When the expression is a square of a rational number.
The discussion focuses on determining when the square root of the expression 25 + 8a^2 is rational, given that a is also a rational number. The user attempts to relate this problem to Pythagorean triples and seeks a formula for a in terms of another rational number m. A suggestion is made to express the condition as a rational equation and to explore rational points on the hyperbola defined by x^2 - 8y^2 = 25. The conversation emphasizes finding a suitable transformation to derive a rational expression for a that satisfies the original requirement.
chingel
I am trying to find when the square root of the expression 25+8a^2 is rational, where the number a also needs to be rational. \sqrt{25+8a^2}=b, where a and b are both rational numbers. I am trying to get an expression for a in terms of some other number m, which would always make the number a satisfy the original requirement.
I haven't really done a problem like this before, but it looks a lot like Pythagorean triples 5^2+(2\sqrt{2}a)^2=c^2, so I tried working something with the formula (m^2-n^2)^2+(2mn)^2=(m^2+n^2). I didn't have any other ideas than simply substituting something in there, for example 2\sqrt{2}a=2mn; then m=\sqrt{2}a/n; then 2a^2/n^2-n^2=5, but this just gets me back to the beginning, if I multiply by n^2 and try to solve using the quadratic formula.
Any hints are appreciated. Some examples of a's that work are 0, 10/7 and 15/17.
Well , I don't quite understand what you are trying to prove. Are you trying to prove that if \sqrt{25+8a^2} is rational , then a is also rational ?
If so then say ,
\sqrt{25+8a^2} = p/q
where p and q are coprimes and q is not 0.
Work it out.
So basically, you need find the rational points on the hyperbola
x^2-8y^2 = 25
See this link: http://mathcircle.berkeley.edu/BMC4/Handouts/elliptic/node4.html to find the rational points on the circle. Can you adapt the proof such that it works in this case?
Do you mean something like this?
a=\frac{5m}{2m^2-1}
\sqrt{25+8a^2}=\sqrt{25+8\frac{25m^2}{(2m^2-1)^2}}=\sqrt{\frac{25(2m^2-1)^2+200m^2}{(2m^2-1)^2}}=\sqrt{\frac{100m^4-100m^2+25+200m^2}{(2m^2-1)^2}}=\sqrt{\frac{100m^4+100m^2+25}{(2m^2-1)^2}}=\sqrt{\frac{(10m^2+5)^2}{(2m^2-1)^2}}=\frac{10m^2+5}{2m^2-1}
  • · Replies 21 ·
