Where to Find Thermocouples for Power Generation in Stores or Online?
  • Thread starter Thread starter .:Endeavour:.
The discussion revolves around the availability and construction of thermocouples for power generation, particularly in the context of using them during hot weather. Participants explore both purchasing options and DIY methods, as well as the practical applications and limitations of thermocouples in generating electricity.
  • Homework-related
  • One participant inquires about where to buy thermocouples or how to make them using household items for electricity generation in summer.
  • Another participant suggests a specific supplier for thermocouples but argues they are not effective as a power source, emphasizing their utility in temperature measurement instead.
  • Some participants propose that thermocouples can be easily constructed using two different metals joined at two points, with copper and constantan being a common combination.
  • A request for a diagram to aid in the construction of a thermocouple is made, highlighting the need for a temperature difference for functionality.
  • One participant elaborates on the construction process, explaining that soldering or welding two different metal wires together can create a voltage difference, and mentions the concept of a thermopile to increase voltage output.
  • Another participant shares a link to a visual reference for constructing a thermocouple and discusses the importance of maintaining a temperature difference at the contact point of the wires.
  • One suggestion is made to consider using a Peltier device for power generation, with links to resources for purchasing them online.
Participants express differing views on the effectiveness of thermocouples as a power source, with some asserting they are not suitable for generating significant electricity while others discuss methods to potentially enhance their output. The discussion remains unresolved regarding the practicality of using thermocouples for power generation.
Participants mention various assumptions about the construction and functionality of thermocouples, including the need for temperature differentials and the limitations of voltage output. There are also references to specific materials and methods that may not be universally applicable.
This discussion may be of interest to hobbyists, students, or anyone exploring DIY energy generation methods, particularly those curious about thermocouples and their applications in power generation.
.:Endeavour:.
I want to know where can you find thermocouples in a store to buy or can you make them by using house hold items? The reason why I want to buy or make one is to use it during summer to generate electricity durning the hot weather.
http://www.omega.com/" is a good place to find theromcouples. You will not find them useful as a powersource in the summer or any other time. what they can do with proper elctronics is tell you how hot it is.
They are really easy to make though and all you need is two different metals ,usually wires, joined at two different places.Copper and constantan(an alloy) is a common combination
Is there a diagram on how to make one. Because I've been Googling thermocouple but I didn't get a solid description on how to make one except that you need a difference of temperature for it to work which I think I know where to get the two different temperatures. Thank you for your help.
It's dirt easy. Solder or weld two wires of different metals together. Stick the soldered end into something that's hotter or colder then the other end of the two wires and that's enough so there is a minute voltage between the free ends.
Make a long zig zag of alternating wires between the two temperatures to multiply the voltage. This is called a thermopile. The Voltage is #&^#$ small, so unless you are planning a whole furry wire coat around something you are planning to get the thermal energy from, you will be able to run a quartz clock at best.
Can you show me how you make a thermocouple. I do understand what you're saying only that I would like something visual to make reference on so I know I'm doing it correctly.
Her you go :)
http://www.madwizard.org/images/content/el/reflowoven/thermocouple.jpg
The other end of the wires where you take out the voltage needs to be colder/or warmer. If you use a cable with two wires of the same metal to transport the voltage away from the thermocouple the point that counts and needs to be colder is the contact point of your cable to the thermocouple. Just search for thermopile to get pictures of those. I liked a drawing from a paper from 1912 a lot, but I cannot find it anymore.
But there is quite a few pictures on google even if you discard all the commercial ones, which are encased and don't show anything.
  • · Replies 0 ·
10K
