What would the universe be like
  • Context: Graduate
  • Thread starter Thread starter wonderer
    Universe
88 replies · 13K views
DEQ: aka diffEQ = differential equations. I'm still reluctant to even attempt mapping 11 dimensional space-time to find the missing TOE. Crap, I'm still trying to figure out 4 dimensional space-time. Confusing. I can only see 4 dimensions, but, it takes 11 dimensions to explain them. I shudder to think how many dimensions it will take to explain the 'missing' 7 once they are found. Must be a string theory thing. The more you unravel it, the more you get strung on.
Astronomy news on Phys.org
Not so. The extra dimensions in string physics come from the need to describe the string consistently, not explaining lower dimensions. And they've had stable numbers for decades: 28 for bosonic strings, 10 for superstrings, 11 for M-theory. With clear, if technical, explanations of why they are different.
connect said:
'Both in tandem' - are you referring to the fact our perceptions behaviour is similar to the behaviour of nature?
No.
Throw a ball.(direct)
Play music.(probagate)
Tape a walkman to the ball then throw it. The sound changes(both in tandem)
MATH
To do the math for each "whole" would include:
All the Space,All the Abilities(Vibrations for one) and All the time for that "whole" and each sub-level"whole" and each neighbor.
Else the math will never be right!
ANOLOGY
Apply anology->->A TRAIN WHISTLE.
Apply anology to this framework.
Do the math.
Ok, just in case the words "resistance is futile" was misunderstood. That was only meant to be funny...
Is quantum mechanics more or less a way to avoid doing all the math beyond a certain precision?
No, not at all. Perturbation theory could be described that way; express physics as an infinite series and only do the first n terms. But perturbation is a feature of work in classical physics too, for example celestial mechanics. If you mean uncertainty, that's not a cop-out, but a severe constraint, which has to be dealt with, and it does not prevent exact depictions in particlular cases. For example the photons in a laser beam all have the same frequency, hence momentum, to a high degree of exactitude. Uncertainty then says that we can know nothing about the position of any particular photon in the beam.
Beyond the simple cases the equations of quantum mechanics tend to become insoluble in exact terms. So approximations have to be used. This again is a common feature of all kinds of physics.
Wouldn't it be possible to eliminate the uncertainty for the anything if it were passing through space(not just nothing) reacting with it as it goes. Even though there would be little happening, there would still be some interaction. And don't forget the cost of shipping and handling...
Uncertainty in the universe, isn't necessarily something we need to get rid of, to explain the universe.
It might be the most fundamental thing in the universe. If we didn't have uncertainty we wouldn't have change.
Getting beyond it, to explain the origin of the universe, is another thing though.
Getting beyond the point... it's really about the shape 'm', 'w' and '-'...
'-' could not exist without 'm' and 'w'...
I do appreciate your responses. It seems to me the answers went AROUND the question and didnt answer it...
Could anything be solved passing through space, not just nothing. With no approximations.
In this context NOTHING = LACK OF REACTION.
I'm stupid. What exactly is m,w and -. shape in your terms?
wonderer said:
On a silver platter...right?
Picture this...remember the triangle for fire.
ABILITY
SPACE
TIME
TIME IS NOT AN ENTITY OR OBJECT.
Remove any one...the whole is no more...
No, I can't say. I'm just having fun by putting simple childish things which represent my theory which (I think) explains a lot. If you choose to view them as childish then you are bypassing it... :smile:
It's just a good way for Reflector to post his subliminal mysterious messages on the internet... That's how I view it. What else am I going to do? I'm just in my room trying to make a cool environment for my self, and I don't have any friends...
Sorry, I got side-tracked. 'M' and 'W' are the same thing viewed from different points of view...
Now that's a little more in the same ballpark.
http://arxiv.org/PS_cache/physics/pdf/0102/0102027.pdf
http://arxiv.org/PS_cache/quant-ph/pdf/0310/0310188.pdf
http://arxiv.org/PS_cache/quant-ph/pdf/0307/0307207.pdf
http://arxiv.org/PS_cache/quant-ph/pdf/0301/0301116.pdf
Apologies. I can't resist poking fun at string theory. I will take it more seriously once a background independent version is proposed.
It does seem that any theory that uses mulitples of the same thing (albeit in different configurations), in this case strings... AND without explaining the "space" in between them... is presumably flawed.
Some seem to forget that it's all about a "singularity."
I got a "hair" theory I'll sell ya... much smaller than strings.
Maybe...just maybe you hit a direct bullseye...
A universe that should be something it...is not ...never was...and never will be.
There is no true solidity in the universe... nor does it ever truly disappear.
And I believe the reason for this is that it is continually attempting to achieve something it can never achieve...by design. A simple flaw.
String theory is elegant and attractive. Unfortunately, it makes no testable predictions, to date. That is my main objection.
It seems like it's comfortable in it's imperfection though. Maybe not so much a flaw but a limit.
Kind of like saying "it's a fun job, I can't be boss, but I can't be fired either."
Guess it could even be expressed as a Lot like "tug of war"...the rope could be a string. I have only read a few lines about string theory and heard about the same.So if it doesn't fit...
