What Phase Difference Causes Maximum SHM Separation Equal to Amplitude?
5 replies · 14K views
manjuvenamma
Two particles are executing SHM with same amplitude and frequency (but with a phase difference). The maximum separation between them was found to be equal to the amplitude. What is the phase difference. This is a question that I came across.
And I solved it the following way.
Assume one is y1 = A sin (wt) and the other one y2 = A sin (wt + phi)
max(y1-y2) = A (given)
Solve for phi.
Since both y1 and y2 are sinusoids of w frequency, their difference will also be a sinusoid with a different amplitude but with same frequency and a different phase.
Since we are just interested in the max value of the difference, I calculated the amplitude of the sinusoid using phasors A e^j(phi) - A. It turned out to be 2A sin(phi/2). From that I calculated phi as pi/3 but the answer I have is as pi/2. I think the book is correct but I could not find the mistake in my calculation.
Can some one point out if I am wrong and if yes, where?
I think I am wrong because the difference between A sin(wt) and A sin (wt+pi/2) is A at t=0 itself. I think the difference between A sin(wt) and A sin (wt+pi/3) is never A ( which is what is required). I am not able to find a mistake in my method though. Can you tell at what 't' the the difference between A sin(wt) and A sin (wt+pi/3) is A? Thanks for your time and effort.
Hi manjuvenamma,
You can't find a specific time in seconds until you specify [itex]\omega[/itex], but here is one time that works:
[tex]t = \frac{1}{\omega} (2.61799\ \mbox{radians})[/tex]
(So if you just use [itex]\omega t=2.61799[/itex] radians as a whole into your functions you will get the right answer.)
You can find this by solving (after cancelling out the A's) for [itex]t[/itex]:
[tex] \sin(\omega t +\pi/3) -\sin(\omega t) = \pm 1[/tex]
Yes, at first glance it may seem so. When particle 1 is at x=0, and particle 2 is at x=A, then their separation is A. But the problem states that the maximum separation is A, which is not true here..
Let us analyze this situation stated above.
Case 1:
2 is at x=A, and 1 is going away from x=0 in the -ve direction. Since the speed of 2 at the extreme point is very small compared to 1, without any calculation we can say that their separation will be more than A for some time after this.
Case 2:
2 is at x=A, and 1 is going toward 2 from x=0, that is, in the +ve direction. We know that when 1 will reach the extreme position, 2 would have come to the mean position x=0. After that, the same argument as in case 1 applies.
As we see, in both of these cases, the maximum separation is more than A.
What you have written in the first post is correct, and the answer is pi/3.
Thanks so much, Shooting Star and alphysicist!
I am now convinced that I am right and I know the correct method too!
