Where When Physics Problem with 1 obj going up and the other going down.
  • Thread starter Thread starter ssjcory
    Physics
6 replies · 8K views · last reply
ssjcory
An object is thrown downward with an initial speed of 10 m/s from a height of 60m above the ground. At the same instant, a second object is propelled vertically upward from ground level with an initial speed of 40 m/s. At what height above the ground will the two objects pass each other?
Professor said for where+when problems should always use the formula
Xf = X0 + (VX0)(Δt) + (1/2)(AX0)(Δt)^2
Variable key:
Xf = final x
X0 = initial x
VX0 = initial velocity
AX0 = acceleration due to gravity (-9.8m/s^2)
Δt = change in time
Ok so first I mapped out the known factors in the equation for each motion of interest
For motion A we have:
X0 = 60, VX0 = 10, AX0 = 9.8, missing Δt and Xf
For motion B we have:
X0 = 0, VX0 = 40, AX0 = 9.8, again missing Δt and Xf
I figure that we are looking for the X when both x's are zero so I set them to equal each other in the same form as the equation
AX0 + AVX0(Δt) + (1/2)(AX0)(Δt)^2 = BX0 + BVX0(Δt) + (1/2)(AX0)(Δt)^2
60 + 10t + 4.9t^2 = 40t - 4.9t^2
From this I get everything to one side so the right side is 0 and I can use the quadratic formula to solve for Δt
Equation looks like
9.8t^2 - 30t + 60 = 0
So i do the quadratic equation
30 +/- sqrt(30^2 - 4(9.8)(60)) all over 2(9.8)
I end up with 3.47475 OR -.413526 as Δt.
I plug either one of those numbers into either one of the original equations to solve for Xf and I get numbers that are no where near correct.
He has listed the answer as 41 m.
Am I going about this completely wrong?
Thanks,
Cory
I have not looked at your work too closely, but I will say right off the bat, I think you might have some sign issues. You need to choose what direction you will consider positive and what you will consider negative. Your initial velocities are in opposite directions and so they must have opposite signs. The values of acceleration will have opposite signs as well.
Thank you I was wondering if that might have been my issue. I flipped the signs on acceleration but I guess all of them have to go in the opposite directions. I will retry and post my work here. Thank you!
EDIT: Tried changing the sign on one of the velocities... came out with wrong answers... Then tried changing the other motion's sign instead and it was wrong again.
Gonna try again tomorrow... been at this for hours on 1 problem lol.
Thanks!
OK I lied ... I stayed up and tried it again... I have a value that is close for distance... 45.04308602 meters(all values kept in calculator memory so not rounded)... His answer is 41m I wonder if it could just be a difference in rounding or something... I'm not sure :(
When I plug my time that i calculated from the quad formula into the original 2 distance equations:
Xf = 60 - 10(t) - 4.9t^2
and
Xf = 40t + 4.9t^2
They both give me the same answer:
Xf = 45.04308602 ... Does that mean that it IS the distance where they cross paths?
Thanks.
Cory
Bump: Can anyone tell me if the methodology used to check my answer is correct?
It seems like it would make sense but I don't like that my answer doesn't agree with the professor's.
I got 41 meters. You need to still be careful with your signs. Look at the following:
and
Xf = 40t + 4.9t^2
The term with 4.9 in it is your 'gravity term.' If you choose 'up' to be positive (which you have, by putting a (-) sign in front of the 10t in the 1st equation) then since gravity points downward, the gravity terms must be negative right? So why is is the gravity term negative in the 1st equation and positive in the 2nd ? Gravity is pointing upward in for object B? :wink:
Thank you very much I finally figured it out.
So in the equation when I always have gravity as negative it works.
I think I had tried it before that way but in writing a step of the equation I had left numbers off or changed signs... It would seem I need to be extremely careful with making sure I write the initial equation right and every subsequent operation because 1 tiny mistake will make me scratch my head for days :D.
Thanks again Saladsamurai.
