Whats the chemichal composition of oak wood?
  • Thread starter Thread starter ForumFire
    Composition Wood
The chemical composition of oak wood primarily consists of cellulose and lignin, which are crucial for its structural integrity. To alter the wood's properties for cutting, one can explore methods that involve digesting lignin using strong acids or bases, as well as applying heat through steam baths. The discussion references a patent on dissolving cellulose and a research paper on lignin digestibility in Quercus species. Additionally, the use of an oxygen lance is suggested as a method to produce gas for cutting purposes.
  • Understanding of cellulose and lignin in wood composition
  • Knowledge of chemical reactions involving acids and bases
  • Familiarity with wood engineering principles
  • Basic concepts of thermal treatment in material science
  • Research methods for digesting lignin using strong acids or bases
  • Explore the use of steam baths for bending wood
  • Investigate the application of oxygen lances in cutting materials
  • Read the paper on lignin digestibility in Quercus for deeper insights
Wood engineers, chemists, and anyone interested in innovative wood cutting techniques and the chemical properties of wood materials.
ForumFire
Whats the chemical composition of oak wood? I want to know because I am trying to cut wood by changing the chemical compound of the places that i want to cut it at by putting a chemical that would bond to the wood, and the new compund of my chemical and wood would be a gas.
I don't know if it would work or not, but i hope it would work kinda the same way as baking soda and vinegar combine and get changed, execpt the wood would be the "baking soda" and the special chemical would be the "vinegar"
Chemistry news on Phys.org
The main structure of wood cells is formed from cellulose. The cells are held together by lignin. If lignin is even partially removed the wood loses structural integrity and can be cut quickly or bent without breaking.
You should check out the concept of digestibility of lignin. Typically it is done with strong acids or sometimes a strong base. Heat can also affect lignin bonding - steam baths are used to heat wood so it can be bent.
Here is a paper on digesting lignin in softwoods and in Quercus (red oak sub-genus):
http://jas.fass.org/cgi/reprint/36/4/768.pdf
For anything to do with wood engineering and chemistry always start here:
http://www.fpl.fs.fed.us/
check out the publications area
You might try an oxygen lance. You apply the chemical (heated somewhat) to where you want to cut and a gas (largely CO2) is produced.
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 19 ·
9K
  • · Replies 24 ·
