When do we need to consider the homogeneous solution?
  • Level: Graduate
  • Thread starter Thread starter LCSphysicist
    Homogeneous
2 replies · 4K views
LCSphysicist
Homework Statement:: All below
Relevant Equations:: ,
Generally, when for example we need to solve ##\nabla u = 0##, we separate variables and find equations like that ##X''/X = -Y''/Y = k^2##. So we just solve it, sum the solutions and make it satisfy the boundary/initial conditions.
But, sometimes we also need to consider the case when ##k=0##, that is, we need to consider solutions of the type ##x, y, xy, const.##.
While it becomes apparent the necessity of these terms when we are solving the problem, i would like to know if there is a way to realize right at the beginning if we would need to consider these other solutions.
For example, ##u = 0## at ##x=0, y = 0, x = L; u = 30## at ##y = H## does not need it. But ##u_y = 0## at ## x=0, x=L; u = 0## at ##y=0; u = f(x)## at ## y = H## need it.
How could i know right at the beginning? Of course this is just one example, i would like to know for any general case, even for differents differential equations other than ##\nabla u = 0##
[Moderator's note: moved from a homework forum.]
One case that I have encountered is with the differential equation for ## H ## in magnetostatics for the steady state problem: ## \nabla \times H =J_{conductors} ##. The solution to this is basically the Biot-Savart formula, but this solution misses the homogeneous solution from the magnetic poles.
In solving the problem in an alternative manner, using ## B=\mu_o (H +M) ##, and taking the divergence of both sides, you get ## \nabla \cdot H=-\nabla \cdot M ##. This has an integral solution for ## H ## with the inverse square law with ## \rho_m==\nabla \cdot M ##, which is the solution from the poles that we needed above, but this time the homogeneous solution from the currents in the conductors is missing.
I don't know that there is a good way to determine in advance whether you need to include a homogeneous solution. In this case though, it really can make for some puzzling mathematics, if one isn't heads-up enough to spot what is missing.
Consider [itex]\nabla^2 u = 0[/itex] on [itex](0,L) \times (0,H)[/itex] subject to
[tex] \begin{array}{cc}<br /> \alpha_0 u + \beta_0u_x = 0 & x = 0 \\<br /> \alpha_1 u + \beta_1u_x = 0 & x = L \\<br /> u = f(x) & y = 0 \\<br /> u = 0 & y = H<br /> \end{array}[/tex] where [itex]\alpha_i^2 + \beta_i^2 = 1[/itex]. Then there exists a sequence of eigenvalues [itex]\lambda_n \in \mathbb{R}[/itex] such that [tex]X_n'' - \lambda_nX_n = 0\quad\mbox{subject to}\quad<br /> \begin{array}{c} \alpha_0X_n(0) + \beta_0X_n'(0) = 0, \\<br /> \alpha_1X_n(L) + \beta_1X_n'(L) = 0,\end{array}[/tex] has a non-trivial solution. The condition for zero to be one of these eigenvalues is [tex] \alpha_1 \beta_0 - \alpha_0(\beta_1 + \alpha_1L) = 0.[/tex]
