When does {t < α} ∩ {β < u} equal {t < α < u}?
  • Level: Graduate
  • Thread starter Thread starter wayneckm
    Set
9 replies · 3K views · last reply
wayneckm
Hi all,I have the following question:
Suppose there are two functions [tex]\alpha,\beta[/tex], which are both mapping [tex]\Omega \mapsto \mathbb{R}[/tex] and [tex]\alpha \leq \beta[/tex] on every point [tex]\omega \in \Omega[/tex].
I am wondering the validity of the following, for [tex]t < u[/tex],
[tex]\{t < \alpha\}\cap\{\beta<u\} = \{ t < \alpha < u\} = \{ t < \beta < u\}[/tex]
Can anyone justify this? Thanks.Wayne
Can you be a little more specific what something like {t < a} means?
Is t also a function [itex]\Omega \to \mathbb{R}[/itex]? Then does t < alpha mean, that [itex]t(\omega) < \alpha(\omega)[/itex] for any [itex]\omega \in \Omega[/itex]?
And is
[tex]\{ t < \alpha \} := \{ \omega \in \Omega \mid t(\omega) < \alpha(\omega) \}[/tex] ?
Or is, for example, t a real number and is { t < alpha } the set of all lower bounds of alpha, or something like that?In general, I would say that if it is given that
[tex]t < \alpha, \alpha \le \beta \text{ and } \beta < u,[/tex]
then you can trivially say
[tex]t < \alpha \le \beta < u[/tex]
Thanks for the reply.
Sorry for not specifying clearly enough.
Here [tex]t,u[/tex] are constants.
The reason for this question is because [tex]\beta[/tex] is some measurable function while [tex]\alpha[/tex] is an arbitrary function.
So given the information above, I am thinking whether
[tex]\{t < \alpha\}\cap\{\beta< \alpha < u\} = \{ t < \alpha< u\} = \{ t < \beta < u\}[/tex]
holds. So that I can say this is a measurable set.
Thanks.
You misunderstood Compuchips question and may be misunderstanding the entire problem. It makes no sense to say "[itex]t< \alpha[/itex]" or "[itex]t< \beta< u[/itex]" for t and u constants (numbers) and [itex]\alpha[/itex] and [itex]\beta[/itex] functions- there is no order relation that order both numbers and functions. Do you mean "[itex]t< \alpha(x)[/itex] for all x" and "[itex]t< \beta(x)< u[/itex]" for all x?
Sorry, I should write clearly again...
[tex]\{t < \alpha\}\cap\{\beta< u\} = \{ t < \alpha< u\} = \{ t < \beta < u\}[/tex] means [tex]\{\omega \in \Omega | t < \alpha(\omega)\}\cap\{\omega \in \Omega |\beta(\omega)< u\} = \{ \omega \in \Omega | t < \alpha(\omega) < u\} = \{ \omega \in \Omega | t < \beta(\omega) < u\}[/tex] where [tex]t,u[/tex] are constants.
Thanks.
The "elementary" approach here is to show two inclusions by considering arbitrary elements of the set.
One part of the proof would then be to show that
[tex] \{\omega \in \Omega | t < \alpha(\omega)\}\cap\{\omega \in \Omega |\beta(\omega)< u\} \subseteq \{ \omega \in \Omega | t < \alpha(\omega) < u\} = \{ \omega \in \Omega | t < \beta(\omega) < u\}[/tex]
Indeed, let
[tex]\omega \in \{\omega \in \Omega | t < \alpha(\omega)\}\cap\{\omega \in \Omega |\beta(\omega)< u\} \subseteq \{ \omega \in \Omega | t < \alpha(\omega) < u\}.[/tex]
Then it is true that both [itex]t < \alpha(\omega)[/itex] and [itex]\beta(\omega) < u[/itex], and because it is given that [itex]\alpha(\omega) \le \beta(\omega)[/itex] for any omega (in particular this one), you get a string of inequalities
[tex]t < \alpha(\omega) \le \beta(\omega) < u[/tex]
from which the inclusion follows.
Almost the exact same argument in reverse applies to show that
[tex] \{\omega \in \Omega | t < \alpha(\omega)\}\cap\{\omega \in \Omega |\beta(\omega)< u\} \supseteq \{ \omega \in \Omega | t < \alpha(\omega) < u\} = \{ \omega \in \Omega | t < \beta(\omega) < u\}[/tex]
So this means
[tex] \{\omega \in \Omega | t < \alpha(\omega)\}\cap\{\omega \in \Omega |\beta(\omega)< u\} = \{ \omega \in \Omega | t < \alpha(\omega) < u\} = \{ \omega \in \Omega | t < \beta(\omega) < u\}[/tex]
is wrong. Rather, it should be written as
[tex] \{\omega \in \Omega | t < \alpha(\omega)\}\cap\{\omega \in \Omega |\beta(\omega)< u\} = \{ \omega \in \Omega | t < \alpha(\omega) < u\} \bigcap \{ \omega \in \Omega | t < \beta(\omega) < u\}[/tex]
No, it was correct.
If t, omega and u satisfy
then of course you can leave out any link of the inequality chain and get
[tex]t < \beta(\omega) < u[/tex]
and
[tex]t < \alpha(\omega) < u[/tex]
separately.
Wayne, your original equation is wrong but your revised one is correct. To verify that the original is wrong, see the following counterexample.
Let a(w)=w and b(w)=w+1 for real w, and let t=1 and u=2. Then
{w: t<a(w)} = (1,inf) does not intersect {w: b(w)<u} = (-inf,1) while {w: t<a(w)<u} = (1,2) and {w: t<b(w)<u} = (0,1).
Thanks a lot.
My proof is as follows:
First, note that [tex]\{ \alpha(\omega) \leq \beta(\omega) \} = \Omega[/tex]
[tex] \{ \omega \in \Omega | t < \alpha(\omega) < u\} = \{ \omega \in \Omega | t < \alpha(\omega) < u\} \bigcap \Omega = \{ \omega \in \Omega | t < \alpha(\omega) < u\} \bigcap \{ \alpha(\omega) \leq \beta(\omega) \} [/tex]
[tex] = \{ \omega \in \Omega | t < \alpha(\omega) \leq \beta(\omega) < u\} \bigcup \{ \omega \in \Omega | t < \alpha(\omega) < u \leq \beta(\omega) \}[/tex]
Note that these two are disjoint sets. Then, similarly,
[tex] \{ \omega \in \Omega | t < \beta(\omega) < u\} = \{ \omega \in \Omega | t < \beta(\omega) < u\} \bigcap \Omega = \{ \omega \in \Omega | t < \beta(\omega) < u\} \bigcap \{ \alpha(\omega) \leq \beta(\omega) \} [/tex]
[tex] = \{ \omega \in \Omega | t < \alpha(\omega) \leq \beta(\omega) < u\} \bigcup \{ \omega \in \Omega | \alpha \leq t < \beta < u \}[/tex]
Again, these two sets are disjoint.
Finally,
[tex] <br /> \{\omega \in \Omega | t < \alpha(\omega)\}\cap\{\omega \in \Omega |\beta(\omega)< u\} = \{ \omega \in \Omega | t < \alpha(\omega) \leq \beta(\omega) < u \}<br /> [/tex]
So it is the intersection of the above two sets.
