What were the advantages of biplanes?
  • Thread starter Thread starter ank_gl
Biplanes were favored in early aviation due to their structural advantages, providing nearly double the lift for a given wingspan while allowing for shorter, stronger wings that could be easily braced. Their design facilitated better maneuverability and lower stall speeds, making them suitable for rough field performance. However, their complexity and increased drag led to their decline as engine technology advanced and the need for speed became paramount. Modern aircraft designs, such as canards and tandem wings, have evolved to enhance performance while addressing the limitations of biplanes.
  • Understanding of aerodynamic principles, particularly lift and drag
  • Familiarity with aircraft design concepts, including wing configurations
  • Knowledge of historical aviation technology, especially from the WWI era
  • Basic grasp of thrust-to-weight ratio and its impact on aircraft performance
  • Research the aerodynamic advantages of canard configurations in modern aircraft
  • Explore the evolution of engine technology and its impact on aircraft design
  • Study the performance characteristics of biplanes versus monoplanes
  • Investigate the role of structural integrity in wing design and its historical context
Aviation enthusiasts, aerospace engineers, historians of flight, and anyone interested in the evolution of aircraft design and performance optimization.
ank_gl
What were the advantages of biplanes??
what were the advantages of biplanes??:confused::confused: i mean they were structurally more complex, had more drag and many things, then why the earlier flying machines were biplanes?? what made them more advantageous in earlier times??
was their only purpose was to provide more lift?? if so, why aren't they used now(i mean, in air not in meuseums:wink:)
You get (almost) twice as much lift for a given wingspan.
It was difficult to create long wings that were stiff enough to support themselves and the aerodynamic forces. Biplanes not only give you shorter wings but you can easily brace them against each other.
The problem as you pointed out is that they are complex and give lots of drag.
Some are used today, tandem wings (with one wing in front of the other) or canards (small wing near the nose) - they are more manouverable and usually don't need horizontal tails.
ank_gl said:
more lift?
More "lift" also means a lower stall speed in many cases and shorter/stronger wings. In both cases this adds to rough field performance and in air maneuverability.
As I understand it in a canard both sets of wings create and add to the lift.
In a main wing wth tail wing the tail wing creates a down force to counter some of the lift and maintain a level flight.
so the complex built is the only reason behind the demise of such planes
They are still around for all the reasons they first found favor (see stunt planes).
The need for speed, paved airports, time is money....call it what you will they are just not mainstream in todays world.
Also remember the importance of thrust to weight ratio - those planes didn't have the option to fly faster to generate more lift.
As far as I can remember (and it's been a while), the main advantage to canards is that they lower the stall potential for the main wings. You can have a steeper angle of attack at low power without falling down.
The elevators don't counter lift; they simply change the pitch axis of the aeroplane. You get the same effect with elevons on a delta layout, which doesn't even have a 'tail'.
Yes, the canard has a higher angle of attack than the wing and stalls first, this pushes the nose down, increases the speed and automatically recovers.
I'm guessing also that since the canard isn't in the wash of the main wing the aerodynamic controls on it are more effective than on a conventional tail.
I'm not sure about that last bit, Mgb. It makes sense, but I've never seen canards with control surfaces. Usually, the whole thing moves (both sides together as a unit).
why so? why can't biplanes fly faster
As mgb_phys already said, more drag.
As far as I understood, at the dawn of aviation there was this widely accepted notion that the wing should be like a flat plate only cambered to give lift, which gave it poor structural integrity. Therefore they couldn't build a strong and light enough single wing to support more capable and heavier WW1 airplanes, although the first true WW1 fighter, Fokker Eindecker of 1915, was, as the name implies, single-winged. The thin-wing hypothesis was finally disspelled at the turn of 1920's by the folks from Gottingen.
Once the structural problems were resolved, two wings simply didn't equate any more weight/drag-wise in most any practical use. Short span is good for roll-rate, therefore, as mentioned, aerobatics may profit. Also, biplane can be usefull for STOL design if efficiency is not an issue; An-2, designed in 1947 way after biplane concept was abandoned, can fly at about 55 km/h with light load.
Chusslove Illich (Часлав Илић)
I'm talking historically - engines were not very advanced when biplanes wre in their heyday and their power to weight ratio was pretty low.
Engines were wretched back in the era of WWI. Horrible thrust to weight. They were definitely the weak link.
  • · Replies 22 ·
