What's The Discrete Math Derivative Equivalent?
The discussion focuses on determining the optimal base value \( b \) and exponent \( n \) for the equation \( ƒ = b^n \) under specific constraints. The constraints require \( 1 < b < L \) and \( b^n < I \), where \( I \) is a large integer. The proposed method involves calculating the logarithmic bounds \( Hi = \lfloor\log_2 I\rfloor \) and \( Lo = \lceil \log_L I\rceil \), and then maximizing \( b^n \) by evaluating \( \lfloor I^{\frac{1}{m}} \rfloor^m \) for \( m \) within the defined range. This approach significantly reduces the search space compared to a brute-force method.
  • Understanding of exponential functions and their properties
  • Familiarity with logarithmic calculations
  • Basic knowledge of integer constraints in mathematical optimization
  • Experience with mathematical notation and inequalities
  • Study logarithmic properties and their applications in optimization
  • Explore integer programming techniques for maximizing functions under constraints
  • Learn about computational methods for searching optimal values in mathematical problems
  • Investigate advanced topics in discrete mathematics related to exponentiation
Mathematicians, computer scientists, and anyone involved in optimization problems, particularly those dealing with discrete mathematics and exponential functions.
iScience
$$ƒ = b^n$$
$$ b,n,I ∈ ℤ $$
Condition: Upon choosing a base value b..
$$ n | b^n ≤ I $$
(n is determined based off the value of b to yield the highest ƒ without going over I)
$$1<b<L , L<<I$$
where I is some large number, and L is also sufficiently large such that we want to avoid going through each base integer via trial and error...
How might I determine the base value that yields a value ƒ that is closest to I?
I'm not sure exactly what you are asking.
Are you asking how to, given ##L,I\in\mathbb{Z}## with ##0<<L<<I##, find the combination ##b,n\in\mathbb{Z}## that maximizes ##b^n## subject to the constraints
1. ##1<b<L##; and
2. ##b^n<I##
If so then you could set ##Hi=\lfloor\log_2 I\rfloor## and ##Lo=\lceil \log_L I\rceil##, then find
$$b^n=max_{Lo\leq m\leq Hi}\bigg( \lfloor I^\tfrac{1}{m}\rfloor\bigg)^m$$
where ##n## is the value of ##m## that delivers that maximum.
That will give a much smaller search space than ##1,...,L##.
  • · Replies 16 ·
