What's the physical interpretation of ρ for dipole forbidden channel?
The discussion focuses on the physical interpretation of the density matrix element ρ12 in a Λ-type three-level system, where transitions between levels 1 and 3, and 2 and 3 are dipole allowed, while the transition between levels 1 and 2 is dipole forbidden. The participants clarify that while dipole-forbidden transitions have significantly lower probabilities, the density matrix element ρ12 still provides insights into population distributions. Specifically, it is noted that in cases with different population distributions, such as ρ11=0.9 and ρ22=0.1 versus ρ11=0.1 and ρ22=0.2, the value of ρ12 varies, indicating a relationship with the populations of the states involved.
  • Understanding of density matrices in quantum mechanics
  • Familiarity with Λ-type three-level systems
  • Knowledge of dipole and multipole transitions
  • Concept of population distributions in quantum states
  • Study the implications of dipole-forbidden transitions in quantum optics
  • Explore the role of density matrices in quantum state populations
  • Investigate the effects of dephasing on quantum state transitions
  • Learn about higher-order multipole transitions and their significance
Quantum physicists, optical engineers, and researchers studying atomic transitions and quantum state dynamics will benefit from this discussion.
zhdx
Consider we have a [itex]\Lambda[/itex] type three level system, the one upper level is denoted by 3, and the two lower levels are denoted by 1 and 2. Assuming that the transitions between 1[itex]\leftrightarrow[/itex]3 and 2[itex]\leftrightarrow[/itex]3 are dipole alowed, while the transition between two lower states 1 and 2 is dipole forbidden. As we know the real and imaginary part of ρ31 describe the dispersion and absorption of the external light in 1[itex]\leftrightarrow[/itex]3 channel. But what does the ρ12 mean?
The same thing.
Dipole-forbidden means that the electric dipole moment vanishes. Higher order multipole transitions (E.g. quadrupole) can still occur, but the matrix elements and thus the transition probabilities are much lower. Therefore the electric dipole is usually very dominant, and if the dipole is allowed, then all other transitions can be neglected. The net effect is that the 1-2 transitions are very weak (but still not completely forbidden)= the 2 state has a very long lifetime.
Does the ρ12 has relation to the population distributions?
Thanks!
Does the ρ12 has relation to the population distributions? Say consider two cases:
Case 1: ρ11=0.9, ρ22=0.1
Case 2: ρ11=0.1, ρ22=0.2
What I've found is that the ρ12 in Case 2 is much less than in Case 1. (I've add a dephasing constant γ2d for level 2 compared to level 1.)
  • · Replies 56 ·
  • · Replies 0 ·
