MHB Why do we use & before ptr->points?
  • Thread starter Thread starter evinda
    Pointers
The discussion centers around the use of pointers and the `scanf` function in C programming, specifically regarding when to use the address-of operator (`&`). It clarifies that when inputting data into an array, such as `ptr->id`, `ptr->firstname`, and `ptr->lastname`, the array name itself acts as a pointer to its first element, so the `&` operator is not needed. In contrast, for non-array variables like `ptr->points`, which is a float, the `&` operator is necessary to provide the memory address where the value should be stored. The conversation emphasizes the distinction between arrays and single variables in memory addressing and the implications for using `scanf`.
evinda
MHB
Hello! (Wave)
I have a question... 🧐
https://dyclassroom.com/c/c-passing-structure-pointer-to-function
At the Complete code stated at the site above, at this part:
Code:
for (i = 0; i < 3; i++) {
    printf("Enter detail of student #%d\n", (i + 1));
    printf("Enter ID: ");
    scanf("%s", ptr->id);
    printf("Enter first name: ");
    scanf("%s", ptr->firstname);
    printf("Enter last name: ");
    scanf("%s", ptr->lastname);
    printf("Enter Points: ");
    scanf("%f", &ptr->points);
    // update pointer to point at next element
    // of the array std
    ptr++;
why when the input is an array we do not use & and when the input is not array we use it?
So why we use only & before ptr->points?
Which is the difference? :oops::unsure:
Technology news on Phys.org
First this can vary with the compute language. Are you referring to C++?
Do you understand what a "pointer" is?
A computer has many "memory locations" in which it can store numbers. A pointer (to x) is, technically, a memory location which contains the memory location in which "x" is stored. Putting & before a pointer changes it to the memory location in which "x" is stored. More specifically, if I have the number "7" stored somewhere in memory, the pointer "P" is the memory location in which "7" is stored while "&P" is the number "7" itself.
First off, we need to provide a memory address to scanf.
Generally, we do that by putting & in front of the variable that we want to fill. (Nerd)
If the data member is an array, there is actually no difference whether we put an & in front of it or not.
Suppose we have char arr[10];.
Then the C standard says that arr is treated as the same memory address as &arr[0].
If we use &arr, we are saying we want to have the memory address of the array, which is the same thing.
And we can't take the address of a memory address - that does not make sense. (Nerd)
ptr->points is not an array. Instead it is a floating point number.
So we have to put & in front of it to get its memory address. (Nerd)
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
  • · Replies 118 ·
9K
  • · Replies 19 ·
11K
