Where Should a 150N Weight Be Placed on a Ladder to Achieve Equilibrium?
To achieve equilibrium on a ladder weighing 200N, a weight of 150N should be placed 0.667m from the pivot point, which is located at 0.5m from the base of the ladder. The calculations confirm that the total clockwise moment equals the total anti-clockwise moment when the weight is positioned correctly. Different approaches to the problem, such as considering the center of mass of the ladder or focusing on a segment, can yield the same result. The discussion highlights the importance of understanding pivot points and moments in achieving balance. Overall, the solution appears to be accurate based on the provided calculations.
learn2physics
A ladder weighing 200N is being held by a man. The man shoulder acts as a pivot. His arm is pushing an upward force F.
http://i.imgur.com/dMrcRtK.jpg
Where could a weight of 150N be hang upon, so that force F do not need to counteract the weight of the ladder
Moment= F x Perpendicular Distance
I am not sure if I am understanding it correctly. If I am not wrong, the question is asking me, where can I hang a weight of 150N, so that force F no need to counteract the weight of the ladder. Meaning, assume force F = 0N.
Let the distance be x
Total clockwise moment = total anti clockwise moment
150x = 200*0.5
150x = 100
x = 2/3
= 0.667m.
Therefore it needs to be hang 0.667m away from the pivot or at 3.167m of the ladder.
Am I understanding this correctly?
From your picture, I thought the pivot was at 0.25m (that's where "F" is drawn) but I guess that 0.25m is just the length of his arm?
Anyway, if the pivot is at 0.5m then I believe you've done it correctly, because I did it a different way and got the same answer. (I could have made a mistake, but as far as I can tell it is correct.)
Yes the pivot is at 2.5 mark of the ladder from the left. Sorry my picture wasn't clear.
Is my understanding correct? Thank you!
It appears to be, from your math. But there are usually multiple ways to understand something.
For example, you used the center of mass of the entire ladder to solve the problem, whereas I solved it using the center of mass of only the first meter (from the left) of the ladder.
The reason is, in my eyes, the first meter (from the left) is the only important part (because the other 3 meters are symmetrical around the pivot and therefore cancel out). So I took the mass of the first meter (50 Newtons, since it's 1/4 of the entire ladder) and multiplied it by the distance from the pivot (2 meters) and then I set it equal to 150xWe created our equations based on different understandings, yet they still led to the same answer.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
