What state has min angle between angular momentum & z-axis
The discussion focuses on determining which state, the electron spin or the atomic n=3 state, has a minimum angle between angular momentum and the z-axis. Participants clarify the calculations involving angular momentum, specifically addressing the use of quantum numbers l and ml. The professor's choice of l=2 for calculations is justified as it yields a smaller angle compared to l=1. Additionally, the concept of electron spin is compared to orbital angular momentum, emphasizing that both can be analyzed using similar equations. Ultimately, the discussion highlights the importance of understanding quantum numbers and their impact on angular momentum calculations.
accountkiller
1. Homework Statement [/b]
What state has a minimum value of the angle between the angular momentum and the z-axis; the electron spin or the atomic n=3 state? [with l not equal to 0]
L = \sqrt{l(l+1)}\hbar
Lz = m\hbar
S = \sqrt{s(s+1)}\hbar
Sz = ms\hbar
For the atominc n=3 state..
Since n = 3 (and l isn't 0), l = 1, 2 ... and ml = -l ... l = -2,-1,0,1,2
So then when you draw it.. (I don't seem to be able to get the picture in here]
The Lz vector is pointing up along the z-axis and the L vector is some degrees to the right of it.
The angle between the z-axis and angular momentum can be written using cosine...
cos(\theta) = \frac{L_{z}}{L}
I understand up to there.
But then the next part the professor did is add in numbers and I'm not sure where the numbers came from. He wrote this:
cos(\theta) = \frac{2\hbar}{\sqrt{6} \hbar} = \frac{2}{\sqrt{6}}
The \sqrt{6} comes from L = \sqrt{l(l+1)}\hbar using l = 2. But why l = 2 and not l = 1?
And I don't know where the 2 on top came from.
Then he wrote another one.. cos(\theta) = \frac{1/2}{\sqrt{3/4}}
I'm assuming this second one is for the electron spin since that is the one we are comparing it to? But.. how do you draw the vectors for electron spin? I'm confused there.
So, I'm confused on where the numbers came from and how you take electron spin into account here.
If anyone could help, I'd appreciate it!
Lz = m\hbar
Sz = ms\hbar
No reason. Try plugging in l=1, and you'll see that you get a larger angle. Your professor knew this in advance, of course, and I'm guessing he wanted to save time by jumping straight to the right answer.
What variable appears on top in the equation?
It's exactly the same as for orbital angular momentum. Literally the only difference is that there are certain values allowed for the spin angular momentum that wouldn't be allowed for orbital angular momentum (namely, the half-integer spins).
For what it's worth, you don't really need to do a drawing to solve this problem. You can work directly from the equations.
Ah, okay. Yes he does like to save time. Thanks for clearing that up.
Lz = ml\hbar
ml = -l ... 0 ... l , which for my l=1 gives me ml = -2,-1,0,1,2
So I'm just supposed to do trial and error to see which one would give me the smallest angle?
Oh, okay. I guess I need to review that a bit more.
How do I do that? I need to know to use the cosine from the drawing, don't I?
Thanks for your help! :)
mbradar2 said:
Lz = ml\hbar
Sure, you can do that. Once you try all the possibilities once, you should understand how you can immediately pick the correct m in the future.
Well, you said you understood where
\cos\theta = \frac{L_z}{L}
came from, right? What would be the equivalent for spin?
  • · Replies 0 ·
  • · Replies 21 ·
  • · Replies 21 ·
