What would happen if gather all universe matter into one object.
  • Context: Graduate
  • Thread starter Thread starter ciurio
    Matter Universe
The discussion explores the hypothetical scenario of gathering all matter in the universe into a single object, examining the implications of such an action on the nature of that object and the universe itself. Topics include potential outcomes like black holes, fusion, and the concept of separation versus binding of particles.
  • Some participants suggest that gathering all matter could lead to fusion unless the density and size result in a black hole.
  • Others propose that the total mass, including that of black holes, might be sufficient to form a black hole.
  • A participant questions whether the term "black hole" is adequate given the scale of all universe matter being concentrated.
  • There is speculation about the possibility of a "big bang" occurring again if all matter were gathered, referencing the concept of a "Big Bounce."
  • One participant raises a question about the criteria for defining an object based on the separation of particles.
  • Another participant emphasizes that the definition of a single object can vary based on context, discussing how cosmologists and particle physicists might categorize objects differently.
  • Some participants reflect on the idea that the universe itself could be considered a single object, despite the apparent separations between matter.
  • There is a mention of gravitational effects and how they might influence the perception of separation among matter clusters.
Participants express multiple competing views regarding the implications of gathering all matter into one object, and the discussion remains unresolved with no consensus on the outcomes or definitions presented.
Participants acknowledge various assumptions about density, binding, and the nature of objects, but these remain unresolved and depend on differing interpretations of physical concepts.
ciurio
What would happen if gather all universe matter into one object?
Hello
What would happen if we
would gather all matter in the universe into one object.
What would happen inside such object?
Space news on Phys.org
http://en.wikipedia.org/wiki/Black-hole
fussion prolly... unless the density and size permit a black hole.
might want to google what happens inside of different types of stars and planets, although the composition of the resulting mass would be represenitive of the distribution of matter-types in the universe... including dark matter? is it spinning?
I think if you gather all the mass in the universe, including the mass already in black-holes (including super-massive black-holes), you might just have enough to form a black-hole.
I'm not a comsmologist, but I think the term black hole is somewhat of an understatement. We're talking about all the matter in the universe including all the black holes.
The universe began with all matter in one spot. It seems to me that there would be another big bang if it were to happen again. See"en.wikipedia.org/wiki/Big_Bounce"[/URL].
Total chaos?
What amount of separation between particles within an object is necessary for the object to be described as multiple objects? I.e. what would be the maximum amount of separation between particles in any part of the universe for it to be considered one object instead of many?
It's not about separation, it's about particles being bound together. Usually a single object is something that's not likely to come apart, and the definition can change based on context. For instance, you'd probably consider two books on a bookshelf to be separate objects for purposes of picking them up and reading them, but if you're moving, you might put those two books (along with others) into a box and consider the box a single object. At more extreme scales, cosmologists consider entire galaxies, or even clusters of galaxies, to be single objects, whereas at the other extreme, high-energy particle physicists consider the individual particles within protons and neutrons to be multiple separate objects.
I guess in a certain point of view, you could consider the entire universe as-is as a single object. But it'd be kind of a strange way to look at it, unless you also knew about things that existed outside our universe (other universes, I guess) and were considering this universe in a larger context.
big bang will be.
And.. its already in one object called The Universe, but this object has low density to bang.
Its like uranium critical mass..
This is what I was trying to get at in a simple way. The OP asked about the entire universe being gathered as a single object, so I wondered what the criteria for "single object" would be. If singularity is just a matter of subjective framing, you could say that the entire universe has always been a single object and it has evolved "rifts" between matter through the progress of gravitation. If space/distance was treated as completely relative, in what sense would you say the universe is "expanding?" You would just treat the universe as a constellation of particles without regard for size or distance between the particles. In this sense, the universe could be regarded as having constant size and only evolving in terms of configurational changes in the relative positions and dynamic interactions among particles.
I don't think you would need to compare the universe to something else external to it. You could just talk in terms of relative densities of matter-clusters and how intense the "rifts" between "clusters" are. These rifts could simply be intensifying as a byproduct of gravitational condensation and increasing density-differentials, which could be interpreted as relative separation the way clouds appear separate from other clouds due to lower humidity in the air between them.
Thank you for answers.
It'd be pretty hard to move.
  • · Replies 33 ·
10K
  • · Replies 30 ·
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 18 ·
