian have any physical significance?
The actual value of the action is not important, only that it is minimized. The value of the action can be made arbitrarily large or small simply by adding a constant offset to the potential.
Likes 1 person
This makes perfect sense.
What if, in a system,
Ep = f(x) - C, C is arbitrary constant
Ek = f(x)
for all x.
Then L = Ek - Ep = C for all x, thus the action remains constant. Does this ever happen?
In principle, it is possible, but I have never seen such a system. Usually the potential energy is a function of the generalized positions and the kinetic energy is a function of the generalized velocities, so I haven't seen a case where they are the same functions like that.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 140 ·
12K
