What to do with unused space in a home freezer?
  • Context: Undergrad
  • Thread starter Thread starter Richard Crane
    Home Space
The discussion revolves around optimizing the use of unused space in a home freezer, focusing on strategies to maintain temperature during power outages and improve operational efficiency. Participants explore various methods, including the use of water jugs, gel packs, insulation, and the implications of these choices on food safety and freezing efficiency.
  • One participant suggests filling a shelf with water jugs to utilize their latent heat of fusion during power outages, questioning the effectiveness and efficiency of this method.
  • Another proposes using salt water to lower the freezing point of the jugs, potentially enhancing their effectiveness.
  • A different viewpoint suggests creating a well-insulated inner space for food storage, arguing that existing freezers may not be optimally insulated.
  • Some participants recommend using freezer packs instead of jugs for convenience and ease of storage, highlighting their flexibility in use.
  • One participant shares a personal experience of a power outage, noting that their well-insulated freezer kept food frozen for several days, suggesting that additional measures may not be necessary in certain conditions.
  • Concerns are raised about the effectiveness of gel packs for deep freezing, with one participant noting that they are designed for around 0°C, which may not be suitable for freezer food safety.
  • Another participant discusses the potential benefits of adding insulation to the freezer but warns against lining the interior, as it could hinder freezing efficiency.
  • Some participants express interest in exploring additional insulation methods while considering the risks of slowing down the freezing process.
  • There are warnings about the importance of not covering the thermostat and ensuring proper air circulation within the freezer.
Participants express a range of views on the best methods for utilizing unused freezer space, with no clear consensus on the most effective approach. Some support the idea of additional insulation, while others caution against it, indicating ongoing debate and uncertainty regarding the best practices.
Participants mention various assumptions about insulation effectiveness, the impact of temperature on food safety, and the operational characteristics of freezers. Some discussions involve personal experiences that may not generalize to all situations.
Richard Crane
Our home food freezer (ca. 14cu ft) is bigger than we really need. I am planning to fill one shelf with 8-12 gallon jugs of water, with the intent of using its high latent heat of fusion to help keep the contents cold during a power outage. Is this volume actually enough to make a meaningful difference? Would this improve the efficiency during regular operation? (I am presuming cold air in the unused volume warms up very quickly, thus needing to be cooled down again.) Could this be improved by adding something to lower the water's freezing point?
Astronomy news on Phys.org
Make it salt water so it freezes at a lower temperature
You could make an inner space that's very well insulated and keep the food in that. They are built to a price and with 'just enough' insulation to match some sort of spec for a given cavity volume. You could improve on that greatly and I have a feeling that volume for volume, it may be better value. But don't try to freeze stuff down in that insulated core. Have a freezing section that's outside the core.
IMHO, if you get a bunch of those inexpensive, plastic cased 'freezer packs', you can jam them into odd corners then easily move some to Fridge or a carry-out chill box as required. Also, you won't have to calculate 'expansion' margins for those brine jugs. Come 'defrost' time, 400g and/or 800g freezer packs are much easier to stow around food in towel nests in buckets than a brine jug.
Back in January - and agreed that the weather wasn't particularly warm or cold, just normal for Wales(!) - we had a burst pipe that tripped the consumer unit. Four days later when we returned from holiday to a kitchen that looked like a cross between Niagara Falls and the Somme, I was pleasantly surprised to find the contents of our rather full large A+++ freezer to still be frozen. As we haven't died of food poisoning yet, I would venture to suggest to Richard Crane that as long as he has a well-insulated, modern freezer and doesn't live in the tropics then it isn't worth the hassle.
Lucky you. I wonder what maximum temperature your freezer compartment reached during the power cut. (A max/min recorder should be mandatory in all freezers, I think). Also, yours was a one-off experiment and the statistics of microbial populations in food could have accounted for the result. You are right in many ways, though in that the recommended storage conditions are well over the top, in most cases. The 'rules' about re-freezing food have changed over the years, partly due to the better initial freezing processes for meat and fish.
I like the freezer pack solution. Bags of ice are also much more convenient than frozen jugs.
This is a harder problem that it might appear. I have been looking at the performance of gel packs and water and, if you want to keep the food 'deep frozen' at well below -10C, I couldn't find any phase change materials to help you. The gel packs are designed for around 0C, which would be too high for freezer food safety. Adding salt will lower the phase change temperature but, so I read, the latent heat goes down. Basically you'd just be using specific heat capacity, which, for water, is only about half the 4.2 J/g /°C at room temperature. That's worth knowing because it means food will warm up faster than you might assume too.
If you can half the thermal conductivity of the total insulation, that would be the equivalent of doubling the mass of water / food, stored in the freezer for a given change in internal temperature. It is a point worth considering. Then there is the advantage that you don't need to freeze down the extra thermal mass.
The cost of insulation is not high. You can buy 50l of polystyrene beads for about £6 (first hit on Amazon and I'm sure there would be a cheaper source) and the insulation doesn't need to be fireproof.
So I still say that insulation could be the way to go! Any comments?
I cheat when it comes to gel packs
Living in the desert. They come in handy.
I tried that approach when a cheap landlord installed a cheap refrigerator, not much insulation. I added polystyrene insulation boards (the 4 x 8 foot type with foil facing used on ourside walls, under the shingles), to the outside surfaces. Ended up with a reduced electric bill but the condensation between the 'fridge and the insulation was enough to rust the 'fridge! Oh well.
Interesting comment. From what you write, it looks as though you put the insulation around the outside of the fridge. Fridges will 'sweat' and there is a regular thermal cycling of the outer skin so I am not surprised that your idea gave you problems. I am suggesting adding extra internal insulation. The thermal cycling inside the fridge is much less and the chill panel (the coldest part of the inside) has a drain which takes the condensate outside and, not surprisingly, that could easily have turned up as condensation between the skins.
I like the thought of extra internal insulation - avoids the problem of heavy jugs of liquid and potential leaks -- will explore ideas to implement.
Good luck!
Lining the interior walls of a chest freezer with insulation will hinder the coils from freezing the food.
some of the food you put in there will then not freeze for a week, which can make for some ghastly culinary disasters and perhaps trips to the doctor and/or hospital. One wants the food to freeze as fast as possible to avoid bacteria growth.
Any extra measure would require some extra considerations. I would never suggest just lining the inside of the freezer. My suggestion was to put already frozen items in ‘local’ insulation. Insulated shopping bags or expanded polystyrene boxes would give extra protection. A frost free freezer would deal with condensation as usual in the intermediate voids - as it does between chicken and beef pieces in their own bags.
I already made the point about freezing stuff down before putting it in extra insulation.
To the point about slowing freezing: the metal shelves have refrigerant tubing running underneath, so I should be fine putting food in on those to chill.
A bit of 'management' would be needed here. Things would spend a few days next to the chilling panels / shelves and then be put in the extra insulation.
Careful you don't cover the thermostat.
That's very true for an ordinary fridge where air should be allowed to circulate. The shelving is usually designed to allow circulation and this avoids hot spots.
But most good freezers will operate chock full and we are told that freezers are more efficient when full. Although that may just be bs. If there are baskets supplied then everything should be kept within them.
As near as I can tell, that is marginally true. A full freezer will have a longer thermal time constant, thus having fewer startup transients per unit time. Not having to cool the evaporator and heat the condensor as often saves a little bit of energy.
Every time you open the door cold air falls out and warm humid air enters and has to be chilled gain. If you fill empty space with anything that traps cold air (or eliminates voids) preventing it falling out then efficiency should improve. This could be jugs of water, empty plastic boxes with lids or even bubble wrap.
Jugs of water/ice have the advantage in a power cut but their shape might not have the optimum packing density to minimise air lost when door opened. Unless you have cubic jugs?
That is true but how much energy is taken in the brief current surge when the compressor starts? I guess that a full freezer just has less air circulation so the heating is less.
A fridge freezer is quite a major part of a yearly electricity bill but people want as much internal space as possible in as small an external volume as possible (at a low price) so 'we' are all stuck with sub optimal efficiency.
  • · Replies 30 ·
