When does JIT compilation occur and at what level?
  • Thread starter Thread starter Chromium
3 replies · 3K views
Chromium
Does "JIT" only occur when translating some intermediate form of the program into native code? Or can it also occur in other ways? For example, say you have a compiler that kind of acts like an interpreter in that for each line it compiles that source code into native code and immediately after compiling that line it executes it.
So for each line, you go through these steps:
1) Compile
2) Execute
To me it seems that something like this would be slow because constantly compiling & executing seems like a pretty inefficient way of computing. But, it was the only example I could think of.
Thanks,
--Jonathan
Chromium,
It would be very inefficient to "compile" one line of code at a time. Instead, entire modules or classes are just-in-time compiled before being used.
- Warren
Also, already-compiled classes and modules are kept loaded (in executable form) in memory (as long as enough memory is available) so that if they are called again, no compilation is needed. This causes programs to "warm up"--once most parts of a program have been JIT-compiled, it runs about as fast as a native executable that is entirely pre-compiled.
JITing usually occurs at the subroutine level or higher. Compilation (or interpretation) produces an intermediate form (a tree usually) that represents the source statements. It is common for these syntax trees to span entire subroutines, that way they can refer to each other. For example an 'if' statement will refer to the 'else' part. Therefore when compiling the whole tree is done at once. JITing (in the .NET or Java sense) refers to taking an intermediate form (IL or byte codes) and compiling them into machine code. At this level there is no source code as it has already been compiled away.
