- 3,379
Nugatory said:I'm not just completely quibbling here. In this case we end up with the right answer, but consider the similar problem with the Lorentz transformations (and the time dilation and length contraction formulas that follow from them). These are derived under assumptions that are equivalent to ##v<c##, just as your argument is derived under the assumption that ##m_0\ne 0## - but when we try to generalize by dumping that assumption and plugging in other values of ##v## the results are nonsensical in a way that has confused generations of physics students. Why should one procedure any less invalid than the other?
john t said:Thanks Nugatory. I understand, and I do not think you are quibbling, and your analogy with the Lorenz situation makes the point clear. Can one say that my logic shows the consistency of the specific with the general equation, given the acceptance (naieve?) of relativistic mass?
Relativistic mass is not wrong, as it's found in many good books (eg. by Feynman, Purcell, Rindler) just that one has to be careful with how one uses it. In many cases, it is easier to avoid the relativistic mass for the purpose of obtaining a correct calculation.
Anyway, maybe to rephrase @john t's question, why does using an argument beyond the validity of its assumptions sometimes work? From the point of view of theory, massless photons are completely different from massive particles, as they are not at rest in any of the usual inertial reference frames, However, given that we don't know for sure that neutrinos and photons are massless, it seems that the equations for massless photons and for massive photons give almost the same results, ie. it would seem that the equations for massive particles should give results "close to" those for massless particles.
