When calculating escape speed why is v_f =0
  • Thread starter Thread starter Saladsamurai
    Escape Speed
4 replies · 4K views · last reply
Saladsamurai
That's all. I am just trying to derive the reason why when using comservation of mechanical energy [tex]v_{final}[/tex] goes to zero?
The escape speed is the minimum speed to just barely make it to infinity with no energy left. So the final speed is zero.
Because escape speed is the minimum velocity at distance [tex]r=x[/tex] that the object has to be moving in order to break away from the gravitational pull of a planet at a velocity of 0.
As the object moving at speed [tex]V_{initial}[/tex] moves from [tex]r = x[/tex] to [tex]r=\frac{1}{0}[/tex] the force of Earth's gravity decellerated the object (use equation: [tex]F=ma[/tex]) and this causes the object to, of course, lose speed, the escape velocity therefore is a velocity that puts you JUST out of reach of a planets gravitational field, but fully decellerated, moving faster than the escape velocity will mean that you will have additional, yet reduced speed after escaping the gravitational field.
Ahhh...yes. I completely overlooked that little word minimum:blushing:...This makes perfect sense..except for the whole r=1/0. I could see it being 1/infinity though.
jedisoccer said:
well escape speed is the minimum speed to break the gravitational pull, so if you look at it like a derivative, the minima will b eequal to 0 where you get Vf is 0
i think
can someone help me with my questions as well?
https://www.physicsforums.com/showthread.php?t=167738
and
https://www.physicsforums.com/showthread.php?p=1449317#post1449317
Patience grasshopper. Someone will surely reply to your posts. Please do not go around hijacking threads.:rolleyes:
Casey
