What uniquely characterizes the germ of a smooth function?
  • Context: Graduate
  • Thread starter Thread starter lugita15
    Function Smooth
The discussion revolves around the characterization of the germ of a smooth function, particularly focusing on the minimum information required to uniquely identify a germ within the set of infinitely differentiable functions at zero. Participants explore various aspects of smooth and analytic functions, equivalence relations, and the implications of different mathematical properties.
  • One participant defines an equivalence relation on the set of infinitely differentiable functions, suggesting that the germ of a smooth function is represented by equivalence classes.
  • Another participant proposes that being analytic could meet the requirement for characterizing a germ but is uncertain if it is the minimum necessary information.
  • A different viewpoint questions the existence of an open interval qualifying a germ, suggesting that the existence of such an interval is essential.
  • Further contributions discuss the dimensionality of the quotient space of smooth functions, indicating that there are infinitely many germs corresponding to different smooth, non-analytic functions.
  • One participant suspects that the sequence of derivatives at zero might serve as a minimal identifier for analytic functions, but expresses doubt about the existence of a minimal identifier for all smooth functions.
  • Another participant mentions that knowing function values on any dense subset of an interval could suffice, but emphasizes that no interval or subset is minimal for identifying a germ.
  • References to literature, such as Courant's calculus, are made to illustrate the complexity of comparing functions' behaviors as they approach zero or infinity, suggesting that no single number can measure such behaviors effectively.
  • One participant introduces a concept of a partial order on the set of infinitely differentiable functions, proposing that the order type of this set is significantly larger than that of the real numbers.
Participants express differing views on what constitutes the minimum information needed to characterize a germ, with no consensus reached on a definitive answer. Multiple competing perspectives remain regarding the role of analytic functions, the existence of minimal identifiers, and the implications of function behavior near zero.
Limitations include the dependence on definitions of smoothness and analyticity, as well as unresolved mathematical steps regarding the characterization of germs and the implications of various function behaviors.
lugita15
Let ##X## be the set of all functions infinitely differentiable at ##0##. Let's define an equivalence relation on $X$ by saying that ##f\sim g## if there exists a sufficiently small open interval ##I## containing ##0## such that ##f(x)=g(x)## for all ##x## in ##I##. Then the set of germs of ##X## denotes the set ##Y## of equivalence classes of elements of ##X## under this equivalence relation.
My question, what uniquely characterizes the germ of a smooth function? That is to say, what is the minimum information needed to unambiguously specify a single element of ##Y## as opposed to all other elements of ##Y##? The nth derivatives of ##f## for all ##n## isn’t enough information, because the function f defined by ##f(x)=e^{-\frac{1}{x^2}}## when ##x## does not equal ##0## and ##f(0)=0## has the same nth derivatives as the function ##g(x)=0## for all ##n##, but they still don’t belong to the same germ.
Analytic functions form a subset of ##X##. Being analytic will meet your requirement, but I don't know if it is the minimum information.
In your example there is no such interval ##I##, so shouldn't it simply be the existence of that open neighborhood which qualifies a germ.
It's not the minimum information, but it provides a great way to deconstruct the search, by taking the quotient of the space of functions that are smooth in a nbd of X over the space of functions that are analytic at X. That way, we need only consider germ-equivalence classes of smooth non-analytic functions.
Given a function ##f## that is analytic at X, the following family of functions gives a different germ at X for every real ##a## and ##b##:
$$g(x) = f(x) + a h(x-X)$$
if ##x\ge X##, and
$$g(x) = f(x) + b h(X-x)$$
otherwise, where:
$$h(x) = \exp\left(\frac1{x^2}\right)$$
if ##x>0##, and
$$h(x)=0$$
otherwise.
So the quotient space has dimension at least 2 as a real vector space. But we know it must be more than that because at least one smooth, non-analytic function that is not in the subspace of the quotient that is thus generated is this function, which is smooth but nowhere real analytic.
i suspect what mathman meant was that the sequence of derivatives of all orders at 0, is the minimum amount of identifying information of a germ, for functions that are analytic, and presumably only for those. In general I do not believe there is any minimal identifier. I.e. the only data that will determine a germ is the values of the function on some interval, but the values on any smaller interval will also work, so no interval is minimal.
well ok, since the function is continuous, knowing its values on any dense subset of an interval will do. again, not only is the interval not minimal, the dense subset isn't either. so i do not know of any useful solution to this problem.
in the analytic case of course the germs are in one one correspondence with the convergent power series at zero. and in the algebraic case, the germs are in one one correspondence with the "local ring" at the origin, i.e. quotients of polynomials, with bottoms having a non zero constant term.but since the question to describing the quotient space of all germs, maybe there is a way, and maybe andrewkirk's idea to also throw out the known subspace of analytic stuff may help, but i don't see how to describe it.
it may be illuminating to read the sections in courant's calculus referred to as "order of vanishing" in his index. there he discusses the complexity of the related problem of comparing how fast various functions approach zero or infinity as x-->0 or infinity. essentially there is no way to assign a number to this even if we use all real numbers. in particular there are functions that approach infinity faster than x but slower than x^(1+e) for all e > 0. thus no real number exists that measures the speed of increase of such functions. (courant, vol. 1, p. 193). similarly there are functions that approach zero more slowly and others that approach more rapidly than any power of x.
Yes, if we define a partial order on the set of all functions infinitely differentiable at 0 by saying that f<g if the limit of f(x)/g(x) as x goes to 0 = 0, and then take a maximal totally ordered subset of that partially ordered set, then the order type of that set will be much bigger than the order type of the real numbers. It will basically be order-isomorphic to the set of all surreal numbers with birthday less than omega_1 (the first uncountable ordinal). See here.
  • · Replies 0 ·
