Where was the big bang singularity?
  • Context: Graduate
  • Thread starter Thread starter jumpjack
    Big bang Singularity
The discussion revolves around the concept of the big bang singularity and its implications for understanding the universe's expansion. Participants explore whether it is possible to identify a specific location for the singularity, the nature of expansion, and the limitations of analogies such as the balloon model. The conversation includes theoretical considerations and conceptual clarifications.
  • Some participants argue that every particle in an explosion appears to be at the center of expansion, suggesting that the concept of a singularity's location is misleading.
  • Others propose the balloon analogy to illustrate that as the universe expands, no point can be identified as the center, as all points recede from each other uniformly.
  • A participant questions how a particle perceives its own motion and whether it can reference an external system.
  • There is a discussion about whether the balloon analogy accurately represents our 3D universe and if a center can exist in a higher dimension.
  • Some participants assert that the universe does not require a fourth dimension for mathematical descriptions of expansion.
  • One participant suggests that the observable universe's uniformity implies there is no center to the universe, as any center would create observable temperature variations in the cosmic microwave background (CMB).
  • Another participant argues that the term "where" is inappropriate when discussing the big bang, as it implies a spatial location that may not apply to the state of the universe before the big bang.
  • Some participants express confusion over the idea that a singularity could be described as "everywhere," leading to further clarification attempts using the balloon analogy.
  • There is a contention regarding the definition of singularity, with references to its implications in astrophysics.
Participants express multiple competing views regarding the nature of the big bang singularity and its implications for the universe's structure. There is no consensus on whether a specific location can be identified or how to interpret the concept of "everywhere" in relation to the singularity.
Participants highlight limitations in understanding the big bang and its implications, particularly regarding spatial concepts that may not apply prior to the big bang. The discussion reflects varying interpretations of analogies and definitions related to singularities.
jumpjack
If all galaxies originated from big-bang, and if currently galaxies are still moving away one from the other, shouldn't it be possible to determine also where they are moving away from? i.e.where the big-bang-singularity was?
Space news on Phys.org
No. the nature of an explosion is such that every particle appears to be the centre of expansion.
I don't get it.
In an explosion , all particles come from the same point and each one goes to a different point.
At least, seen from outside. How does a particle see its own motion? Can "she" see it w.r.t the outside reference system?
jumpjack said:
I don't get it.
Balloon analogy. Think of a bunch of dots marked on a balloon. The balloon expands and every point on the surface of the balloon recedes from every other point. In fact, the rate of recession between any two dots is directly proportional to their distance.
Note that the surface of the balloon has no centre; no dot can claim to be nearer a centre than any other dot. When the balloon was (ideally) zero-size, all dots were at the centre.
The two sentences do not match!
Indeed, all dots on the surface were previously all in a single point: the centre of balloon VOLUME.
So, where is this point in the Universe? Can we determine it? How?
Or maybe the balloon surface (2d) represents our 3d universe?!?
Could we determine the "centre position" if it was in the 4th (?) dimension?
Can Flatland inhabitants determine position of objects in the 3d space surrounding them?
Correct.
As it turns out, the extra dimension is not actually required for the math to work out. The balloon doesn't need a 3rd dimension, the universe doesn't need a 4th, and neither need a place for the centre to be.
DaveC426913 said:
Correct.
maybe our math doesn't need the additional dimension, but the Universe has it! The balloon HAS a 3rd dimension!
I'm not saying "just" the math doesn't need the dimension; I'm saying the 3D expansion of the universe works just fine mathematically without the need to resort to a 4th dimension.
Thing is, it's virtually impossible for the layperson (non-mathematicians) for wrap their head around it, which is why we resort to simpler analogies.
That's why it's an analogy. Not everything about the balloon analogy is translatable to the universe.
I'm not an expert of this but perhaps I can provide an explanation that will help.
The first thing you have to understand is that every direction we look, we can see for 13.7 billion light years. This means one of two things. WE are at the center of the universe OR the Universe is much larger than we can see and it is roughly uniform in every direction.
Every time we say we're at the center of the Universe we are proven wrong. This is why we call what we see, "the observable universe". Base on our observations of the observable universe, there is no edge and since there is no edge, it could be infinite or finite and wrap around itself. If you take the entire Earth and you put an ant hill on one small part of it then ask the ant where the center of the Earth is, will he be able to tell you an answer or will he just say that the Earth goes on forever?
Basically, you're asking a question which no one can really answer. The data from the CMB seems to show that everything is roughly uniform in all direction. This would imply that there is no center because a center would by definition be where the big bang originated and it would show up as hotter in the survey. Again, if there is a center that is outside of our observable universe, we would expect to see that one direction is cooler (whichever direction is the exact opposite of the center). It is of course possible that the center of the universe is so far away that we can't see the extremely small decrease in temperature with our current equipment.
In other words, based on current observations, the universe started with everything at a single point in space and everything expanded from there. That's the only way to account for current observation.
I hope that helped.
I think the word "where" is inappropriate to use when describing the Big Bang. When we usually use "where", we are implying some location in 3-D space in our Universe but the Big Bang was the start of our Universe and I suspect just prior to the Big Bang there was no space but rather something qualitatively different and therefore our concept of space, of location, distance, size, volume, area, location, and other similar metrics are not applicable and cannot be used to describe the instant of the Big Bang and therefore "where" it occurred.
Q. Where was the big bang singularity.
A. Everywhere
Skippy
Here is an article that throws around a plethora of ideas except the ID one.
http://www.tomcoyner.com/before_the_big_bang_there_was__.htm
A. Everywhere
Skippy
A singularity was everywhere ?
Then everywhere was / is a singularity. Very confusing.
Go back to the balloon analogy. When the balloon was uninflated (ideally, a point), all dots on the balloon were in the same place. None had a preferred location. When the balloon began to expand, all dots that were at the initial point of expansion moved away from that point. Still, no dot has a preferred location. And no one dot is nearer the initial point of expansion than any other.
OK, but when the balloon was uninflated all the dots were at one single point, not everywhere.
The single point was equal to everywhere, everywhere was the single point...
What you're missing is that the balloon/point/universe was not a point in space; it was a point that was all space. There was no space outside that point.
As DLuckyE says, that point is what constitutes "everywhere".
From ..
http://www.thefreedictionary.com/
I think the agreed consise definition of singularity is;
Astrophysics; A point in space-time at which gravitational forces cause matter to have infinite density and infinitesimal volume, and space and time to become infinitely distorted.
It is difficult to believe or to even understand the notion that 'all there is' was contained in zero volume. Very difficult.
As Chronos said in ..
https://www.physicsforums.com/showpost.php?p=2849594&postcount=4
Plenty of work is in progress to remove the big bang 'singularity'. It is highly theoretical and speculative - largely because we have little or no clue haw to obtain the necessary observational evidence. We are fairly certain singularities are illogical, but, lack the math/evidence to dismiss them with any confidence. The nature of the universe remains quite mysterious.
As a layman (or less), I can certainly go no further than this.
But I sometimes entertain wild notions ..
"OK, assume it was initially a singularity - could it be that it still is, and that we exist still inside it, and are even smaller than that singularity ? After all, to call the universe 13.7bly wide (for our purposes) or to call us, say, 13.7b times smaller than the initial singularity, might just be the same thing"
But don't take me seriously - I'm probably being silly, seeing as I can't go in any other direction with it.
With respect to the surface of the balloon no location on the surface is the center of expansion
At time 0, the balloon was a point. As time progresses from then, it expanded into what we see now. The time/space location of point at time 0 only exist in the past and not in the present "balloon surface"
True. Though we have rolled back the film to a very small fraction of a second after the BB, when it was still smaller than an atom.
I think I'll retroactively loosen the use of the term "point" - whether it is actually a single point or whether it was just a small volume - changes nothing in the scenario being discussed.
The fact that the theory has a singularity at the "starting time" doesn't mean that there actually was a physical singularity at that time. It's far more likely that the theory simply fails to describe what really happened when we get too close to the "starting time."
When or if we make observations that give us information about conditions before the earliest time that we can currently "observe," and they disagree with current theory, we'll simply have to revise the theory. In the meantime we work with what we have.
Yeah, this is what I am beginning to understand is the correct interpretation of the word.
Singularity doesn't identify an event or object, it simply identifies the boundary of our model - our knowledge of the event/object, beyond which it breaks down.
As with the BB, so it is with BHs (black holes).
OK - even that though, is hard to accept. 'All that there is' was contained in something smaller than an atom .. there's something very wrong here, and I speculate that in my lifetime and yours, it will be shown as such.
Zero volume, however, can be as different to small volume, as nothing is to everything.
I like your retroactivity, BTW :-)
That makes sense.
I can respect that too. Thanks !
(without ANY disrespect implied to any other posters)
The only difficulty with the idea is that it goes against the concept of 'solid' objects - but we've already realized that's an illusion anyway.
The atomic theory dealt it a massive blow, quantum mechanics killed it stone dead.
Let's be clear: none of that was matter. None of it was comprised of any substance that actually takes up room. Matter did not precipitate out until the universe was much much cooler.
Instead of looking at it as "full of stuff", think about this: How bright can a room get - how much light can you pack into a room - before it is "physically too full" of light?
Hi Dave;
Your 'light / room' analogy is very instructive and makes the point clearer to me. Thanks.
Your first paragraph "None of it .."
What is (or was) 'it' ? Mainly photons / electrons ? If so, mainly light precipitated into matter ?
Also, I'm still wondering about the singularity issue, which is what I jumped in about in the first place. Up till recently at least, singularity was thought of as a zero dimension / infinitesimal volume point, wasn't it ? That's what I was, and continue to have problem with.
If the physical world follows some rules which are essentially mathematical, then solid objects cannot be an illusion. If everything is an illusion, then we can accuse Newton and Einstein of creating illusions out of illusions. In that case, we would rather search for a metaphysical answer.
It was too hot for electrons (another form of matter).
It is all energy (I think it was photons, but I'm not sure).
The objects are not an illusion, their solidity is what is illusory.
First we discovered that heretofore "solid" atoms are almost entirely empty space, then we discovered that protons and electrons are not solid either, but are comprised of quarks. Are quarks solid? As we look deeper and deeper, the components become more and more like energy fields than any "real" form of soild substance.
  • · Replies 38 ·
  • · Replies 31 ·
  • · Replies 31 ·
  • · Replies 69 ·
  • · Replies 33 ·
