What stress needs to be exerted to turn a quart of water into a pint?
  • Thread starter Thread starter jami8337
    Stress Water
The discussion centers on the physics of compressing a quart of water (946 ml) into a pint pot (473 ml) using a steel piston with a radius of 1 mm and a length of 10 m. The calculated stress required to achieve this compression is approximately 2.2 GPa, leading to a pressure of 1.1 x 109 Pa. The conversation highlights the impracticality of the scenario, noting that water is nearly incompressible and would require extreme pressure, far beyond the capabilities of conventional materials.
  • Understanding of basic physics principles, specifically stress and pressure.
  • Familiarity with the equations for stress (stress = F/A) and bulk modulus (B = -P/(dv/v)).
  • Knowledge of material properties, particularly the incompressibility of water.
  • Basic mathematical skills for calculations involving pressure and volume reduction.
  • Research the properties of water under pressure and its bulk modulus.
  • Explore advanced materials science, focusing on materials capable of withstanding extreme pressures.
  • Learn about hydraulic systems and the mechanics of pistons in fluid dynamics.
  • Investigate real-world applications of high-pressure physics in engineering and material science.
Students in physics or engineering, educators teaching fluid mechanics, and professionals in materials science or mechanical engineering who are interested in the principles of pressure and material limits.
jami8337
Dr Stewart’s Aunt Sally was constantly reminding him that he couldn’t squeeze a
quart (946 ml) into a pint pot (473 ml). Annoyed by this negative attitude, he set
about proving old Sally wrong. He constructed a platform, resting on a steel piston
radius 1 mm, length 10 m, bearing down on a chamber of equal radius, containing
1 quart of water. He then placed a number of 1000 kg elephants, procured from the
local zoo, on the platform.
B=-P/(dv/v)
stress = F/A
2.2Gpa(473/946)=P
=1.1*10^9
Not really sure what to do from here...
Hope that the zoo has a lot of elephants available. Water is very nearly incompressible. You are looking at a 50% reduction in volume which is going to require extreme pressure, very extreme pressure!
Do the math. Not even one elephant is needed. And these are small elephants.
That's assuming this piston or cylinder could exist. Both would have to be made of unobtanium.
