Order
- Messages
- 96
- Reaction score
- 3
A uniform rope of mass [tex]\lambda[/tex] per unit lengt is coiled on a smooth horizontal table. One end is pulled straight up with constant speed v0.
a. Find the force exerted on the end of the rope as a function of height y.
b. compare the power delivered to the rope with the rate of change of the rope's total mechanical energy.
[tex]F=\frac{dp}{dt}[/tex]
[tex]P=Fv[/tex]
[tex]\frac{dE}{dt}[/tex]
a. I have no problem in finding the solution. I use [tex]p(t)=v_{0}t \lambda v_{0}[/tex] where [tex]y=v_{0}t[/tex]and [tex]p(t+\Delta t)=v_{0}(t+\Delta t) \lambda v_{0}[/tex] to obtain [tex]\frac{dp}{dt}=\lambda v_{0}^{2}.[/tex] And therefore [tex]F=\frac{dp}{dt}+F_{g}=\lambda v_{0}^{2}+\lambda y g.[/tex] Here the first term is independent of height which is surprising to me, but never mind.
b. I use [tex]P=Fv=\lambda v_{0}^{3}+\lambda v_{0}yg.[/tex] Now to find the energy change I use [tex]E(t)=v_{0}t \lambda \frac{v_{0}^{2}}{2}+\lambda y g \frac{y}{2}=v_{0}t \lambda \frac{v_{0}^{2}}{2}+\lambda g v_{0}^{2}\frac{t^{2}}{2}[/tex] [tex]E(t+\Delta t)=v_{0}(t+\Delta t) \lambda \frac{v_{0}^{2}}{2}+\lambda g v_{0}^{2}\frac{(t+\Delta t)^{2}}{2}[/tex] and therefore [tex]\frac{dE}{dt}=\lambda \frac{v_{0}^{3}}{2}+\lambda v_{0}yg.[/tex] You can see here that gravitational energy is conserved whereas the energy change because of momentum is not. There are no collisions, so where does the energy go?
